Old 06-28-2012, 12:20 PM   #1
LillaMan OP
n00b is okay by me.
LillaMan's Avatar
Oddometer: 36
F650GS Front Wheel Removal
Hello,
I have a 2010 F650GS and I want to install the fork gaiters I bought from Wunderlich.
I have two questions for you all:
1) From experience, what is the best way to suport the bike (before removing the front wheel)?
2) Is there enough ground clearance, with the wheel removed, to drop out the forks?
I have a center stand, but unlike the boxers I've owned, the F650GS feels REALLY front heavy. I assume that I can't just remove the wheel and expect the bike to balance on the rear wheel and center stand.
I look forward to your feedback.
Jay
Don't fear your ignorance - live it, embrace it, write about it.
An American copywriter in Sweden
LillaMan screwed with this post 06-28-2012 at 12:22 PM Reason: Difficult to read with the blue
LillaMan is offline   Reply With Quote
Old 06-28-2012, 01:07 PM   #2
Pomo
gonzo
Pomo's Avatar
Oddometer: 611
1:
If you're in the garage, use a jack stand or a car jack to support it under the skid plate (or jam a piece of wood between them to protect the oil pan if you don't have a skid plate). You can also use ratchet straps to torque the rear of the bike towards the ground if you have a suitable anchor point.
In the event you have to pull it off "on the trail", just dump the bike on its side. Or use one of the above methods with a big rock.
2: I believe there is, though it may be a little close. All I did when I installed my Bitubo's was to stuff a few cinder blocks under my skid plate and pulled all the stuff off of the front without too many issues. I have an F800 rather than the 798, but I don't think the triples are that different.
Stubborn and Stupid
"It's supposed to be a challenge, that's why they call it a shortcut. If it was easy it would just be the way." ~ Rubin, Road Trip
Pomo screwed with this post 06-28-2012 at 04:02 PM
Pomo is offline   Reply With Quote
Old 06-28-2012, 09:09 PM   #3
Dadayama
Constant Adventurer
Dadayama's Avatar
Oddometer: 589
When i took my forks off, i put bricks under the engine (skid plate) with the bike on its center stand. Removed forks and did work with no problems.
Ich Fahre Nicht Zu Schnell, Ich Fliege Nur Niedrig
Oklahoma Adventure Trail
YouTube
Dadayama is offline   Reply With Quote
Old 06-29-2012, 02:07 AM   #4
LillaMan OP
n00b is okay by me.
LillaMan's Avatar
Oddometer: 36
Responses
Thanks for the responses. I will try my luck this weekend.
Old 06-29-2012, 02:16 AM   #5
tkent02
Oddometer: 2,378
I find it safer to hang the front from above than to stack stuff under the front. It can't tip over as easily. Piling stuff on the back to keep the front up is second best.
tkent02 is offline   Reply With Quote
Old 07-01-2012, 10:17 AM   #6
LillaMan OP
n00b is okay by me.
LillaMan's Avatar
Oddometer: 36
The job is done
I installed the gaiters this afternoon.
Pretty simple actually. Took about an hour, most of the time was spent reinstalling the bodywork that I had removed when I installed the bar risers. Hopefully this mod will increase fork seal service life.
Here is the result:
Times are GMT -7.   It's 04:18 AM.
