Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 06-18-2012, 11:20 AM   #1
FixerDave OP
KLR650 - XR200R
FixerDave's Avatar
Oddometer: 396
Android tablet GPS maps and mount
Originally Posted by Myway View Post
You solved the problem: Taken a andorid tablet to the handlebars.
Rugged one? Waterproof? Size? Which? Picture?
Then I have to go digital to.
But i want my own custom symbols on it.
This is way off-topic for the original post, so I started this thread.
First, the pictures:
The mount:
rubber isolated in an attempt to reduce vibration... didn't work that well.
The sun shield:
Works well. The eventual plan is to wire the above adaptor in permanently
Here's the tablet in the mount:
The above shows an earlier version of the custom maps I've come up with.
I wrote a review the tablet here so I won't bother repeating it:
http://fixerdave.blogspot.ca/2012/01...ni-review.html
I also made a few comments, okay, whining complaints about using a table here:
http://www.advrider.com/forums/showthread.php?t=781683
But, to answer your questions, I'm using a cheap ($115) Chinese 5" Android 2.2 tablet that has a decent gps chip in it. Not rugged, not waterproof, but not expensive either. Glare was a big problem until I came up with the idea of using high-contrast custom maps, and that works surprisingly well. Overall, I'm very please with the results.
Someday, hopefully soon, I'll do a write-up on making custom maps for it. But, for now, the short answer is OSM data - Osmosis to grab a section - JOSM to make custom layers - Maperitive with a custom ruleset to render everything down to tiles - MOBAC to convert the tiles to Orux maps - and Orux on the tablet to actually use them. It was a steep learning curve, but after getting it figured out it's become fairly easy to work through the process.
David...
FixerDave is offline   Reply With Quote
Old 06-18-2012, 11:44 AM   #2
Myway
Myway's Avatar
Oddometer: 3,213
Thanks!! well done.
Myway is online now   Reply With Quote
Old 06-18-2012, 01:19 PM   #3
FixerDave OP
KLR650 - XR200R
FixerDave's Avatar
Oddometer: 396
As a side note, if you're making paper maps with custom info on it, you might want to look at Maperitive. It's designed for that, more so than making custom tiles.
David...
Times are GMT -7.   It's 01:50 PM.
