Old 06-24-2012, 02:19 AM   #1
dewi64 OP
Oddometer: 2
BMW system 6 sunvisor
I've been using the system 6 helmet for a while now, and although I'm not too happy with it, it cost me an arm and a leg and I can't afford to replace it.
My problem is that the sunvisor mechanism has become stuck on one side and the lever arm only drops down on the one side. Has anyone else experienced this? And what did you do to rectify or repair it? Is it possible to take the helmet appart and repair it myself or will I need to take it to a dealer?
Any help much appreciated.
Dewi
dewi64 is offline   Reply With Quote
Old 10-08-2013, 02:49 PM   #2
capofarukgb
By OverLand
capofarukgb's Avatar
Oddometer: 83
Dewi
hello! I have the same problem and called SBW BMW dealer in Herts, they said there are no repair option and the warranty is out by a month so I will have to replace, as you said it cost an arm and a leg to buy : no fair I know but im still wondering if there is someone who would have come with a solution for this
capofarukgb is offline   Reply With Quote
Old 10-27-2013, 04:50 AM   #3
capofarukgb
By OverLand
Oddometer: 83
Just to update I took the helmet apart and bent back the two cables on feeding the mechanism and put the whole thing back and it's all good
Old 11-19-2013, 07:49 AM   #4
ladmilk
Oddometer: 1
If not too much asking…how did you do it, did you have access to a video or manual? I stopped at the 3 screws close form the sliding mechanism before breaking something, which I'm good at…but since I'm getting older, I learned to ask advice…thank you for your help.
Grateful Lad from Montreal
ladmilk is offline   Reply With Quote
Old 01-19-2014, 11:55 AM   #5
kjc625
Oddometer: 5
Take 4th screw on the rear of the slide and separate the housing. You will see two wires probably tangled. Straighten the wires and put some oil on the wires. Put everything back together. Done.
kjc625 is offline   Reply With Quote
Old 01-23-2014, 02:18 PM   #6
capofarukgb
By OverLand
Oddometer: 83
Ladmilk have you done it yet? Please let me know if you still need the advice apologies I was away for a few months could not respond
Sent from my iPad using Tapatalk
One Life Live It
Old 11-02-2014, 01:25 PM   #7
Wiebe
Oddometer: 3
Hi! May I join in from Sweden and ask how I get access to the sun visor mechanism on my System 6 helmet? After removing the padding I can see four screws (T10 it seems) fixing the styrofoam shell inside the helmet. Are these four the only screws I need to remove to take the styrofoam shell out and get to the visor mechanism? Or are there more fasteners that need removing?
The sun visor apparently jammed when it was pushed up instead of pulled with the slider.
Wiebe is offline   Reply With Quote
Old 11-02-2014, 02:30 PM   #8
mwood7800
Oddometer: 611
I have purchased 2 bmw helmets and both rattled apart
mwood7800 is offline   Reply With Quote
Old 11-03-2014, 12:45 AM   #9
Wiebe
Oddometer: 3
How did you take the helmet apart, please? I have removed all the padding and I'm now down to the white styrofoam shell. There are four screws (with T10 heads) visible near the jaw opening. Do I need to remove them to get to the visor mechanism?
Are there any more screws other than these four that need to be removed?
Old 11-03-2014, 08:55 AM   #10
Gompie
Oddometer: 174
I've a C3 Pro now. From memory, you take out all 4 screws. Two are on the front, into the foam, and in a section covered by a black metal plate. I think the other two only hold the slider cover plate.
When you've taken out the screws, lift the front (cheeck) side just enough to be able to slide it forward, and downwards. This as it 'hooks' under the rest of the liner. Bending it too much can cause a part to break off. Guess how I would know.
Gompie is offline   Reply With Quote
Old 11-04-2014, 01:48 PM   #11
Wiebe
Oddometer: 3
Dewi
Hi! Since I have just had the same problem I'll respond even though your posting is several years old. The problem with the design of sun visor mechanism on the BMW System 6 helmet is that the two stainless steel wires that connect the slider control with the visor pivots are far too weak. With a diameter of only 0,5 mm the wires will buckle under compression where the cable run is unsupported for more than a few millimeters.
If the wires do buckle, the mechanism will jam and the only solution is to take the helmet apart completely and get a spare set of wires from BMW.
Compressing the wires will happen if one tries to open the visor by pushing the visor up instead of thumbing the slider control forward. The manual cautions against doing that (pushing the visor up) but folks seem to keep doing it regularly.
Taking the helmet apart is time consuming - allow a good couple of hours the first time. The only tool needed is a Torx size 10 screw diver.
I wish BMW would redsign the mechanism so as to keep the wires supported throughout their full run. BMW should offer that as a retrofit.
Old 11-05-2014, 01:49 AM   #12
Simonhantler
Oddometer: 308
do you guys find your system 6 noisy?
RIDING IS THERAPY. GG 250 trials,ktm 250, 690, 990, HP2 E, husa FE570.
Simonhantler is offline   Reply With Quote
Old 11-06-2014, 11:27 AM   #13
birdie_xx
birdie_xx's Avatar
Oddometer: 822
Which System 6 ?
Are you guys having problems with System 6 or System 6 Evo ?
If the first one, then I believe Schuberth (for BMW) did find the solution, as this was one of the improvements done to the Evo version, if I am not mistaken.
birdie_xx is offline   Reply With Quote
Times are GMT -7.   It's 01:50 AM.
