06-30-2012, 12:13 PM
#46 |
NW adventure rider
Oddometer: 16
For me, the decision to switch from F8 to the 990 came down to the cost/benefit calc. I believe the KTM has a better suspension to start with but as I said earlier, I have "fixed" almost every bike I have ridden. To me this is a normal part of setting up a bike to match my size and ability and intended use. I also expected to add normal thing like bash plates and crash bars bla bla bla to both bikes. I own a new Husaberg and joke about it being KTM's expensive cousin... Point is the parts for both bikes are spendy for OEM / hard parts. After market seems comparable too.
All that said, I choose the F8 originally because I expected to do more road ( dirt and pavement) on this bike and use the others for more hardcore dirt riding. I mean come on, it weighs almost double a good dirt bike! And you would spend an extra $7000. In my estimation ( and a lot of the reading I did prior to purchase) the BMW had the advantage on the longer road trips, thus I bought it. No dealer in my area would have been cool with a fast run thru the desert as a test ride so I found the limits of the bike after paying for it. I love this bike on the roads. I also have a K1200 LT fully loaded ( the wife likes a comfortable ride) and I prefer to take the F8 unless it's a 2 up ride. I like the bike in the dirt. The solution, for me, is upgrading my way to " loving " in the dirt as well. Bottom line, you will spend money on any ADV bike you buy unless the guy you buy it from has already done the work. I figure the difference in stock bike price gives me a pretty big cushion to get the Beemer up to speed off road and I still have the on road advantages... IMO.
'11 F800GS '11 Berg FE390 '06 YZF250 (anniversary edition) '00 BMW K1200 LT (loaded) |
06-30-2012, 04:43 PM
#47 |
Ridin' in MT
Oddometer: 978
It seems to me, that if you want a dirt bike in this engine size class, you go with a KTM 950SE. Otherwise you live within the limitations of a large ADV touring bike. The F8GS is smaller than the R12GS and that class, but larger than the 650's. You can strip a F8GS down and make it more dirt worthy or set it up to be more road worthy depending on the rider. The option not discussed in this thread, is building your own bike like JDRocks did.
Why the hell would you ride a bike that loads out at 750 lbs at reduced tire pressures? For me the necessary changes from stock are as follows: Engine guards - they protect your radiator, my radiator is running with broken brackets from a 15 mph tip over on ice. Sargent Seat - makes 500+ mile days possible Hand guards - protect your levers TKC tires (or other offroad) - they look cool, and work reasonably well on gravel roads saddle bags additional fuel tanks Bash plate Mods that didn't pan out: Ohlins shocks and cartridges - not that they are bad, just beyond my skill level. Tourtech HID light - get the cheaper LED lights
'07 VFR800, '09 F800GS, 07 CRF250X Riding roads in Montana - Big Sky Country www.mtrider16.smugmug.com Alaska Trip Report |
06-30-2012, 09:16 PM
#48 |
Oddometer: 1,116
Put as simply as this:
I bought mine 2nd hand, the PO (an older gentleman) hadn't even reached the first service in 3 years, but had it serviced annually anyway. He traded it on a new one. I got it for 2/3 the price of a new one. In Aus$ terms that gave me nearly $7K to spend on "farkles" before I hit new price. I understood at the time I would spend money on suspension and racks, screens, crash bars, bashplates etc. The suspension didn't have the solutions I thought it had from my on line research, using this forum for starters. It looked like there were lots of front end options starting to make an appearance, and people on here who were praising them. Then, right after I bought mine, the failures with the Bitubos and others started to appear in these pages. So my suspension budget has blown out. The Ohlins didn't come set up for 2-up riding as I ordered it, and revalving and several resprings cost me more than I was prepared for. So I'm bitter and twisted. Shit happens. I'm over it. For someone coming into a F800 for the first time I think you need to allocate a budget, read very carefully, and then do the mods you want. It may not be the bike you thought when you finish. It's a very personal thing, so you need to think logically and remove emotion from it before committing. If you buy one, and set it up, and then don't like it...what then? Have a clear understanding of what you want to do with it. Not just what you "think" you want to do with it. |
06-30-2012, 10:27 PM
#49 | |
Gear addict
Oddometer: 574
I find this generally quite true, particularly the "personal thing" idea. I thought the Ohlins suspension was well worth it for me, for MTrider16 apparently not so much. You win some, you lose some. I don't sweat it too much because I like screwing around with my bikes. And lots of the advice here is worth exactly what you pay for it.
Dan 2010 BMW F800GS, 2011 Yamaha WR250R, 2011 Honda Ruckus, 2013 KTM 500 EXC Up the WABDR, F800GS Stealth Bike Build, WR250R Scotts Damper Install Red dirt, rocks and sand; Riding the southern UTBDR |
07-01-2012, 03:21 PM
#50 | |
Ridin' in MT
Oddometer: 978
It seems like the OP thinks there is a list around, that you "have' to do. All you "have" to is buy one and ride it. However, a marriage analogy would work well here. If you didn't like the KTM, which is in the same class of bike as this F8GS, what has changed this go around that makes you think the F8GS will work better? And as you are the common denominator in both relationships, this is a personal question that only you can asnwer. David
07-28-2012, 05:01 AM
#51 | |
Oddometer: 135
2 months ago I notice an F800GS same colour 100 meters down my house. He had all the goodies on the bike. Hepco bars, cases, fog lites hyper pro front and rear, and more. I left a card. We ended up calling each other and leaving messages. Than the bike disappeared from the side of the road. 1 month ago a friend has asked my opinion about F800GS. He found for sale the same colour etc.. Yes it was that bike. So he bought it and paid minimal price for all the goodies. Lucky him..... ![]() So if you finf the bike where somebody took all the TIME and MONEY to get the goodies assembled, buy it will you? Regards |
08-15-2012, 12:43 PM
#52 | |
Oddometer: 2
www.Humvee-Graphics.com |
03-17-2013, 04:09 PM
#53 | |
Oddometer: 37
03-17-2013, 07:56 PM
#54 |
Oddometer: 100
48mm fork conversion....
![]() I love my bike.
'13 F800GS |
