Thread Tools Rating: Thread Rating: 59 votes, 5.00 average. Display Modes
Old 05-01-2013, 10:02 AM   #526
Xtremjeepn
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,069
06 KTM 950 Adventure(The Fainting Goat)
02 KTM 520 EXC
04 KTM 351 EXC
Xtremjeepn is offline   Reply With Quote
Old 05-01-2013, 10:56 AM   #527
PaulGinAZ
FNG
PaulGinAZ's Avatar
Oddometer: 259
Nice job! I love the attention to detail that you have given this project.
-Paul
- All bikes gone... thanks for the memories!
-2013 Yotota Tacoma TuRD (daily)
-1989 VW Syncro Tristar TDi (long-term project)
-Too many bikes and cars in my sordid past to list...
PaulGinAZ is offline   Reply With Quote
Old 05-01-2013, 07:21 PM   #528
eric1514
(R)
eric1514's Avatar
Oddometer: 300
Originally Posted by Hodakaguy View Post
From that site
Current draw on 12 volt is 2.5 amps (average) with an average daily usage of 22 amp-hours
I guess I don't understand, but 2.5 amps average for 24 hrs is 60, not 22 and 60 will kill a 100 amp/hr battery in one day. Is my math wrong?
Eric
P.S. Beautiful build.
eric1514 is offline   Reply With Quote
Old 05-01-2013, 07:26 PM   #529
Hodakaguy OP
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,092
Originally Posted by eric1514 View Post
From that site
Eric
The fridge cycles and doesn't run continuously, just as needed. When running it's pulling around 2.5amps, with a total amp draw of 22 amp hrs daily. If it's real hot out or you are opening the door a lot the fridge will cycle more and use more current.
I plan on eventually installing a roof mounted solar system and onboard charger to keep the house batts topped off when parked. For now they will charge when the vehicle is running, parked and plugged in to 110v shore power (charging through a on board charger) or if parked a long time I have a Honda 1000 Gen that will charge through the shore power plug as well.
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy is offline   Reply With Quote
Old 05-01-2013, 09:09 PM   #530
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,119
Hodakaguy
That seems odd, or amazing, that the fridge when running would only draw about the amount of power required to run the fridge light (30 watts eq 2.5amps x (nominal)12v.) I'd check that draw before I headed out for a few days. . . . but I have no doubt that you will check it thoroughly
Really nice build.
Zak
ktm
old bmw
others
slackmeyer is online now   Reply With Quote
Old 05-02-2013, 04:34 AM   #531
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,092
Really nice build.
LOL...yep already checked it before I painted the fridge :-). I wanted to make sure the fridge was 100% operational and check the amp draw as well. I also wanted to make sure there was no parasitic load when the fridge was in the off position, otherwise I would add a on/off switch going to the fridge.
When the compressor first kicks on it pulls about 3.5 amps, then quickly stabilizes at 2.4 to 2.5 amps while running. Then I turned the fridge to the off position to verify it wasn't using any power....and the meter read 0.037 amps, Hmmmmm parasitic load? Then I realized I had the door removed at that point and the light was on, pushed in the door pin and I got 0.000 amps. No parasitic load when off and the light takes 0.037 amps :-)
Light draw. I didn't snap a pic of it running.
Hodakaguy
Old 05-02-2013, 09:50 PM   #532
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,092
Ok...time to get started on the fridge project. Started removing the fridge today and quickly got side tracked on another project lol.
Removed the fridge door and the trim around the fridge. Yep...this is where I got side tracked already. Thanks to another Samba member I got the idea to use the old fridge door as a new closet access door. Before I cut the trim piece to match the new fridge I wanted to use it as a pattern for cutting the new door in....soooooo better get that out of the way now :-)
Separated the fridge door from the cabinet door.
The closet is pretty deep and has a lot of storage capacity, unfortunately the only access is the tall skinny door above the rear table (red arrow). It's not very convenient to get stuff in/out and you have to dig around to get to stuff on the bottom.
With the rear door removed I used a square to draw a level pencil line so I could place the trim piece on and mark out the opening. You can see a light pencil outline of the cut out.
Tape applied to keep the laminate from getting scratched. I built a home brew Westy hospital tent to try and control the dust during it's open cabinet surgery :-)
Drilled a small test hole with a hole saw to see how it cut through the laminate. Worked good but you have to go really slow to keep it from grabbing as it goes through the laminate.
Ok...a few more trial cuts with the 4" hole saw and then it was time to cut the corners in.
Used a square and a jig saw to cut the rest of the opening out.
Used a router to cut in a groove for the original trim from the fridge.
And installed. This will make it a LOT easier to get stuff in and out of the closet. Looks like it came this way from the factory!
Door open. I'll make a shelf to install inside so it will be easier to utilize the space more efficiently. The trim is still loose in places in this pic.
Last project for the night, applied some silicone to the groove and taped the molding into place. I'll install the door again in the morning and move on to the fridge install.
Hodakaguy
Old 05-02-2013, 10:16 PM   #533
troidus
Oddometer: 15,116
You may want to put something down on the floor ribs in there to keep them from getting scratched up and rusty. It may cut down on noise in the cabin and heat in the closet, too. (Based on the rest of this build, you probably have already custom-made something just for the purpose and haven't told us yet.)
troidus is online now   Reply With Quote
Old 05-02-2013, 10:21 PM   #534
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,092
Lol. I actually have a piece of carpet that goes in the bottom, but I removed it before cutting the opening to make clean up easier :-)
Hodakaguy
Old 05-03-2013, 09:06 AM   #535
Rainmaster
Rainmaster's Avatar
Oddometer: 441
Hodakaguy
Anal retentive is as anal retentive does...... LOL and I mean that as a complement,! I truly admire the effort in this build. Looking forward to the camping reports.
"Some people try to turn back their odometers. Not me, I want people to know "why" I look this way. I've traveled a long way and some of the roads weren't paved." Will Rogers
Rainmaster is offline   Reply With Quote
Old 05-03-2013, 10:08 PM   #536
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,092
Today's progress.
Took the Syncro in for an alignment first thing this am. I knew I had it close with the garage alignment but the steering wasn't quite right, just had a weird feel to it. I wanted to get it checked before it started eating my new tires, I'll have it re-checked after I put 1500 miles or so on it and let the suspension bed in properly.
Well the front was off a bit (figured that) but I had the back close enough that he didn't charge me for tweaking it to exact specs, only charged for a front end alignment. :-) It drives a lot nicer now with a normal feel from the steering wheel. All the T3 Urethane bushings are great, nice solid feel in the front end!
Next up...Propex heater install.
Headed to my friend Mike's house and pulled the stock fridge.
With the fridge out I was anxious to check behind the insulation and see if there is any rust forming. Water can leak in from the outside hook ups and once inside gets trapped and forms rust. I pulled back the insulation and poked around...nice and clean, no rust :-)
Cutting the access holes for the Propex heater. I decided on the under the fridge location since it will take up the least cargo space. I was originally going to mount it under the rear bench seat...but it would take up a large amount of that area and I use that storage space a lot.
My friend Mike recently installed his Propex in this location and so far it's worked great.
Checking layout with the supplied pattern, getting ready to drill the two holes for the intake and exhaust piping.
Holes cut and sub floor removed. I painted the bare metal with POR-15 and later applied a coat of high temp RTV on the edges. You need to get the Propex as low as you can so you can have a air gap between the fridge and the heater.
With temps in the Mid 80's it was getting hot inside the bus...time to roll out the awning. Man what a difference, the interior stayed a lot cooler with the awning out.
Propex mounted in place. I'll be using foil tape to wrap the edges around the openings. Here the cover is open and I'm getting ready to hook up the power and control wiring.
Running the wiring for the thermostat and controller. I'm using these screw on type wire retainers, you just screw them down then slide a snap tie through the slots, makes for a nice neat wire run.
And wiring up the thermostat. Having the new closet door in the rear worked great, had a lot more room to work in there and run the wiring :-)
More tomorrow.
Hodakaguy
Old 05-04-2013, 05:12 AM   #537
jdiaz
Oddometer: 32,259
If this camper was being offered on the GoWesty site, it would cost $86,000.
jdiaz is offline   Reply With Quote
Old 05-04-2013, 06:13 AM   #538
bassogap
Haulin' the kids around
bassogap's Avatar
Oddometer: 1,594
And would be listed as ***SOLD***.
bassogap is offline   Reply With Quote
Old 05-04-2013, 10:06 AM   #539
riverdog
Oddometer: 5
Amazing
I never join forums, but I found your build somehow and have been following you with this project since almost the beginning, and just had to join here and complement you on this amazing build. Ive never seen such attention to detail and your skill level is second to none. After looking at the prices of other Syncros for sale, I'm certain you have a six figure camping machine. Good work!
The best part of all this is you and your Dad working on it together.
Jeff
riverdog is offline   Reply With Quote
Old 05-04-2013, 09:28 PM   #540
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,092
Jeff
Welcome to ADVrider! Thanks for the comments. I'm getting really close to having it ready for camping season, we have a couple trips coming up soon and we can't wait! My father and I have done quite a few projects over the years, I feel really blessed to have been able to do them with him...memories I'll never forget!
Hodakaguy
Thread Tools
Times are GMT -7.   It's 06:26 PM.
