Thread Tools Rating: Thread Rating: 33 votes, 5.00 average. Display Modes
Old 08-04-2012, 06:47 AM   #76
Hodakaguy OP
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,087
Originally Posted by dlearl476 View Post
Something tells me that when you finish with this one, you're going to want to do another one with all the information you've learned from this one, what do do again, what to avoid, etc.
I'd be happy to help finance the next project by buying this one when you get it finished.
It would take a LOT to make me want to start over again......but if you want to make a offer
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy is online now   Reply With Quote
Old 08-04-2012, 01:46 PM   #77
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,046
Hey Hodakaguy-
I'm curious, with the cost of synchro westys now, and all the work put into the subie swap, could it make sense to build a syncho out of a 2wd westy bus at the same time as the engine swap? I'm sure it would be spendy, but it seems like you could pick up a 2wd westy with a blown engine for quite a bit less money.
Zak
ktm
old bmw
others
slackmeyer is online now   Reply With Quote
Old 08-04-2012, 03:41 PM   #78
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,087
Originally Posted by slackmeyer View Post
Hey Hodakaguy-
Yep it has been done a lot. The trick is finding a Syncro that has good running gear and a bad body to rob the running gear out of. Then a good 2wd with a good body and bad running gear. There will be minor things like the fuel filler in the wrong location on the 2wd so you will have to graft the body section out of the syncro as well. With the price of Syncro Westy's its being done more and more.
Hodakaguy
Old 08-04-2012, 08:07 PM   #79
RocketJohn
Hook em' Horns!
RocketJohn's Avatar
Oddometer: 11,330
Great work... love keeping up with this thread...
RocketJohn is offline   Reply With Quote
Old 08-04-2012, 10:43 PM   #80
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,087
Progress report.
Woke up this morning and started masking parts in preparation for powder coating. This is a high temp tape made to be used in the oven. I masked off the phono finish area where the hub and drum mate up, don't want PC causing the connection to get loose down the road as the PC wears.
More masking.
Applying powder.
19 minutes in the oven and out back to cool down.
Last piece for the day. Since it's heavy and would be easy to mess up while removing it from the oven I shut the oven down and let it cool in place.
A group of freshly PC'd parts. Since the drum takes the brunt of the heat I painted it with 1200 Deg F. Stove Paint instead of PC.
After powder coating I applied rubberized undercoating to add an extra layer of protection inside the rear control arm, with a extra thick layer along the seams.
Over at Mike's polishing up the seal surface on the axle.
Inboard bearing installed. This bearing slips in easily and is secured by a large snap ring. (Snap ring not installed yet in pic). It will be well greased with Waterproof Bel-Ray grease.
For the outboard bearing I used Dry Ice and Denatured Alcohol to shrink the bearing down. Liquid N2 works best but this method will get you around -110 Deg F. Shrinking parts helps prevent wear and tear on both the new bearing and the housing during install. A properly cooled part will require a lot less force to seat the bearing then just pressing/driving a warm bearing.
Outboard bearing installed. Next up pack the bearing with grease and press in the axle. At this point I remembered I was going to drill and tap a hole for a grease zert...oh well bearings are already installed so I will have to do that down the road some time. More to come.
Hodakaguy
Hodakaguy screwed with this post 08-04-2012 at 11:30 PM
Old 08-05-2012, 01:11 AM   #81
Nailhead
Painting by numbers
Nailhead's Avatar
Oddometer: 6,144
You're an artist, man.
-Chris
'7? Benelli 650S, '80 BMW R100 RS, '07 KTM 990 Adventure
Nailhead is offline   Reply With Quote
Old 08-05-2012, 07:17 AM   #82
A-Bone
Indubitably
A-Bone's Avatar
Oddometer: 12,547
Great thread... and thanks for sharing it with us!
Is there a specific reason you would use powder coating over a liquid coating... there are some pretty amazing paints out there these days....??
A-Bone is offline   Reply With Quote
Old 08-05-2012, 10:08 AM   #83
DireWolf
Knees in the Breeze
DireWolf's Avatar
Oddometer: 12,929
Wow.
Please help Elias' (Toolfan's) young family - they lost a husband and a father: Donation Page: Toolfan Support Fund
DireWolf is offline   Reply With Quote
Old 08-05-2012, 10:25 AM   #84
a1fa
Riding Nomad™
a1fa's Avatar
Oddometer: 13,758
Originally Posted by Hodakaguy View Post
Nice steel toes, bro :)
Learn to ride. Ride to learn.
a1fa is offline   Reply With Quote
Old 08-05-2012, 11:37 AM   #85
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,370
I was thinking the same thing. Having worked on many transmissions in the shop and have something roll off the bench to hit my foot just past the steel cap, I've learned to quickly shift my feet away from the bench. Not to mention the chipped safety glasses when a drill bit broke.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 08-05-2012, 12:32 PM   #86
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,087
I actually just walked out in the garage to snap that pic while I was typing up the days progress. I do work in sandals way to often though. :-).
Hodakaguy
Old 08-05-2012, 12:37 PM   #87
DirtFarmer
Has anyone seen my mother
DirtFarmer's Avatar
Oddometer: 2,664
Great project, nicely done!
PM me if you need any salt nitriding, black oxide or hard crome. Be happy to help.
Well, sister, the time has come for me to ride hard and fast. - Rooster Cogburn
DirtFarmer is offline   Reply With Quote
Old 08-05-2012, 02:48 PM   #88
dlearl476
Two-bit Throttle Bum
dlearl476's Avatar
Oddometer: 23,418
So tell me, other than the satisfaction of knowing everything is done right, and the ability to do it piece meal, what is the economics of doing the PC yourself.
Always wanted to get into it so I could do small bits and pieces as needed, but never got past the initial outlay for materials and an oven. Same with Carbon Fiber.
I got a little "anodizing" kit from Eastwood a few years ago. It's really nice to be able to plop all the bolts from a project and coat them, but none of the parts, so far, have seen any real world conditions, so who knows how well the finish will hold up. But they LOOK great!
"When the power of love overcomes the love of power, the world will know peace" - Jimi Hendrix
Politics is the gentle art of getting votes from the poor and campaign funds from the rich by promising to protect each from the other. -- Oscar Ameringer
dlearl476 is offline   Reply With Quote
Old 08-05-2012, 08:16 PM   #89
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,087
Thanks for the offer....I'll keep it in mind
Hodakaguy
Old 08-05-2012, 08:21 PM   #90
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,087
I really like the finish that the Minitex Powder provides. It's durable and holds up well....plus I have free access to the equipment so that helped a lot in the decision process Having the equipment at home and being able to work with it when you have a free moment is a big plus, keeps the progress rolling instead of waiting on a shop to get the parts back to me. Another benefit is being able to bolt up the parts as soon as they are cooled down, no waiting for paint to dry.
It's really not that hard to do, although there are several tricks that we've had to learn along the way. I'd love to experiment with a home anodizing....I could see where that could come in handy as well!
Hodakaguy
Thread Tools
Times are GMT -7.   It's 09:52 PM.
