Thread Tools Rating: Thread Rating: 48 votes, 5.00 average. Display Modes
Old 06-27-2012, 06:21 AM   #31
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,555
Originally Posted by Hodakaguy View Post
It's really not as bad as it looks, I'm 6'1" tall and I can use the kitchen without a problem. I carry a Jet boil in one of the cabinets for heating water...a lot faster if you only need hot water.
Hodakaguy
Cool, thanks - then it would work for me.
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is online now   Reply With Quote
Old 07-01-2012, 04:16 PM   #32
Hodakaguy OP
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,086
Work around the house has slowed progress on the Westy. I did manage to get a little work done on the 2.5L this weekend.
Received my parts for the timing belt change out in the mail on friday, decided to do a little work on it early Sat morning. The engine only has 60K miles on it but since it's out of the vehicle and on the stand it makes since to freshen everything up while it's easy to get at.
Timing belt removed.
New water pump installed.
New idlers, water pump, thermostat, timing belt and belt tensioner installed.
Note the red arrow, this is where the timing belt guide would be if this engine came out of a manual transmission car. The guide keeps the belt from skipping a tooth if its parked in gear on a hill without the E-brake. Since this engine came out of an automatic Outback it doesn't have the guide, Since I will be installing it in a manual Vanagon I will install the guide before I button it up.
A shot of the guide as listed in the Subaru repair manual. The part is only $5.00 and I figured the Japanese installed it for a reason, I'll install it on mine for cheap insurance.
Old parts.
A few more bits showed up for the build. Received the front and rear wheel bearings, hardware and seals. Also received the Burley upper control arms and T3 Powerflex suspension bushings.
Once I start on the suspension I'll sand blast all the parts and powdercoat them while they are out, should make a clean install once re-assembled.
Can't wait!
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy is offline   Reply With Quote
Old 07-01-2012, 06:07 PM   #33
zgfiredude
Oddometer: 844
Looking good, sub'd and watchin' every step of the journey!
zgfiredude is offline   Reply With Quote
Old 07-01-2012, 06:43 PM   #34
madeouttaglass
The AntiHarley
madeouttaglass's Avatar
Oddometer: 3,534
At first I wondered why screw up a nice original Syncro, but it looks like you do very nice, thorough work. This is going to be a nice build.
Our ride across the USA on a Ural Gear Up- http://www.advrider.com/forums/showthread.php?t=781149
Escape from NY- http://advrider.com/forums/showthread.php?t=955520
madeouttaglass is offline   Reply With Quote
Old 07-01-2012, 06:56 PM   #35
.fisher
pissin' in the wind
.fisher's Avatar
Oddometer: 150
Originally Posted by zgfiredude View Post
looking good, sub'd and watchin' every step of the journey!
+1!
.fisher is offline   Reply With Quote
Old 07-01-2012, 07:09 PM   #36
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,463
Looks like an interesting build to me too, IN !
Mike
Cogswell Rides To Big Bend
See my airhead project here
Time Warp Vintage Motorcycle Club
The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED.
Cogswell is online now   Reply With Quote
Old 07-03-2012, 09:04 PM   #37
huzar
Pastor of Muppets
huzar's Avatar
Oddometer: 2,234
huzar is offline   Reply With Quote
Old 07-04-2012, 05:48 AM   #38
a1fa
Riding Nomad™
a1fa's Avatar
Oddometer: 13,838
Belts, due to tension, or lack there of, are known to pop out... Good $5 insurance in my opinion.
Learn to ride. Ride to learn.
a1fa is offline   Reply With Quote
Old 07-21-2012, 08:13 PM   #39
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,086
Ok...Finally go the new driveway poured so the Syncro build can resume. I will be pulling the stock engine soon, lots of work ahead.
I've made a few small steps....hopefully the pace will pick up now.
Tightening the crank pulley. You need clean oiled threads and it needs to rotate at least 60 deg before it gets full torque. Mine went past 90 deg and finally hit torque. Here's a shot tightening the crank pulley.
Installing the reverse coolant manifold. With the intake manifold removed you can see the stock coolant manifold. The modified manifold will exit the engine on the back side instead of the front...making for a nice clean install in the bus.
Here you can see the modifications done to the stock coolant manifold. This manifold is from RMW. There is deep corrosion pitting where the coolant hose connects to the manifold on the RMW supplied unit...the core I'm sending them is nice and clean :? . I will clean up the RMW unit and fill in the pits with metal filler, don't want any leaks at the hose connection.
Lots of parts :-)
Had a lighting storm pass over a couple days ago, I drove the Westy to a vacant lot and tried to frame the bus in with a lightning bolt...unfortunately the lightning stopped right as I got set up :-(
The engine coolant sensor harness needs to be modified to reach the new sensor location. The blue arrow is where the original sensor port was located...the red arrows are where the harness needs to reach now. Here I've started to lengthen the stock harness.
Harness modified :-)
Hopefully more progress will be made soon.
Hodakaguy
Old 07-21-2012, 08:21 PM   #40
nfranco
over macho grande?
nfranco's Avatar
Oddometer: 770
What kind of metal filler can you use on the coolant manifold?
nfranco is offline   Reply With Quote
Old 07-21-2012, 08:47 PM   #41
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,086
Any kind of metal epoxy will work...just fill in the pits and sand smooth. They manifold was pressure tested before it was shipped to me, I'm just concerned that coolant will try to leak out between the hose and the manifold if the pits are left in place.
Hodakaguy
Old 07-21-2012, 09:34 PM   #42
nfranco
over macho grande?
nfranco's Avatar
Oddometer: 770
Cool, thanks. I've got an old Land Cruiser with some pitting on the thermostat housing, will give the epoxy go.
Great build on the Westy!
Hodakaguy
Old 07-22-2012, 06:16 AM   #43
a1fa
Riding Nomad™
a1fa's Avatar
Oddometer: 13,838
Hoodka, does your horn work?
Old 07-22-2012, 06:39 AM   #44
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,086
Yes.
Hodakaguy
Old 07-22-2012, 08:48 AM   #45
a1fa
Riding Nomad™
a1fa's Avatar
Oddometer: 13,838
Let me know if you need any parts. I am going to Poland tonight. I ordered 3 horn contact rings for $15/pop, versus $55 from robWesty.
Thread Tools
Times are GMT -7.   It's 05:32 PM.
