Old 02-12-2013, 11:12 PM   #16
dnrobertson
Big Bike, Slow Rider
Oddometer: 794
Originally Posted by rmhrc628 View Post
Can you please tell me how to read that manual ?
What do the letters mean?
They tie in with the connector codes in the official KTM wiring diagrams.
eg on the 2005 640A, the rear taillight uses a AJ/BG combo (male/female).
David
2005 KTM 640A
2008 Wee-Strom
dnrobertson is offline   Reply With Quote
Old 02-13-2013, 01:45 PM   #17
h2oplayer
h2oplayer's Avatar
Oddometer: 36
Female plug
Can you guys help me locate where if this ktm connector is molex and where I'd get the connector and pins from for the female side?
It's from the Cev switch block
Here you go $2.70 including socket pins
http://shop.vetcosurplus.com/catalog...oducts_id=9655
Don - Gig Harbor, WA
GTR1400
CBR1100xx
LC4 six days
Some of my past rides
GSXR1000, FZ1, ZX-10, CBR1000F Hurricane
Sabre V65. CB1100F, CB900F, CB750F, CB750K
Kawasaki 750 H2 Triple, RD350 and RZ350
YZ250F, KDX200, Elsinore MT125
h2oplayer is offline   Reply With Quote
Old 02-13-2013, 02:10 PM   #18
rmhrc628
rmhrc628's Avatar
Oddometer: 2,536
H2o you are a legend !!
I owe you a beer. Next time you're in Australia look me up.
Cheers mate really appreciate it.
I'd like to get the special tools as well to properly crimp and remove pins when needed.
rmhrc628 is offline   Reply With Quote
Old 02-13-2013, 05:06 PM   #19
h2oplayer
h2oplayer's Avatar
Oddometer: 36
I might just take you up on the beer later this year if all goes well.
If you were a little closer I would lend you one of my crimpers. Here is a link for a decent open barrel crimper that will work on a wide range of connectors and wire gauges. http://www.mouser.com/ProductDetail/...FQhxQgodpC4AlQ It should be reasonably priced as well.
I do alot of custom harnesses and it gets expensive if you are buying the OEM crimpers, some of my crimpers are $500 plus.
GTR1400
CBR1100xx
LC4 six days
Old 02-22-2013, 06:07 PM   #20
rmhrc628
rmhrc628's Avatar
Oddometer: 2,536
Can you guys help me out with some Ktm switch specifics.
I have a Baja designs dual hid lapaz headlight to install. They currently have toggle switching on the light frame but I want to move the switching to my eu ktm exc switch block.
The hids are 35 watts each.
Do I need to run a relay to switch these lights on? I plan to have lo beam as the spread light and high beam will be both lights on.
This is the switch I'm using:
Old 02-27-2013, 04:07 PM   #21
h2oplayer
h2oplayer's Avatar
Oddometer: 36
At 35 watts that works out to just under 3 amps each at 12 volts. Running both at once puts you at 6 amps plus any line loss. The switch would most likely handle this as long as the contacts are kept clean; these switches are not well sealed. As soon as you start to get dirt or corrosion going on the resistance of the switch will go up and so will your amperage/draw. A relay would be a safer bet as you would lower the load on the switch and most automotive type relays are better sealed from the elements.
GTR1400
CBR1100xx
LC4 six days
Old 02-28-2013, 04:17 AM   #22
rmhrc628
rmhrc628's Avatar
Oddometer: 2,536
Legend Thankyou for your response.
Back to eastern beaver.
Times are GMT -7.   It's 09:09 PM.
