Old 06-26-2012, 09:01 PM   #1
henrymartin OP
Mr. Tourguide
henrymartin's Avatar
Oddometer: 3,571
Bluhduh Damaged Sheetrock painting question
Boys and girls who like to play with paint and sheetrock, please help...
The Mrs hinted (about 30 times) her desire to redo our bathroom. Being a good listener (yeah right) I jumped right on it, ripped the ceramic tile floor, and yadi, yadi, yada...
Anyway, there were some things attached to the walls with a combo of fasteners and adhesive. Said adhesive did such a good job at sticking, that it ripped some of the sheetrock paper off
Not completely to the gypsum board, but the brown paper is exposed. I went around with a razor blade, cut little shapes out around the damaged areas, removed all loose, peeling stuff. Stuck with the brown paper for now. Okay, two local hardware stores told me to mud the brown paper with a skim coat, sand, skim again, sand, and prime. I was going to prime, then skimcoat, then prime again but for some reason I listened to those guys. So, with a thin, thin coat of joint compound, there are places where the brown paper likes to suck in the moisture and bubble up. Hooray! No, not really.
So, how do I deal with this situation, where there are a few small spots, and a couple of big spots (like 2x2ft) of brown paper? cutting and replacing the sheetrock is not an option at this point. Thanks
henrymartin is offline   Reply With Quote
Old 06-26-2012, 09:11 PM   #2
D.T.
Up in this MF'er!
D.T.'s Avatar
Oddometer: 10,984
BTDT.
I'd keep cutting back the paper until the B.S. stops. Keep on keepin' on with the joint compound. Thicker and thicker if needed.
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 06-26-2012, 10:35 PM   #3
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,583
When sanding between the coats.... just knock the lumps off... make sure you dont sand into the paper or just find a good drywaller.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 06-26-2012, 10:37 PM   #4
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,075
Cut back the bubbles, seal with an oil based primer, coat with hot mud, then all purpose or topping compound.
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Old 06-27-2012, 06:01 AM   #5
roger123
roger123's Avatar
Oddometer: 1,600
Sorry to hear about the bubbles, I had the exact same problem and the only thing I could do to get the bubbling to stop was rip out and install new drywall, good luck!
Roger
'07 Wee Strom (For Sale)
'14 Tenere ES
COG 5903
roger123 is offline   Reply With Quote
Old 06-27-2012, 06:05 AM   #6
mcma111
mcma111's Avatar
Oddometer: 12,099
I always use oil based primer on new or repaired sheet rock. Need texture? Paint effected area with a thick coat and then stab the brush around and you have texture.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-27-2012, 07:59 AM   #7
squiffynimrod
maximum shrinkage
squiffynimrod's Avatar
Oddometer: 1,369
The brown paper is a form of kraft paper, it's normally laminated to the face paper which is a much higher quality paper. The quality of the kraft paper has been decreasing as the amount of recycled paper vs. virgin paper has increased.
The kraft paper is highly absorptive compared to the face paper. Drywall mud can contain lots of water depending on which brand/ product. High moisture content + absorptive paper = bubbles. Better off to cut right through to the gypsum core. The fact that you were given wrong information doesn't surprise me.
Normally, unpainted drywall is not sealed with oil based products. The extended dry time will cause the "hair" in the face paper to raise up causing a rough surface. It's usually water based sealers for a really fast dry time.
Your case is different. You could oil prime the kraft paper to seal it off, because you're going to bury it in mud. This will work, but you've got a longer dry time to deal with. A good alternative would be a pigmented shellac (Zinnser BIN or similar).
Alcohol based, dries quick. May take a couple of coats as the paper's going to be sucking it in.
Posting all the bikes you have or have owned in this spot is stupid.
squiffynimrod is online now   Reply With Quote
Old 06-27-2012, 11:15 AM   #8
henrymartin OP
Mr. Tourguide
Oddometer: 3,571
Funny you should mention that. I hit the trouble spots with the BIN just before I read this. Now it's time for more mud
Old 06-27-2012, 12:39 PM   #9
ericrat
Oddometer: 1,189
I've switched
I have switched to the dry powdered mix type of compound for around the house repairs. It is SO MUCH BETTER. I suspect this is what the poster above was refering to as "hot mud". For a problem area like that, you can reduce the amount of water in the mix (the chart in on the bag) and use warm water. Mixed like that it will set up in minutes with very little water available to soak up into the substrate.
Eric
Have you visited ride reports lately ?. click HERE
ericrat is online now   Reply With Quote
Old 06-27-2012, 02:07 PM   #10
LexLeroy
Aging Gracelessly
LexLeroy's Avatar
Oddometer: 2,137
Eric
+1 on the setting vs. the drying type of joint compound. The drying types have always shrunk and bubbled for me - then I discovered Durabond 90. Low shrink rate, stickier than a booger on your finger - just be sure to get it where you want it and then clean your tools off quickly. After it sets it's an absolute bitch to sand or scrape down. Once it's set apply your topping compound, prime w/ Kilz and you should be golden.
"They're smarter than you son... that's why they're the police."
LexLeroy is online now   Reply With Quote
Old 06-27-2012, 03:31 PM   #11
Wired
Oddometer: 301
Personally, if this was a bedroom you would probably be fine. With it being a bathroom I would cut the area between the studs, replace with the proper green board, tape, mud, primer, and paint. Do it right the first time and be done. You've already messed with this for a bit. Even if it does work for now, it's probably not as good as starting over and doing it right. In 2, 4, or 6 years down the road you might have to mess with this again to save time now. How long are you planning on staying in this house? If it's awhile, do it right.
Wired screwed with this post 06-27-2012 at 03:54 PM
Wired is offline   Reply With Quote
Old 06-27-2012, 03:38 PM   #12
ragtoplvr
Oddometer: 6,163
+1 for the green board, you can be finished in less time than messing with salvaging the white board, and have real actual water resistance.
Rod
ragtoplvr is online now   Reply With Quote
Old 06-27-2012, 03:59 PM   #13
gplane
Brush With Destiny
gplane's Avatar
Oddometer: 881
Pigmented shellac on exposed paper-hot mud-topping-sand-prime-paint.
gplane is offline   Reply With Quote
Old 06-27-2012, 05:06 PM   #14
frogy
frogy's Avatar
Oddometer: 811
+1 here.I do maint. at Assisted Living facility (read lots of wall damage with walkers),the fast setting powder is a dream if you work fast,if you dont,yell you gots a lotta chippin ta do.
frogy is offline   Reply With Quote
Old 06-27-2012, 07:31 PM   #15
squiffynimrod
maximum shrinkage
Oddometer: 1,369
Ding! Ding! Ding!
Times are GMT -7.   It's 11:06 AM.
