Old 06-28-2012, 08:38 PM   #1
kawzak OP
Oddometer: 38
New ural patrol
I brought home a new Ural Patrol tuesday. What a beauty ! White w/black trim. going over everything.rode it a little, have less than 100 Kilometers. I am checking everything over first. Runs kinda doggy, but I am sure that will improve. plugs looks gray/light tan, so carb jet/mixture is close I think. still figuring out the timing. checked all fluids,I know about the importance of the break-in period. Did yours run much/lots better after some miles put on it?
kawzak is offline   Reply With Quote
Old 06-28-2012, 08:52 PM   #2
eastbloc
comprador bourgeois
eastbloc's Avatar
Oddometer: 1,356
Yes. They run much better after they are broken in.
The best running Ural I ever had was a lowly '95 650 with almost 50,000km on the clock. It ran almost as smooth as my BMW R60/5.
eastbloc is offline   Reply With Quote
Old 06-29-2012, 05:30 AM   #3
Thermos
Thermos's Avatar
Oddometer: 240
How about some pics?
-T
Thermos is online now   Reply With Quote
Old 06-29-2012, 06:34 AM   #4
cycleash
Oddometer: 3
Waiting for pics!
cycleash is offline   Reply With Quote
Old 06-29-2012, 08:37 PM   #5
kawzak OP
Oddometer: 38
New Ural Patrol
I have to figure out how to post pictures. It is a 2012 white patrol. so far I retorqed heads, adjusted valves, corrected timing, synced carbs,checked all nuts/bolts, changed rear unit lube, greased side car axle u-joints/drive shaft splines (cant get my grease gun fitting onto driveshaft u-joint), fixed sidecar swing arm noise,tire psi, went through about everything.got rid of most squeeks. It runs pretty good now. only have about 130 km as of tonight. Plan on riding tomorrow with my wife. so far I love it.
Old 06-30-2012, 03:31 AM   #6
BeeMaa
Hack Pilot
BeeMaa's Avatar
Oddometer: 1,098
Pic Posting
Check this out.
http://advrider.com/forums/showthread.php?t=919
Then find one of the "test" threads and give it a try.
Good luck, welcome to the asylum and congrats on the new outfit.
Eric B
'06 R12GSA/Hack & '10 R12GSA
An armed society is a polite society. Manners are good when one may have to back up his acts with his life. Robert A. Heinlein
BeeMaa is offline   Reply With Quote
Times are GMT -7.   It's 10:10 AM.
