Old 06-09-2012, 07:51 PM   #1
ktm950se OP
ktm950se's Avatar
Oddometer: 1,385
New Air filter: Bikeair/ITG
Greetings,
Does anyone have experience with Bikeair/ITG's air filter?
ITG's website lists a filter (assembly?) for the KTM 950 Adventure, 950 Superenduro, and 950 Supermoto, as part #HMP-747.
ktm950se
ktm950se is offline   Reply With Quote
Old 06-10-2012, 08:01 AM   #2
ktm950se OP
ktm950se's Avatar
Oddometer: 1,385
I'm guessing it'll look something like Mikael's ITG filter assembly, shown in his Ultra gravel-traveller. RC8Red Adv-S... thread:
ktm950se
Old 06-11-2012, 09:39 AM   #3
ktm950se OP
ktm950se's Avatar
Oddometer: 1,385
I just received word from ITG regarding this 'filter' and, alas, its just that and nothing more...
HMP-747 is a filter replacement only. It has no base plate. It replaces the standard filter and sits inside the stock air box of the Super Enduro.
ktm950se
Old 06-12-2012, 04:58 PM   #4
bambadoo
Oddometer: 5
I also use the one in the pictures above in my SMT. However I use the itg with 65mm internal height instead of 100mm as in the pictures. Works great..
It is called ITG Megaflow jc30 "sausage" filter.
http://itgairfilters.com/downloads/JC30.pdf
With corresponding baseplate.
bambadoo is offline   Reply With Quote
Old 06-13-2012, 03:33 AM   #5
ktm950se OP
ktm950se's Avatar
Oddometer: 1,385
Greetings,
Can you explain your baseplate setup in more detail?
Did you have to drill holes in it for the carbs to protrude through?
What Fuel Injector Body-to-baseplate gaskets/O-rings did you use?
Did you encounter any other issues or problems setting this configuration up?
ktm950se
Old 06-13-2012, 04:26 AM   #6
bambadoo
Oddometer: 5
Not time right now but some work had to be done....
As you can see the baseplate (1mm thick) had to be cut out to fit. a 4mm plexi glass was glued to it. (to make it stiffer and so that the throttle (I have changed to RC8 throttles) fitted good.
69mm o rings was also fitted to make the seal between the throttlebodies and the baseplate.
EDIT - 69mm o rings.. Not 6.9mm
bambadoo screwed with this post 08-15-2012 at 01:35 AM
Times are GMT -7.   It's 08:36 AM.
