Old 06-15-2012, 06:01 AM   #1
Süsser Tod OP
Süsser Tod's Avatar
Oddometer: 1,029
Another Chinese Scooter Blog - Italika GTS175
Basically, I just want to share my "experience" with my latest chinese bike, which is actually a scooter, 175cc GY6 scooter.
I got it with 500 miles on the clock, just 2 months "old". Already without a warranty, because the PO missed the first service, due at 250 miles, whatever. I really couldn't care less about the warranty, because I'd trust more a monkey with a wrench than the mechanics at the service centers for these bikes.
I've had prior experience with chinese bikes, so I knew what to expect...
And it didn't dissapoint.
First thing that went wrong, the clutch bell. It's quite common for GY6 scooters to have the clutch pads glaze, that causes a bit of judder when starting from stop (centrifugal clutch). Well, on mine it got really bad, so I thought about sanding the clutch pads and inside of the bell, that's pretty easy and shouldn't take more than 1 hour to do. So I get to it, remove the CVT cover and I take a look at the clutch bell...
Here, picture of a clutch bell:
Something was really wrong. It's not true, it's actually out of round! You can even see it on the machining marks on it. I was speechless! They took a clutch bell that was not true, visible in plain sight, and then they balanced it! It doesn't vibrate, because it's balanced, and if I sand down the inside of the clutch bell and the clutch pads, it does engage smoothly for... 50 miles? That's good enough just to get it out of the factory!
Amazing. I can get a new one for $25, just hope it's actually round.
Yesterday another thing broke (it's getting too much miles on it, 1000 miles!). I was going down hill, braking and then I feel something weird on the front end, and it was definitely on the front brake, I could feel something intermitently hitting the whole front end and the brake lever pulsating.
Long story short: The front brake rotor/disk broke! OMFG! Seriously, had never seen something like that happen. I still have to take a picture of that, will do later today. The OEM rotor is a "waved" one that doesn't look like it had too much R&D into it, they just cut it to look cool. Will replace it with a regular, round one, for $15.
Seriously, these chinese crappy bikes are not for the faint of heart. You must be a DIY'er or they will nickel and dime you to dead... Well, and you won't be doing much riding as it will spend most of it's time on the mechanic's shop.
Why did I end up with a cheap crappy Chinese scoot? My commute is now 3 miles each way, and I live in a very congested area. Not enough for any of the big bikes to "warm up", charge the batteries and the clutch on the big bikes would take a beating because of too much stop-go and slipping. The Chinese scoot is an experiment, if it works, I'll get rid of it and get a better scooter, and I already think the experiment was a success.
Yeah, I already tried this commute on the XT and CBR, I ended up stalling the CBR like 3 times and never shifted past 1st gear, on the XT it was 2nd gear tops, but she does have respectable low end torque.
Süsser Tod is offline   Reply With Quote
Old 06-15-2012, 10:42 AM   #2
MacNoob
MacNoob's Avatar
Oddometer: 1,672
Three miles? Sounds like walking would be less work than maintaining this thing....
"Persuade thyself that imperfection and inconvenience are the natural lot of mortals, and there will be no room for discontent, neither for despair."
MacNoob is offline   Reply With Quote
Old 06-15-2012, 12:47 PM   #3
Süsser Tod OP
Süsser Tod's Avatar
Oddometer: 1,029
Commute involves crossing two interstates, you can do it walking, if you're feeling suicidal.
Old 06-15-2012, 01:19 PM   #4
MacNoob
MacNoob's Avatar
Oddometer: 1,672
Ooog. Well that rules out "on foot" and "by bicycle" for sure.
Old 06-15-2012, 04:50 PM   #5
klaviator
klaviator's Avatar
Oddometer: 6,630
My Kymco Super 8 150 also has a GY6 engine. So far after nearly 7000 miles I haven't had to replace any parts unless you count oil, a spark plug and air filter. The GY6 engine can be reliable, it all depends on who made it. Oh, and since It's less than 2 years old it's still under warrantee It cost me more than a Chinese scooter would have but I depend on it to get me to and from work every day. Maintenance cost has been next to nothing since I service it myself although I will be replacing the belt before too long.
I ride, Therefore I Am.
klaviator is offline   Reply With Quote
Old 06-15-2012, 05:16 PM   #6
DudeClone
DudeClone's Avatar
Oddometer: 1,855
I think if you put wheels on that box sitting on the floorboard you'd be better off.
No but seriously, good luck. And it sounds like you know what you are doing, so hopefully it turns out well enough and becomes a halfway decent commuter
bikes
DudeClone is offline   Reply With Quote
Old 06-15-2012, 06:15 PM   #7
deezildennis
Its a what?
Oddometer: 864
Originally Posted by klaviator View Post
My Kymco Super 8 150 also has a GY6 engine. So far after nearly 7000 miles I haven't had to replace any parts unless you count oil, a spark plug and air filter. The GY6 engine can be reliable, it all depends on who made it. .
Over 4k on My Crappy China scoot but I did have a issue with the spark plug that was over tightened by the factory. I have a outstanding warranty and dealer so everything was taken care of in One day.. Only Nickle and dime-ing it has done is the fuel going into the tank and my over zealous oil changes. You cannot just pick bottom of the barrel and hope for the best especially with a generic china scoot. If you do....Be prepared to wrench.
I Hope the OP has Better luck with his Crappy China scoot.
deezildennis is offline   Reply With Quote
Old 06-15-2012, 06:41 PM   #8
Dabears
Oddometer: 722
Well at least you're lucky enough to have a back up bike to ride on the many days the Chinese thing is out of service.
1980 Vespa P200E
2006 BMW R1200GS
2012 SYM HD200 Evo
Dabears is offline   Reply With Quote
Old 06-16-2012, 07:36 PM   #9
CaseyJones
Ridin' that train
Oddometer: 1,024
Well, the hammer dropped for my crappy clone china scooter.
With 2700 miles on it, with Mobil 1 oil changes, with proper break in...AND with delightful performance and riding characteristics (that's what pisses me OFF) I started getting a rod knocking.
NO MISTAKE. It didn't let go; but I don't want to make it break. It supposedly is under warranty for a year...I guess the China Scoot marketers don't think many of them will see 3000 miles in a year. This one did.
We'll see how that plays.
CaseyJones is offline   Reply With Quote
Old 06-16-2012, 09:00 PM   #10
Süsser Tod OP
Süsser Tod's Avatar
Oddometer: 1,029
Kymco is Taiwanese, they are in a different league that is leaps and bounds better than generic Chinese scooters. Taiwanese and Korean scooters are close to Japanese scooters in terms of reliability, and only the cheaper ones might be a bit lacking in fit and finish. Really grinds my gears that people don't make a distinction between China and Taiwan, yes, both are China, but they are not the same. People in Taiwan won't buy Chinse scooters because they know how crappy they are, they do buy their own scooters and also Japanese scoots.
Old 06-16-2012, 09:11 PM   #11
Süsser Tod OP
Süsser Tod's Avatar
Oddometer: 1,029
Italika aint "bottom of the barrel", it's one of the biggest scooter brands in Mexico and one of the few that has some post-sale support. I actually went with one of the better Chinese scooter brands, but I'm not delusional and I won't try to fool myself, I know that even the best of them are crappy compared to Japanese, Taiwanese and European scooters.
"Over 4K"? Is that a joke? Seriously, 4,000 miles is nothing. I really find it funny that Chinese bike supporters always come out to defend their bikes claiming they have been trouble free for ridiculous low milleages. I know they are not meant to go on epic rides or touring for months, but I did feel kinda stupid parking my 2012 scooter besides a 30 year old Honda 50cc scooter outside of the parts store. The guy riding the Honda was looking to buy shock absorbers for it...
Come on, these things cost less than $500 F.O.B. somewhere in China. Yes, you can get a container full of 250cc scooters for $500 each. What do you expect to get for that kind of money?
Old 06-16-2012, 09:16 PM   #12
deezildennis
Its a what?
Oddometer: 864
Yeah its a joke. Good luck your generic crappy Scoot.
Old 06-16-2012, 09:32 PM   #13
Süsser Tod OP
Süsser Tod's Avatar
Oddometer: 1,029
Back on topic. Today I replaced the front rotor, here are the old and new rotors side by side:
The OEM rotor looks much cooler than the plain generic 150cc scooter rotor, I'll give them that. BUT, they just drilled holes on it to make it look cool. The rotors on these scooters are already too small, removing mass just makes them heat up faster and those holes and weaving do little to help cooling it. Well, that and the fact that they didn't account for the stress on the metal, which caused this:
It had cracked all the way through:
And it was cracking in other places too...
There is "logic" to their madness, we usually confuse the concept of "quality" with a product being good, reliable and all sort of positive attributes, when in fact, that isn't what quality is. The costumer buying these things, the branding company that imports them to your country, wants them to be as cheap as possible. They do allow for a certain amount of failures to happen within warranty, they factor that into the cost. They also know that a lot of these scoots will be toys, and once their owners get past the "new toy" stage, they will be parked under a tree and forgotten forever.
So, they expect them just to be reliable enough to get past the warranty period with a certain failure rate. The factories in China must supply thousands of these things that meet those requirements. That's where quality kicks in, meet the customer expectations...
http://en.wikipedia.org/wiki/Quality_%28business%29
Thing is, we are not their customers. Their customers are the branding companies. The factories in China couldn't care less about us, they do care about the branding companies, who are the ones giving them the money.
Back on topic.
I also replaced the clutch bell, but found that this particular 175cc GY6 uses a slightly larger clutch and bell than the generic 150cc GY6. Happily I had got a complete clutch and clutch bell for $30, so I replaced the entire thing. Now it's uber smooth!
Here, the old clutch bell:
Can barely be seen, but the machine marks are missing near where the reflection of the lamp is. Stupid blackberry... It seems that after welding the belt around the bell, they put it on a lathe, and as it is not round, there are parts with deep machining marks and others with no machining marks at all.
What can be seen clearly is on the inside, the pads were not making complete contact with the clutch bell as it wasn't round:
And notice how many holes they made into the thing to balance it out!
Well, it's fixed up... For now. I know it will break again, I owned 4 Chinese bikes before, this is the fifth. I'm very familiar with them and I know better than to expect it to be dead nuts reliable. I know something else will break, it's not a matter of if but when. I'm also curious as to what will break next.
Süsser Tod screwed with this post 06-16-2012 at 09:49 PM
Old 06-16-2012, 09:41 PM   #14
Süsser Tod OP
Süsser Tod's Avatar
Oddometer: 1,029
Thanks for the good wishes, but I don't need luck, I'm perfectly aware of what I bought and what I got into.
Old 06-17-2012, 09:06 AM   #15
deezildennis
Its a what?
Oddometer: 864
All of these issues are with a little over 500 miles on it?
I Think you need more luck than you think. :)
Times are GMT -7.   It's 03:44 AM.
