Old 06-25-2012, 06:29 AM   #1
Moto Bikemad OP
Ride, see, fall off!
Moto Bikemad's Avatar
Oddometer: 63
Back wheel movement ???????
Sorry if this question has been asked....(have looked but don't know what I am looking for)
I was in Dublin City Centre on Sat night, with a charity cycle run Belfast to Dublin and back. (210 miles each way)
Got a puncture, on my 2000 1150 GS and while I was repairing it I noticed a slight movement in my back wheel.
If you grip the tyre, there is a little movement right to left from the rear.
Was discussing this with some of my fellow bike marshall's and there was talk of some adjustment, and a video, something
to do with a long stick and a bag of sugar.
This could have been the beer talking.......
Any help would be great.....
Moto Bikemad is offline   Reply With Quote
Old 06-25-2012, 06:36 AM   #2
tagesk
Tuscan rider
tagesk's Avatar
Oddometer: 3,135
Send a message via Skype™ to tagesk
There should be no movement in the FD.
Not in 3-9 and not 12-6.
Zero.
Movement is the first and surest sign of a worn main bearing.
It will leave you stranded if you don't attend to it.
[TaSK]
'02 R1150GS - Adds life
My Riding in Tuscany-thread is here.
Renting out motorbikes in Toscana, Italy
Proud contributor to Wisdom and GSpot FAQ and European Ride Report Index.
IBA: 33616
tagesk is offline   Reply With Quote
Old 06-25-2012, 06:43 AM   #3
ultane
sqeezin the bag
ultane's Avatar
Location: the dry side of the blood brain barrier in SW Id
Oddometer: 858
What he ^^^^ said...
I might be wrong... Just ask my X...
I might be wrong, just ask my X...
If a man speaks, and there is no woman present to hear him,..
Is he still wrong?
ultane is offline   Reply With Quote
Old 06-25-2012, 03:18 PM   #4
MIXR
MIXR's Avatar
Oddometer: 501
Before you panic
A bit of movement can also just be a sign that your paralever bearings are on their way out. Mine had movement for 50,000 kms before they were replaced. It drove my service guy nuts because I kept saying 'No' as they weren't bad enough by my reckoning. Really depends on whether it's 12/6 or 9/3 movement and whether you are sure it's the wheel or the whole paralever. Also check the wheel's rotation with a slow rotation. If the big bearing in the drive is going, you MAY feel it or hear it, but it's a test that may not show the problem. If you can, pull the rear wheel and look for any oil staining around the rear drive seal. That's also a sign that the bearing may be moving. And last (or first), drop the rear drive oil out and see what's on the magnetic plug. You may find nothing. You may find metal. A bit of sludge on the mag plug can be normal if you don't do the diff oil often. Bottom plug to drain, top plug to fill, and 250 ml of any good GL5 gear oil. Re-use the old crush washers. Look for a silver sheen to the oil that comes out. It may also be cloudy or dirty if it's been there a while. Start changing it every 10,000 kms with your engine oil.
MIXR is offline   Reply With Quote
Old 06-25-2012, 03:32 PM   #5
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 41,491
Kind of as above.
First verify if it is your FD or your paralever bearings that are the issue.
Hold the brake pedal down and try again. If your movement persists, it is your paralever. If no movement it is your FD!
Jim
Old 06-27-2012, 08:32 AM   #6
Moto Bikemad OP
Oddometer: 63
Hi,
Just changed the drive oil, nothing out of the ordinary,
Looked at the hub no leaks.
Nothing on the magnet, just a little dust, in oil.
I do change the oil every 6000m with the other fluids.
The movement is 3/9, with a little noise, click.
No grinding or growling when wheel is spun.
Still there when back brake is pressed........
Old 06-27-2012, 06:28 PM   #7
HighWay319
Oddometer: 12
That's good news. Sounds like its just the paralever, much cheaper part to fix.
HighWay319 is offline   Reply With Quote
Old 06-27-2012, 06:29 PM   #8
JimVonBaden
"Cool" Aid!
Oddometer: 41,491
Hi,
No wories, pivot bearing wear. Simple fix.
Jim
Old 06-27-2012, 07:53 PM   #9
Short-Johnson
IBA# 34787
Short-Johnson's Avatar
Oddometer: 121
12-6 movement
could you guys explain the 12-6 movement a bit more as to how much should be allowed and what would be the cause of lets say 1 inch of free play 12 to 6 ?
08 GSA
07 TW200
05 Wide Glide "Bad ass"
99 GZ 250
2011 WR450F
Short-Johnson is offline   Reply With Quote
Old 06-27-2012, 08:18 PM   #10
solarinsocal
Oddometer: 27
I think about 1" of free play will mean your wheel is about to fall off. I think you might be misunderstanding the play at 12 and 6.
solarinsocal is offline   Reply With Quote
Old 06-27-2012, 08:32 PM   #11
Short-Johnson
IBA# 34787
Oddometer: 121
very possible I am mis understanding, the 12 to 6 I thought would be as if the bike was rolling back and forth. I grab my wheel and roll it and it has an inch of play. but as i write this I'm thinking I understand the whole 3-9 12-6. Grab the wheel at 3-9 try to move it then at 12 top and 6 bottom and repeat ? sound right ?
08 GSA
07 TW200
99 GZ 250
2011 WR450F
Old 06-27-2012, 08:32 PM   #12
SloDon
SloDon's Avatar
Oddometer: 488
I am sure I will be corrected if I am wrong.....but they are NOT talking about driveline slack/lash while trying to rotate the wheel in gear. There will be some of this always....
I believe they are talking about grasping the wheel at the 3 and 9 o'clock or front and rear POSITIONS and trying to ROCK the wheel on its axle then again at 12 and 6 or top and bottom.
Seeing if there is any free play.
SloDon
'09 R 1200 GS Adv, '05 DRZ 400, '08 RE Bullet 500
http://www.youtube.com/user/SlooDon#p/u
Don't grow up.......it's a trap!!
SloDon is offline   Reply With Quote
Old 06-27-2012, 08:36 PM   #13
Short-Johnson
IBA# 34787
Oddometer: 121
Thanks slowdon, took me a bit but I got it..... Nuttin gets by me !!!
08 GSA
07 TW200
99 GZ 250
2011 WR450F
Old 06-28-2012, 01:46 AM   #14
Moto Bikemad OP
Oddometer: 63
I was looking at the back wheel from the exhaust side.
Grabbing it at the top 12 and the bottom 6 and trying to move it.
Doing the same at 3 o'clock and 9
Just a big guess on my side
Old 06-28-2012, 02:07 AM   #15
MIXR
MIXR's Avatar
Oddometer: 501
Yep - That's it.
You've got it now guys. No rotation of the wheel involved. Just a static check on the centrestand with the rear wheel off the ground. It can be deceptive, but testing it each service and jotting down what you find is a good thing to do. As I said earlier, worn paralever bearings can be lived with for a long time if you want. They tend to 'squeak' when they get too bad and too dry, and the movement can become excessive. There a question that this can exacerbate other loads on the drive bearings, but I'm not convinced of that having had a lot of play on one bike and no drive failure, and no play on another bike and a drive failure after relatively few miles.
Times are GMT -7.   It's 07:24 AM.
