Old 06-03-2012, 08:35 PM   #16
Apostolos
Oddometer: 391
Originally Posted by mustardfj40 View Post
Hi, can you post a pic or two of where you place the display? Thanks.
Here is where I placed mine. It hasn't budged since I installed it several months ago.
God bless,
David
Apostolos is offline   Reply With Quote
Old 06-04-2012, 03:14 AM   #17
FredRydr
Danger: Keep Back 500 Ft.
FredRydr's Avatar
Oddometer: 2,462
The first photo shows where the Battery Bug is mounted on my F800GS. It is applied to a custom dash cover made by another inmate that I bought off the ADVrider flea market. It is essentially the same as the TouraTech cover, but allows the use of the BMW OE touring windscreen that I use in the winter. The second photo is of the TT dash cover on my bike with the Battery Bug, before I returned the cover to TT (because it did not work with the touring screen).
Fred
Custom dash cover:
TT dash cover:
FredRydr is offline   Reply With Quote
Old 06-04-2012, 02:09 PM   #18
Dieselboy OP
Journey not Destination
Dieselboy's Avatar
Oddometer: 1,176
Originally Posted by Indy Unlimited View Post
I carry a spare alternator and regulator on long trips. I too run the battery voltage indicator and it is very reliable to detect the difference from high 13s to low 13s.
Are the spares OEM or after market? Source?
Dieselboy
The Adventure Continues
Dieselboy is offline   Reply With Quote
Old 06-04-2012, 02:13 PM   #19
Dieselboy OP
Dieselboy's Avatar
Oddometer: 1,176
I mounted mine to the right of the RID.
Dieselboy
Dieselboy screwed with this post 03-28-2014 at 06:58 AM
Old 06-04-2012, 02:27 PM   #20
JoelWisman
JoelWisman's Avatar
Oddometer: 1,392
Originally Posted by FredRydr View Post
The voltmeter is great, but what is the meaning of "47%" displayed on the Battery Bug? Is it a gimmick, or is it an accurate reflection of the life of my battery? My battery was tested at the shop and it's fine.
I'll get off my lazy ass and look for a Battery Bug manual online.
Fred
P.S.: http://www.bugmanweb.com/c6/c6files/...nersmanual.pdf
It is data that coupled with other things has meaning but without almost none.
Battery bug assigns some numbers that they arbitrarily pulled out of their ass for what the average voltage should be during startup. They then assign an arbitrary number for what the voltage would be with a shitty battery. From that they measure the voltage during your last start and show it on the screen 100% being at their highest arbitrary number and 0% being their minimum arbitrary voltage.
It wouldn't really matter if the voltages weren't arbitrarily assigned because oil condition, compression, in gear or neutral, ambient temperature, atmospheric pressure, engine temperature, starter motor commutator cleanliness and health, time since last startup, state of charge of battery, clutch drag, how long the engine takes to start, carbon build up in cylinder, and quite a few other things I am not bothering to type all influence how much current is drawn during startup none of which does the battery bug effectively compensate for.
I have substantial education and practical experience in this area so if someone wants to front me $500,000.00 to design something that takes all of these things into account then I think we could get a fairly accurate unit to production that if we sold in bulk would cost around 10 grand per unit and only take 19 hours to install
Use those numbers as a vague representation that something might be up, and if the reading is low during a warm startup that seemed normal you might bother to check if the terminals are tight and check the battery SOC and if all is peachy, load test the battery, but relying on the battery bugs battery state of health numbers causes needless anxiety and needlessly replaced batteries.
The running voltages are very nice to have however.
Owned to date. Honda Aero 50, Honda Elite 80, Honda Elite 250x2, Suzuki Katana, Suzuki RF600, Yamaha YZF1000R, Kymco Xciting 500, Suzuki GS500, Suzuki Burgman 650, BMW F800GSx2, BMW S1000RR, Aprilia Scarabeo 200, Aprilia Caponord, Aprilia Sportcity 250
I love and miss you Jeneca and I'm sorry.
JoelWisman is offline   Reply With Quote
Old 06-04-2012, 03:44 PM   #21
RexBuck
Oddometer: 1,089
So a simple voltmeter will do just fine?
Reading this thread, I thought this gizmo would be the cat's ass . . . apparently not. Seems a bit big for the limited dash real estate and I would prefer something compact. Any preferences?
www.rexbuck.com - RexBuck's Latin America
Information on travelling in Latin America.
Includes links to ride reports to Mexico and to South America
RexBuck is online now   Reply With Quote
Old 06-04-2012, 05:37 PM   #22
JoelWisman
JoelWisman's Avatar
Oddometer: 1,392
I would take a battery bug over a regular voltage gauge if both were cosmetically equal and similarly priced because it is some additional information.
The problem is you have to know a hell of a lot to interpret its false readings.
If your looking for a simple gauge that tells you when to replace your battery, forget it, the battery bug will have you replacing good batteries and keeping bad ones until they strand you
But if your the sort of person that can think "well it was pretty cold" or "I did have to crank longer then usual" "did have to crank twice in a row" "I haven't started it in a while" "I am at sea level know and previous readings were at 4000 feet" "I do need to change oil" "yeah I didn't pull the clutch all the way in on that start" "I did run some accessories for a bit so my battery probably isn't failing but just not fully charged" ect then it is helpful.
Then again, if you are that sort of person you could also just listen to how quickly the bike is turning over and know the same data the battery bug feeds you, so I suppose if you were deaf and the type of person that can mentally sort all of those variables....
It is a nice voltage gauge but one should have zero confidence it its battery state of health readout.
A brand new DEKA will show 10% health if you let the clutch drag or if the deka has been run down slightly, or its extra cold ect.
A Excide with one foot in the grave will show 100% if its nice and warm out and the battery is fully charged even though the buss is corroded and going to burn in half on the very next start.
If you want to know your batteries state of charge, a good multimeter is required, or voltage gauge far more accurate then the battery bug.
If you want to know your batteries health you need to do a real honest cold cranking amp test, not the abbreviated one motorcycle shops do.
If you want a good indication of your charging systems performance, a battery bug or motorcycle voltage gauge works just fine.
Old 06-05-2012, 03:55 AM   #23
Dieselboy OP
Dieselboy's Avatar
Oddometer: 1,176
The problem is you have to know a hell of a lot to interpret its false readings....
It's like using a GPS. It is not infallible. You must use your common sense to interpret what it is telling you. Otherwise you end up going in circles. So yes you will do foolish things if you follow the instrument blindly. But I don't know another product that is this portable that provides the same data.
I'm a long distance rider and don't base out of my home garage so this package is a good compromise. The data I get is well worth the false readings.
It is also good as an Alzheimer defense....keeps the brain active.
I'll stick with my battery bug (and brain).
Dieselboy
Old 06-05-2012, 05:51 AM   #24
FredRydr
FredRydr's Avatar
Oddometer: 2,462
I should have read manufacturer's information before my first post here. Apparently, Argus' technology behind the BatteryBug does take into consideration issues that Joel says it does not, and over a period of time, though a battery bench test would eliminate the potentially misleading variables he warns us of. So here is the other side of the story, with links, beginning with How Batteries Fail, the technology behind the BatteryBug:
Argus Battery Monitoring Technologies - Argus' smart battery performance instruments are powered by two core patented technologies:
CrankCheck
CrankCheck measures the electrical effort the battery actually exerts to start the engine. This technique is ideal for monitoring starting batteries because it is a direct measurement of the battery while it is doing it assigned job. The BB-SBM series uses CrankCheck to track cranking health decay over time and sounds and alarm before the battery fails.
The microprocessor in the BB-SBM series combines CrankCheck results, battery voltage information, and temperature to deliver the most advanced battery monitor for automotive starting battery applications.
Large Pulse Resistance (LPR)
LPR technology is the core technology powering the BB-DCM series of capacity and lifecycle meters for deep cycle batteries. LPR measures battery internal resistance which is effectively a measurement of the battery's ability to deliver electrical power. What makes LPR unique is that it precisely measures battery internal resistance while a battery is being used.
A powerful microprocessor in the BB-DCM series carefully tracks internal resistance as the battery is charged and discharged - and measures capacity decay over time providing the only real time state-of-charge and state-of-health meters available.
Unless these are a pack of lies (be sure to click on the links), it seems to this layman that the Argus BatteryBug will give me fair warning that, at the very least, further investigation of battery condition is warranted to avoid severe disappointment on the road. It's nice to have that as a bonus with the voltmeter (and it matches the OE gauges!).
Fred
FredRydr screwed with this post 06-05-2012 at 06:25 AM
Old 06-05-2012, 02:15 PM   #25
Mike.C
Stelvio Dreamer!
Mike.C's Avatar
Oddometer: 592
I wonder if it will work with a LIpo4 battery like Anti Gravity... They didn't answer when I emailed them to ask.
Cheers, Mike
Don't just look at it - Ride the bloody thing!
Mike.C is offline   Reply With Quote
Old 06-05-2012, 05:35 PM   #26
JoelWisman
JoelWisman's Avatar
Oddometer: 1,392
Here is what BMW uses at all of its motorcycle dealers to test batteries.
http://www.toolsource.com/battery-el...-p-103858.html
$795.00 and its right about half the time at best but still false positives and negatives.
go here: http://www.midtronics.com/shop/produ...battery-tester
if you want to read fancy advertisements about it, but no matter what advertising you read, the tool still doesn't work.
This: http://www.midtronics.com/shop/produ...ry-chargers-27 is what BMW's car side uses and it actually works well about 90% of the time with only a few false negatives and positives.
Price is a modest $4,589.00 You do have to remove the battery and set it on the charge tray because it weighs the battery which id one very good indication of electrolyte level in a sealed battery.
This tool http://www.usatoolwarehouse.com/usat...OL-CST800.html is right about 99.9% of the time, but it takes someone skilled to safely use it. They cost about a grand but used correctly are the be all end all for detecting battery health.
Heres the battery bug http://www.argusanalyzers.com/batter...analyzers.html
It costs $43.84 and has some very fancy advertising, but yes, the advertising is a pack of lies if you assume that all the fancy jargon indicates the tool can reliably estimate battery health. Just about everyone that owns one has seen super low battery health numbers as well as high numbers later on with the same battery. Did the battery somehow repair itself?
I personally test 6 to 15 batteries a day and have done so for going on 24 years. Currently I test usually 4 to 6 batteries a week in bikes that have battery bugs. I have found ZERO correlation between the BB's battery health % and the actual battery health. I frequently have batteries fail real load tests completely even though the display reads 80+% and have seen many batteries pass when the display reads 30% and below.
BB has nice advertising with many impressive terms, and it absolutes IS a good voltage gauge which I personally think every bike should have, but use your own eyes rather then advertising. The battery health % is no more informative then listening to the bike turn over and substantially less reliable.
Old 06-07-2012, 03:29 PM   #27
Dieselboy OP
Dieselboy's Avatar
Oddometer: 1,176
... and it absolutes IS a good voltage gauge which I personally think every bike should have, but use your own eyes rather then advertising. The battery health % is no more informative then listening to the bike turn over and substantially less reliable.
Joel, I'll concede the overall health issue (especially considering mine reads 30% right now).
But the original issue for me was all voltage related and in that regard this product worked well in allowing me to diagnose the problem.
Whether it is inaccurate as compared to $5k testers I do not doubt, but could the "health" measurement not be of use in monitoring relative change? It seems to be a good idea regardless of variance to ask, "why is that reading different?". Even if the answer is that the Bug is wrong. No use? Some use? Good use?
Dieselboy
Dieselboy screwed with this post 06-11-2012 at 05:41 PM
Old 06-07-2012, 08:56 PM   #28
JoelWisman
JoelWisman's Avatar
Oddometer: 1,392
Weather it is inaccurate as compared to $5k testers I do not doubt, but could the "health" measurement not be of use in monitoring relative change? It seems to be a good idea regardless of variance to ask, "why is that reading different?". Even if the answer is that the Bug is wrong. No use? Some use? Good use?
It's of some use. I would rather have a setup that had even an unreliable health gauge to none at all.
Just pointing out that the health gauge on the battery bug is best taken with a grain of salt. Do not use it alone when deciding to replace a battery, and absolutely do not take high readings to mean your safe and your battery is good.
I see people do both and waste money or become stranded all the time. I would have your charging system professionally tested twice yearly and before any trips dangerously far from civilization.
As to where to find someone working for a motorcycle shop that is capable and equipped for professional battery and charging system health tests...... If you are in the midwest you can bring it to me. Beyond that, I have never actually seen a motorcycle shop that could truly do this. Most car dealers have the expertise, but lack equipment for batteries as small as motorcycles use :(
Old 06-09-2012, 10:03 PM   #29
GJGSRider
carver
GJGSRider's Avatar
Oddometer: 72
Monitor Alternator
I want to monitor my alternator and be able to know when it starts to fail. I have lost one stator, under warranty. I drove the bike over 100 miles with no lights or gauges and if I let the rpm drop it would stall. It is an adventure. I want a warning. I bought a Heads Up LED Voltage monitor. We will see if it gives me enough warning to find a safe harbor.
RJeff
05R1200GS then 09F800GS now
GJGSRider is online now   Reply With Quote
Old 08-10-2012, 07:13 AM   #30
oduibhir
Russ
oduibhir's Avatar
Oddometer: 32
Well for a 40 dollar health indicator I guess when it drops below 10% I should heed what data the device is providing.
The Bug had been reading in the 20-30 range for a year when I started it and it dropped to 10 on the last 2 rides I had intended to clear it and ensure that pesky false low was cleared since it was coming out of my winter drive infrequently stage.
So I am supposed to meet Dieselboy in Torrington jump on my bike and get the dreaded CLICKCLICKCLICK sound.
So just replace the battery…20 phone calls later and I have enlarged the search to 400 mile radius who would have thought that a 1150GS battery would be so hard to find.. I should at this point say that my nearest BMW dealer is an 8 hour drive.
So I end up online because I can get one sent to me as fast as the local dealers can get me one, wow sometimes it sucks living on the end of the supply line.
I am not saying it is an infallible device but like any other tool it must be used as for the data it provides.
In the end my old battery had a bad cell apparently, as it will only hold 10.2 volts post charge for 24 hours.
Again I would NOT recommend ordering at any certain point on the “battery Life” but would consider not starting a long trip at below 20 percent.
Oduibhir
HIGH Adventure
oduibhir is offline   Reply With Quote
Times are GMT -7.   It's 06:54 AM.
