Old 06-12-2012, 09:28 PM   #1
AstroZon OP
AstroZon's Avatar
Oddometer: 199
Thinking Outloud: VeeKayGo
OK, it will probably never happen, but as I own a BMW K75S, and was completely floored by this beautiful Virago > Vincent Conversion, I thought maybe it would be possible to put an XV1100 engine and rear drive into a K75 upper and front frame. Both bikes use the engine as a stressed member, however, the Virago has a frame holding the swing arm and the K75 pivots off the engine/trans.
I've actually looked at both frames, and I think a skilled welder could do it. I don''t plan to use my K75. I'd buy one with a blown motor or something.
Sorry about the bad photoshopped image, but I had trouble finding a profile shot of both bikes that were about the same dimensions. I had to use the K75 owners manual profile. Anyway, what do you think?
Moto Pasado
AstroZon is offline   Reply With Quote
Old 06-12-2012, 11:28 PM   #2
DR-Zed
Oddometer: 7
Looks interesting! You best get finding another K75 before someone beats you to it.
DR-Zed is offline   Reply With Quote
Old 06-13-2012, 06:17 PM   #3
bk brkr baker
bk brkr baker's Avatar
Oddometer: 4,134
I ride an XV920 Rh, the chain drive version of the Virago. I wholeheartedly approve of this progect.,
i'd also like to be there when you ride it up to bunch of narrow minded Beemerphiles. I picture a similtaious about face , shunning for you.
Do it.
Old 06-16-2012, 10:26 AM   #4
AstroZon OP
AstroZon's Avatar
Oddometer: 199
Thanks guys. I'm still looking at the two frames and trying to figure if I can get the front top engine mount of the Virago onto the BMW K frame. It's probably easier to make that mount out of plate steel and clone the angle.
Another idea is to use the Virago frame unaltered and graft the K upper tank and seat frame onto it. However, I like the strength and build quality of the K75 frame. The K bike gas tank is really cool and begs for use on Cafes / Street Trackers / Street Fighters. Other than modded K bikes, I haven't seen one used. They do house an electric fuel pump, so that's likely one drawback for universal use.
Low mileage XV1100s are common - I've seen several for a little over $2k. Cheap, undented K75s aren't as easy to come by. I had this in mind for a winter project anyway, so I'll take my time.
One more thing - if I go through with it, no way am I using those hideous Virago pipes.
Moto Pasado
Old 06-16-2012, 09:31 PM   #5
RedRaptor22
Oddometer: 133
This thread lacks empty beer cans and spent cut-off disks.
Aside from that it seems like a great way to make a beemer reliable and cheaper/faster to fix lol.
RedRaptor22 is offline   Reply With Quote
Old 06-16-2012, 09:54 PM   #6
AstroZon OP
AstroZon's Avatar
Oddometer: 199
Oh, plenty of empty beer cans, well, St. Pauli Girl bottles actually. You can't come up with hack ideas like this while sober.
Moto Pasado
Times are GMT -7.   It's 02:05 PM.
