Go Back   ADVrider > Riding > Trip Planning
Old 05-30-2012, 03:57 PM   #1
kyled1 OP
kyled1's Avatar
Oddometer: 117
Tow strap?
How many of you bring a tow strap with you on a trip? What kind of strap do you bring? Are there any light weight straps?
Kyle
kyled1 is offline   Reply With Quote
Old 05-30-2012, 04:01 PM   #2
PineyMountainRacing
Oops....
PineyMountainRacing's Avatar
Oddometer: 2,438
If off road, and rough terrain, I carry a length of rope. I recently bought a very small block and tackle, hope I never have to use it.
PineyMountainRacing is online now   Reply With Quote
Old 05-31-2012, 05:55 AM   #3
pfarrell
Oddometer: 112
MSR makes a dedicated small light motorcycle tow strap.
google it.
pfarrell is offline   Reply With Quote
Old 05-31-2012, 06:51 AM   #4
kyled1 OP
kyled1's Avatar
Oddometer: 117
google it.
Thanks! That's exactly what I'm looking for.
Old 05-31-2012, 07:01 AM   #5
NaeKid
Ancient member, eh?
Oddometer: 168
I have used tow-straps and tug-straps for getting other Jeeps unstuck when offroad but I have never used one for a motorcycle. Is there a safe way to make it happen? I did a quick YouTube search and found some videos and even found one where they tried to bump-start the bike via tow-strap and ended up dragging the bike sideways.
Good video using tow-strap offroad:
http://www.youtube.com/watch?v=_lzbMmoM050
Bad video using tow-strap:
http://www.youtube.com/watch?v=Wi6N5Iyqfwk
A Jeeper with a ZOR-decal'd KLR650 -- Vance
Just waiting for the day that I become road-spaghetti - till then, I ride.
NaeKid is offline   Reply With Quote
Old 06-01-2012, 03:26 PM   #6
acejones
acejones's Avatar
Oddometer: 5,282
I can't see much use other than to drag a bike out of a ditch.
I got tired of being here, so now I'm there
acejones is offline   Reply With Quote
Old 06-01-2012, 05:26 PM   #7
going south
hero & Zero...
going south's Avatar
Oddometer: 1,157
Few guys I know carry two small ratchet straps 1 inch by 6 foot, for strapping down on the ferry, or pick up truck haul out, or put together tow strap...
P.S. I have seen 4 packs in different lengths at costco & home depot for like $10.oo or so...
going south...
Never Lost! Just Don't know where I am!
"Don't worry about your money, let your money worry about you" Jorge González
going south is offline   Reply With Quote
Old 06-02-2012, 11:33 AM   #8
pfarrell
Oddometer: 112
some ferries require 4 straps...and depending on traffic, they may or may not be able to give them to you...
Old 06-02-2012, 06:49 PM   #9
Walterxr650l
Walterxr650l's Avatar
Oddometer: 1,286
I read in a magazine many years ago how to safely tow a motorcycle. You wrap the tow strap around the towed motorcycle's handlebars a few turns, then clamp it to the hand grip with your hand. With the right number of turns you can hold it with out strain, but when released it will pull free. It likely will take a couple trys to find the right number of turns. The important thing is the towed rider be able to release if there is a problem, instead of being drug. This method worked well the once or twice I needed towed.
In my opinion neither of those videos showed safe towing.
Walter
"How much a dunce
That has been set to roam
Excels a dunce
That has stayed at home."
Walterxr650l is offline   Reply With Quote
Old 06-02-2012, 07:00 PM   #10
Attico
Wrong way 'round
Attico's Avatar
Oddometer: 1,957
2 kayak straps. They are continuous loop and about 15 feet long.
“If you think adventure is dangerous, try routine; it is lethal.” (Coelho)
Attico is offline   Reply With Quote
Old 06-02-2012, 07:11 PM   #11
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,459
Walter
What he said ^^^^^^
Done it a few times.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 06-02-2012, 08:43 PM   #12
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,743
I got a tip recently on a way to tow. Go from footpeg to footpeg with the strap...then the strap doesn't want to pull either of the bikes over and you're going nearer to the center of mass of both bikes. I haven't tried it myself, but I have a friend who was in a tow situation last summer and he said it worked great.
Old 06-02-2012, 10:37 PM   #13
max384
Disgruntled Student
max384's Avatar
Oddometer: 3,549
I carry 550 paracord with me if I'm going anywhere longer than a couple of hours from home or am camping. Braid it or just loop it several times and it will easily have enough strength to act as a tow rope. This way you have an item that has multiple uses, which is great if you're packed heavy as is, like on a longer trip.
'09 Suzuki SV650, '02 KLR250, CRF70 and 80 for the kids IBA # 56419
Newfoundland 2012
James Bay 2014
max384 is offline   Reply With Quote
Old 06-03-2012, 04:20 PM   #14
Attico
Wrong way 'round
Attico's Avatar
Oddometer: 1,957
Thats the best way. I towed someone out on a g450x because the wimpy battery died. I don't wrap it, i just step on it. If anything happens, i just want it to slip free.
Old 06-03-2012, 04:34 PM   #15
shu
Oddometer: 1,053
I towed a BMW F650 Dakar 25 or 30 miles in Uzbekistan after it fried its wiring harness. Across pavement, dirt, and a welded steel plate and oil drum floating bridge- greasy and polished and long!
Uzbekistan
Fried wires
We used a 20 foot x 1 inch climbing webbing as the tow rope. Tied to my right footpeg and wrapped once around the Dakar's crashbar before ending up at my partner's left handgrip. We got pretty good at keeping the strap tight and making big wide corners.
Now I usually carry a 15 foot x 3/4 strap with me when I ride out in the backcountry.
...........shu
Ride report if anyone's interested: http://www.advrider.com/forums/showthread.php?t=568261
shu is offline   Reply With Quote
Times are GMT -7.   It's 02:50 AM.
