Go Back   ADVrider > Riding > Trip Planning
Old 01-20-2013, 11:49 AM   #1
SiouxsieCat OP
SiouxsieCat's Avatar
Oddometer: 210
Type I diabetics - your insulin/diet strategy
I'm planning a solo 2 week trip through SD, WY, CO this summer. I use Novalog and Lantus, a pretty common combination.
Obviously, I'm not going to be able to keep this stuff cool. I plan to carry all food/water - primarily dehydrated meals.
Type 1's - what is your strategy for long, somewhat-primitive trips? Any special diet or dosage tips?
Thanks very much
SiouxsieCat is offline   Reply With Quote
Old 01-20-2013, 11:53 AM   #2
acejones
acejones's Avatar
Oddometer: 5,282
Have you discussed strategy with your doctor ?
I got tired of being here, so now I'm there
acejones is offline   Reply With Quote
Old 01-20-2013, 11:56 AM   #3
Cannonshot
Having a Nice Time
Cannonshot's Avatar
Oddometer: 20,383
There are a bunch of threads on this topic already that may give you some of the information you are looking for. ("Search This Forum" "Diabetes")
Take a look at these and see if they help you out.
http://www.advrider.com/forums/showt...light=diabetes
Hope this information proves helpful to you.
Cannonshot.net
Cannonshot is offline   Reply With Quote
Old 01-20-2013, 12:53 PM   #4
SiouxsieCat OP
Oddometer: 210
Ya, this would be part of my normal discourse with her.
Perfect. Obviously my search skills need improvement. Thanks!
Old 01-22-2013, 09:27 PM   #5
Yakima
DL 650
Yakima's Avatar
Oddometer: 391
I'm a pumper for about six years; type 1 for 46 years. I'm 56.
Check out "frio" or its equivalent for keeping insulin cool.
Insulin pens are helpful. I injected through clothes on many occasions without ill effects.
I did break a pump falling on it. I now wear it around my neck on a lanyard under my jacket.
Check your Bg every hour or 90 minutes, especially for the first two days, to discover your rhythms.
Adjust accordingly.
being alone means maybe running a bit high at bedtime lest you run into lows at night.
It's really no big deal.
Good luck. Be smart. Don't worry.
Be yourself. Everyone else is already taken.
Yakima screwed with this post 03-08-2013 at 09:17 PM Reason: Consistency
Yakima is offline   Reply With Quote
Old 01-22-2013, 09:57 PM   #6
trippda
trippda's Avatar
Oddometer: 55
type 1 journey
Type 1 since i was 12 here. I am on the Novolog/Lantus regiment too. First I would spend a few weeks prior to your trip making sure you are really comfortable with your lantus dosage and carb to insulin ratio. Counting carbs should be easy with packaged dehydrated meals. If it is not labeled, I would reasearch carb/mass ratios and weigh out ideal portions so you know.
I use pens, so it is not really necessary to keep that small an amount cold. Highly recommended.
I second Yakima saying to check as often as possible for your first few legs of the journey to get your rhythm down.
One strategy the Doc told me about when I went to summer camp way back when, that I still use sometimes is to not be afraid to run a little high. Because as you know, last thing in the world you want is to go low while your riding. I find the physical symptoms of hypo really hard to notice while riding. This heightens the risk for dehydration though so beee careful!
I want a pump though
trippda is offline   Reply With Quote
Old 01-24-2013, 09:19 AM   #7
JustRon
ex-broadwayron
JustRon's Avatar
Oddometer: 1,290
You'd be shocked at how little the average dr knows about type 1. Having had it for 26 years, I've been through many of 'em, and it seems to be a pretty common trend. Rather the norm, as opposed to the exception, unfortunately.
2010 Beta 520RR
Baja crash Report
JustRon is offline   Reply With Quote
Old 01-26-2013, 05:38 PM   #8
panhead rick
Oddometer: 59
im pretty sure the pens dont have to be kept cold,i just started useing them...ive been dieabetic for 25 years and only had 1 bottle of novalog go bad because of the heat,,,but it was summer in nj and it was left in my truck the same way i always did.I pretty much have the same eating routine now for years so u should stick with your normal shots but keep snacks handy its better to be high on a bike than low thats the way i did it on my trips.just check your blood in the morning and you know your body better than any doctor,,even if your high a few days you will be fine.
panhead rick is offline   Reply With Quote
Old 01-26-2013, 06:30 PM   #9
JustRon
ex-broadwayron
JustRon's Avatar
Oddometer: 1,290
I carry clif bars (granola bars, cereal bars, etc) everywhere- it's actually pretty annoying lugging that crap around all the time.
I test my blood every 2 hours or so- even more when I'm riding. But, I don't eat breakfast, eat a small lunch, and a big dinner, so traveling is easier when you only need one big meal per day.
As others have said... I'd take the same insulin as normal, but if I were going to change my dose, I'd err on the less insulin side. High blood sugar takes years to kill you... low blood sugar kills you overnight.
2010 Beta 520RR
Baja crash Report
Old 02-21-2013, 10:21 AM   #10
kreegah
Oddometer: 33
Oh yes you are - and you should. Get a couple of them Frio wallets or just soak a t-shirt and wrap it around your pens/vials/whatever if the weather gets hot. Evaporation will do the trick.
Remember to pack your prescriptions, too (just in case).
kreegah is offline   Reply With Quote
Old 02-21-2013, 01:16 PM   #11
KinkyWinks
El Gringo Perdido
Oddometer: 66
I bought a 12volt/110volt cooler on e-bay that holds several bottles or 3 (I think) pens. It's about 6"x6"x12" I have ran it on 110 to test it. I have not wired it up to the Goldwing yet but, I plan to use it this summer. I have seen several types on e-bay, the one I got was around $70
So I told the Cop, "It's my damn motorcycle and I'll ride it as fast as I want to"
KinkyWinks is offline   Reply With Quote
Old 02-21-2013, 01:46 PM   #12
DevGuy
Oddometer: 10
+1 on the Frio pouches. They've worked for me when I did MDI and I use one now for my Novolog bottle used to fill a pump. I've ridden lengthy trips in Eastern Oregon and California with no issues due to heat.
If at all possible, I'd suggest a CGM. I use one that I put in a waterproof map case strapped to my arm (from Aerostich). As I'm riding, I can simply push the button and see where my blood sugar is.
If CGM isn't an option for you, then stop frequently to check even if you THINK you're good.
As for diet, I actually find eating low carb helps me with more consistent sugar levels. Less insulin means the numbers are far more stable but this isn't something you want to start just before a trip.
Darcy
DevGuy is offline   Reply With Quote
Old 02-23-2013, 03:39 PM   #13
SiouxsieCat OP
Oddometer: 210
Frio purchased!
Times are GMT -7.   It's 07:03 PM.
