Old 06-05-2012, 08:48 AM   #16
aGremlin
aGremlin's Avatar
Oddometer: 395
Originally Posted by Synisalo View Post
I mounted it on the left side handlebar, right next to the clutch resevoir. I like being able to use it, while keeping my hand near the bar end. I cable my helmet speakers into it, and use it for music, and to let me know of a call comes in.
+1. Did this for my Zumo 550, and same again with my Zumo 660 I just bought, using the included RAM mounting hardware. I figure having it off the screen puts it too far away to use, and to see the screen only requires a quick glance down... safer than reaching forward to do something.
aGremlin is offline   Reply With Quote
Old 06-05-2012, 12:07 PM   #17
DetoX68
DetoX68's Avatar
Oddometer: 108
I made my own mount because the standard Ram mount (steeringbar clamp) was too much "in my face".
Where is global warming when you fuckin' need it???
DetoX68 is offline   Reply With Quote
Old 06-05-2012, 09:33 PM   #18
Final Drive
Final Drive's Avatar
Oddometer: 43
I have the Tourtech mount for the BMW Navigator IV and I really like it.
Final Drive is offline   Reply With Quote
Old 06-05-2012, 10:10 PM   #19
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,375
nuvi 550
Works great, RAM mount. Inexpensive and vibration free. First mounted at handlebar but now in front can be seen much better at this location.
Using the Garmin cradle, much better than RAM cradle, makes inserting the USB power plug in the nuvi much more simple, GPS can be inserted in cradle with USB plug already in the GPS.
The 3 screws seen on this picture are one size larger than the one's supplied with the Garmin cradle, the original
were one size too small and I ruined them immediately so used 3 screws/nuts I had from a different RAM cradle...
shows the exposed zink U-Bolt...
...found a black cable and removed the wire, pushed the U-bolt through it...painted nuts black...
Absolutely no visible vibration unlike the ADV-Crossbar mount I've tried before...
Ram-Mount:
http://www.gpscity.com/ram-mount-mot...-b-309-7u.html
used it with the short arm to minimize vibrations:
http://www.gpscity.com/ram-mount-sho...-b-201u-a.html
Garmin Cradle:
http://www.gpscity.com/garmin-nuvi-5...and-power.html
Powering the GPS via the 12V>5V USB plug adapter that came with the Garmin cradle kit,
using a relay triggered by the under the seat socket. Using the dedicated GPS
plug won't shut of power to to "Can-Bus" requiring additional load...I tried that first but
GPS kept charging and power didn't shut down...
tallguy-09 screwed with this post 06-06-2012 at 10:57 AM
tallguy-09 is offline   Reply With Quote
Old 06-06-2012, 05:52 AM   #20
labenske
Criminal
labenske's Avatar
Oddometer: 80
Here's where I put mine. I love it being up high and center because it helps me to keep my eyes on the road. I don't have any pictures of the mount, but I'm running the Garmin rugged mount attached via a short ram mount.
FYI, I now run my Montana rotated to the "portrait" position. Really helps to see what roads are coming up when exploring.
-Coop
2012 R1200GSA Triple Dirt
If the army still used flame throwers, I'd have never left.
labenske is offline   Reply With Quote
Times are GMT -7.   It's 03:09 AM.
