05-31-2012, 03:33 AM
#1 |
Journey not Destination
Oddometer: 1,004
Battery Bug = Good
I'm mid-ride between Florida and New York and notice that the battery bug is reading lower than normal numbers for running voltage. I'm seeing 13.3v at speed and 13.8v at idle. My battery was showing 12.2v in the morning before start up and caused the precipitous "hmmmmm".....
![]() So after pondering this for a few hundred miles, I considered it an issue. Had to go through the stages of motorcycle repair: deny (the diagnosis), delay (the decision), despair (about repair), and finally- act. Carolina BMW Greensboro, NC was the closest help and they took care of it. I called ahead and rolled in. They confirmed the problem as the regulator and pulled a part from a bike to get me rolling. |
05-31-2012, 06:25 AM
#2 |
Mod Squad
Oddometer: 53,454
A voltmeter like the Battery Bug is definitely worth adding to the GS. I have one and I keep my eye on it when riding
ADV decals, patches & flag? Here |
05-31-2012, 09:19 AM
#3 |
Oddometer: 388
Glad it worked out for you.
That's why I put the battery bug on sometime ago. You've got to know what's going on down there with these peculiar charging systems on our bikes. Also, the battery bug has some useful additional features as well, and I like the backlit on the new versions. God bless, David |
05-31-2012, 02:14 PM
#4 |
Oddometer: 1,004
I'm getting condensation on the inside of the screen. I'm a little peeved but this gives me an excuse to get a new one with backlighting.
05-31-2012, 02:22 PM
#5 |
Oddometer: 101
05-31-2012, 03:02 PM
#6 | |
Oddometer: 10
Edit - This is the one you want http://www.argusanalyzers.com/batter...analyzers.html It's the BB-SBM12-PS. The PS stands for power sports like motorcycles and jetskis. Dave |
05-31-2012, 03:36 PM
#7 | |
..this space for rent..
Oddometer: 2,189
any idea if that's one of the newish regulators that address the abnormal voltage patterns evident on most F800GS'?
- B Proud to be an inmate of AdvRider. |
05-31-2012, 04:28 PM
#8 | |
Oddometer: 101
05-31-2012, 05:34 PM
#9 |
Oddometer: 1,004
I can't say but, I like what I am seeing. Running voltage reads between 14.1 and 14.5. Which is higher than anything I've seen off my original.
05-31-2012, 06:26 PM
#10 |
Oddometer: 388
06-03-2012, 04:25 AM
#11 |
Danger: Keep Back 500 Ft.
Oddometer: 997
The voltmeter is great, but what is the meaning of "47%" displayed on the Battery Bug? Is it a gimmick, or is it an accurate reflection of the life of my battery? My battery was tested at the shop and it's fine.
I'll get off my lazy ass and look for a Battery Bug manual online. Fred P.S.: http://www.bugmanweb.com/c6/c6files/...nersmanual.pdf FredRydr screwed with this post 06-03-2012 at 05:02 AM Reason: added link |
06-03-2012, 07:11 AM
#12 |
Oddometer: 1,004
That's running voltage.
06-03-2012, 07:14 AM
#13 | |
Oddometer: 1,004
It has read lower. Happens when you start up, shut off, start up in quick sequence. Disconnect from the battery and reconnect. If it is still reading low you have an issue. |
06-03-2012, 05:31 PM
#14 |
Oddometer: 1,120
I carry a spare alternator and regulator on long trips. I too run the battery voltage indicator and it is very reliable to detect the difference from high 13s to low 13s.
Current Stable: 2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS 2007 Husqvarna TE610 , 2003 KTM 525 MXC |
06-03-2012, 06:07 PM
#15 |
Oddometer: 119
Hi, can you post a pic or two of where you place the display? Thanks.
