Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 10-14-2012, 09:24 AM   #211
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 6,112
Saw this yesterday.
I used to be indecisive. Now I'm not so sure.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 10-14-2012, 10:03 AM   #212
SpeedoJosh
SpeedoJosh's Avatar
Oddometer: 546
I'd kill for a Syncro Doka with a TDI. Literally kill
2000 XR250R - Tagged
2003 XR650R - Sold
2006 Ducati Monster -Sold
'Cause I like to party - Story of 2 XR650s conquering Florida
http://www.advrider.com/forums/showthread.php?t=754094
SpeedoJosh is offline   Reply With Quote
Old 10-14-2012, 05:11 PM   #213
a1fa
Riding Nomad™
a1fa's Avatar
Oddometer: 12,723
You can import one cheap... All it takes is granola, and time to follow through the maze of processes.
Learn to ride. Ride to learn.
a1fa is online now   Reply With Quote
Old 10-14-2012, 07:44 PM   #214
Hodakaguy OP
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 1,681
Progress has been slow lately, been working a lot of overtime.
Today I assembled the brakes on the passenger side and re-installed the tire.
Parts cleaned up, new wheel cylinder....going back together.
Hard line and new Stainless brake hose installed.
My friend Mike torquing the rear axle nut to spec while I snap a pic :-)
Sitting on the wheel again....oh yeah!
Installed the drivers side trailing arm.
That's all for tonight :-)
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy is offline   Reply With Quote
Old 10-14-2012, 07:59 PM   #215
SpeedoJosh
SpeedoJosh's Avatar
Oddometer: 546
I was about to ask what was the tank fill doing there, then remembered you're rocking a Syncro.
a1fa - Yea, I know importing is possible, but mucho expensive. Might be going to Germany though in a year, and if I do, you can bet I'm bringing back a Doka Syncro TDI.
2003 XR650R - Sold
Old 10-14-2012, 09:25 PM   #216
Mr. Fisherman
oneandahalfassed
Mr. Fisherman's Avatar
Oddometer: 9,811
Do you think you will ever do anything like this with it?
Mr. Fisherman is online now   Reply With Quote
Old 10-15-2012, 06:29 AM   #217
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 1,681
Ahhh....NO!
Hodakaguy
Old 10-15-2012, 06:31 AM   #218
ducnut
Oddometer: 2,460
Nothing wrong with that, as overtime funds projects.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 10-28-2012, 06:23 AM   #219
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 1,681
Progress.
It started to rain early in the am and the forecast didn't look like it was going to change all weekend so a improvised shelter was in order.
Brakes re-installed. To save time I had a few of the smaller driver side parts powder coated at a local shop while I was working. They powdered the mating surface area on the hub although I told them to leave that bare. I will strip it and re-powder it myself later, don't want a wheel loosening up if the powder wears etc.
Shock and spring installed.
Brake lines installed.
Wheel installed and axle nut torqued. Sitting on it's wheels again! :-)
Before...
After...
Hodakaguy
Hodakaguy screwed with this post 10-28-2012 at 06:36 AM
Old 10-28-2012, 06:56 AM   #220
zgfiredude
Oddometer: 493
Beautiful work, now, what's next? How's the motor coming?
zgfiredude is offline   Reply With Quote
Old 10-28-2012, 07:16 AM   #221
Hughlysses
Hughlysses's Avatar
Oddometer: 2,644
It is truly beautiful work. One question:
The new coil springs look to be ~6 inches taller than the old ones. The trailing arm appears to only lightly loaded yet the top ~5 coils of the spring are almost fully compressed. Are you really going to get much more useable suspension travel out of this setup?
2007 Buell XB12X Ulysses
1983 Honda VT500FT Ascot
Hughlysses is offline   Reply With Quote
Old 10-28-2012, 08:03 AM   #222
ducnut
Oddometer: 2,460
That is a progressive-rate coil spring. It is wound to softly ride in the initial travel and, then, get progressively stiffer as the wraps contact one another and the spring compresses.
'96 Ducati 900SS
Old 10-29-2012, 07:32 PM   #223
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 1,681
Little progress after work tonight.
Starting to get the engine ready to bolt up to the trans. Installed the new plugs, wires and coil back on the engine.
Installed a Vanagon temp sender in the reverse cooling manifold next to the Subaru sensor.
Bolted up the alternator and AC compressor. Here I ran into a little problem, the stand off for the heat shield is interfering with the AC belt. I pulled the stand off and moved the belt to the other side but it's still rubbing on the standoff. Red Arrow.
I finally just removed the stand off, the heat shield is plenty sturdy so I don't think it will miss this one piece.
Hodakaguy
Old 10-29-2012, 07:33 PM   #224
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 1,681
Thanks, getting ready to install the engine/trans soon....Then move it inside the garage :-)
Hodakaguy
Old 10-30-2012, 07:03 PM   #225
Keith
Slabbing it
Keith's Avatar
Oddometer: 787
Nice progress.
49 Hudson - 72 Yamaha - 74 Caravelle - 00 Honda - 03 Chevy - 07 KTM
Keith is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 04:28 AM.
