Old 08-22-2013, 05:28 PM   #226
FloorPoor
Oddometer: 712
Those bikes are sweet! I've been on the lookout for a totaled Versys to have on hand when my KLR is ready for a freshening up.
To bad I missed you when you were in southern Idaho. I would have ridden the 150 miles just to check out the KLR twins.
"You can have anything you want, but not everything you want."
"There's nothing like that fresh tire feeling "
FloorPoor is offline   Reply With Quote
Old 09-12-2013, 05:56 PM   #227
Slowphil
REALLY Gnarly Adventurer
Slowphil's Avatar
Oddometer: 1,627
Excellent thread, have you decided if your going to go into business with all that entails?
Cheers Slowphil
Everything will be all right in the end
and if its not alright then it is not yet the end.
Super Blackbird CBR 1100XX.......making squids out of gentlemen since 1996
Slowphil is offline   Reply With Quote
Old 09-12-2013, 06:53 PM   #228
KLRsys OP
KLRsys's Avatar
Oddometer: 131
Cheers Slowphil
I've been waffling about it but according to my wife I'm already committed. I bought another Versys yesterday and she say's "It's not for YOU so you better build another and sell it".
It's the "all that it entails" part that's got me a bit concerned. But hey, it's all just part of the adventure, right?
BTW, we'll be at the Roll the Bones rally in Lake Whitney, TX Oct 25-27 so if you're in the area stop by and take one for a spin.
http://www.rollthebonesrally.com
KLRsys build Versys powered KLR's
KLRsys is offline   Reply With Quote
Old 09-12-2013, 08:13 PM   #229
FloorPoor
Oddometer: 712
Not sure if anyone has suggested this yet, I may have missed it, but what about frame modification services? Someone sends you a KLR frame, and you modify it to fit the versys engine and send it back. That would be the most difficult part for most of us, and you already have a jig sorted out. That and the header pipe would be the hardest parts for myself and many others.
Old 09-19-2013, 09:13 PM   #230
KLRsys OP
KLRsys's Avatar
Oddometer: 131
At this point in time I'm only interested in building complete bikes, and partial builds don't look to be economically feasible, at least not yet. Still too many hand made parts.
Old 10-12-2013, 08:48 PM   #231
DiggerD
DiggerD's Avatar
Oddometer: 705
Nice Read KLRsys
Just spent a few hours reading your post. Good on ya. Got the Rocky theme song running in my head for ya. Been watchin the builds of this Kawi twin for some time. Thought about it but bought a 950 instead 'case life is short. Still have an itch tho. Met Jay Springer up Castle Rock flat track last year and he is involved with Kawi to get more rider on the track via less expensive bikes with this motor. That's a good motor for ya. Had good luck with Kawis my self. 86K on a 86 600 Ninja. 90k on my 92 ZX7R.
Thanks again for the read.
DiggerD is offline   Reply With Quote
Old 10-16-2013, 06:08 AM   #232
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
It is clear you are interested in the engine portion but those flimsy forks and that single brake would concern me for a bike with 70 HP vs 36.They must wobble some when you turn them up. Any plans to start looking at some quality USD forks and fitting some sort of 21 wheel with a twin rotor brake? Fork flex may have contributed to that tire/tube failure. Seems like a Ninja 600 front fork, t-clamps and brake system would be a good place to start. You are a good machinist and should be able to do this . Front 21 wheel with twin discs is biggest problem area. Your work is outstanding.
buls4evr is offline   Reply With Quote
Old 10-16-2013, 08:32 AM   #233
tonymorr
Malta,NY(Saratoga Spring)
tonymorr's Avatar
Oddometer: 2,530
Single front disk is a big problem???
2013 Multistrada 1200ST - 2013 Honda CB500X - 2014 Honda CTX700
2011 Husaberg FE 390 - 2014 Honda Grom "Napoleon" - 2014 Honda Grom "Lucy"
'07 Mutant Ninja II (sold)click for build report - 2008 Yamaha WR290R (sold-not sure why)
2013 Piaggio BV350 (sold)
tonymorr is offline   Reply With Quote
Old 10-16-2013, 01:07 PM   #234
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
You already have QUALITY BRAKES and FORKS on that bike! We are talking about KLRs here. But ,in fact yes, even that KTM could use double discs. KLR stuff is very "price point". So at least the OP knows where to get a front end that works pretty well (KTM). Or, maybe an XC front 21 from a Triumph.
Old 10-16-2013, 06:20 PM   #235
KLRsys OP
KLRsys's Avatar
Oddometer: 131
Brakes - Admittedly the Gen1 KLR's brakes leave something to be desired but the larger rotor and good pads fixes it to my satisfaction. The Gen2 brakes are fine. The fact that the bike has more horsepower now doesn't change the braking at all. It doesn't require any more brake to stop the same bike whether it has 36hp or 70hp, unless you forget to close the throttle when braking. You must understand that I really don't ride it much faster than I did before the engine swap, I just ride it further because it's so much nicer now. Also I don't like an overly powerful front brake on a bike I ride on gravel.
Forks - I've thought about changing to USD but I'm not sure the juice is worth the squeeze, at least not for the way I ride. The new back shock and front springs/emulators helped a lot and I'm quite happy with it as is. But at the end of Oct I'm hoping to ride a friends 05 KLR that has the USD fork conversion, I'd like to ride them back to back to see the difference. Maybe for the next build...
Old 10-17-2013, 03:57 AM   #236
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
The basic formula has never changed, F=ma. You have more mass with the heavier engine and a lot more accelleration from that engine.Especially when you load down bikes with a lot of luggage. That bike weighs more than a standard Versys I suspect and it( Versys) has 2 quite large discs, 2 larger calipers and they are mounted in USD forks with large T-Clamps.Kawasaki engineers really do know what they are doing when it comes to brakes.They think it takes more force to stop that much mass from speed.
If you pushed this bike to it's limit even once I think you would show underbrake and steering head shake/deflection on blacktop. A build this good deserves a better front end than the 1980s junk that a KLR has on it.You need to be ready to make a fast stop and want your bike to be able to do it and stop in a straight line. Gravel stopping is controlled by the brake lever pressure being lessened. One never hopes for a "weak brake" in any circumstances to help them.
T-Clamps.....just take a look at them! If the forks WERE strong enough, then the T-Clamps would still be insufficient by at least 50% for a bike this size.At least put a fork brace on the thing.That might help to keep them inline a little.Just asking you to consider this before that beautiful bike ends up in someones trunk
Old 10-17-2013, 08:37 AM   #237
Dallara
Creaks When Walks...
Dallara's Avatar
Oddometer: 2,070
Hmmmmm...
Hmmmm...
Let's see... KLRsys has actually built the bike, and built the bike he wanted (and apparently one that others have wanted, too, since they bought 'em). He has ridden both the KLR variants as well as the Versys, and combined the things he liked about both. He's a very smart guy, and an very experienced rider who has ridden one of these to Alaska and back, and I don't recall any part of that trip where "that beautiful bike ends up in someone's trunk"...
I don't want to sound out of line, but it seems to me if you don't like what he's built then you could always grab your tools and build your own. Why trash his thread by trying to get into an irrelevant debate with him?
He's actually ridden *ALL* the bikes being discussed here... Have you?
Dallara
You never see a motorcycle parked outside a psychiatrists office. - Unknown
'Cos it's easier to try than to prove it can't be done, and it's easier to stay than to turn around and run. - Justin Hayward
Dallara is offline   Reply With Quote
Old 10-17-2013, 09:39 AM   #238
jeepsandbikes
loneadventurer
jeepsandbikes's Avatar
Oddometer: 151
so what kind of prices are you looking at to build one ?
KLR 650 PRELOAD ADJUSTERS .. PM ME FOR DETAILS
A bad day of riding is better then a good day of work
jeepsandbikes is offline   Reply With Quote
Old 10-17-2013, 02:47 PM   #239
KLRsys OP
KLRsys's Avatar
Oddometer: 131
For a turnkey bike using a very low mileage Versys motor and a new or almost new KLR (maybe a new last years model), around $17-18k. My current Versys donor bike has 520mi on it.
Old 10-17-2013, 04:29 PM   #240
2old2Bbold
was 2bold2getold
Oddometer: 1,843
That ought to separate the men from the boys. $6K for the Versys + $6K for the KLR + $6K for the parts and labor. Or however it shakes out. Sounds fair to me, but I'm not sure that's enough. For all that R&D, trial and error, and late nights in the shop, YOU NEED TO MAKE SOME $$$$ !!!!
2old2Bbold is offline   Reply With Quote
Times are GMT -7.   It's 02:00 AM.
