06-29-2012, 11:26 AM
#1 |
Oddometer: 556
Super Tenere vs. '12 Wee-Strom Adv: Why?
Nevermind. Just found a gazillion threads on this topic.
To sum up Tenere = faster + better offroad, if you have the $$$
Current: BMW Sertao "Gizelle" Past: 2012 Super Tenere, 2009 WR250X/R, 2004 Triumph Tiger 955i, 2009 KLR 685, 2006 DRZ400S, 2006 TW200, 2001 KTM 250 EXC Gundy screwed with this post 06-29-2012 at 11:46 AM |
12-19-2012, 09:11 PM
#2 |
Oddometer: 147
After extensive research I have narrowed it down to 2012 dl650 or 2012 ST for long range touring. I plan on New orleans to yellowstone next year on the new bike. Since this thread was originated but never went anywhere, I actually have some very specific questions regarding these two bikes.
The goal is long distance touring comfort 1up with limited luggage. Likely a lot of highway miles. I'm not after passing power or off road capabilities, which is mainly where the tenere seems to outperform the dl650, from what I read. So... 1) Given that I could care less about power and off road capabilities, does it seem practical/necessary to spend x2 on the tenere or will the dl650 will be nearly the same for my intended use? Or might the tenere have specific features that will be a big improvement over the dl650 for touring? 2) Is there anything I should know about either bike that becomes unbarable after several hundred miles (besides the seat) The only dealer in my area that sells these models does not allow test rides . Sitting on both isn't much help as they feel pretty similar in terms of ergos. The x2 cheaper price on the dl650 was skewing my decision but then I thought I should look the other way and just buy the tenere just to be on the safe side... I just don't know what to do... ![]() A little backround on me. I'm 6ft tall, 34in seam, 180lbs. I have never owned a sports tourer bike or even a sports bike ( I can't stand crotch rocket seating position b/c of too much knee bend). I come from a cruiser (currently own suzi M50 and a Victory Hammer), but have realized that I wouldn't want to do 1000+ mile trip on either of my current bikes. I bought the Hammer without much research and realized it's too big, bulky, heavy and just plain too damn much bike. Way more than I need and It doesn't do anyting my m50 can't do, besides burn more gas. Hope you guys understand where I'm coming from and can shed some light in this dark tunnel. Gundy: why did you settle on the tenere over the wee? MariusD screwed with this post 12-19-2012 at 09:21 PM |
12-19-2012, 09:40 PM
#3 |
Oddometer: 1,976
If you need a big engine the S10 is probably the best of the bunch.
If you don't need a big engine, the DL 650 is the best of the small engined bikes - and (I'm biased) the DL 650 is probably 'more better' compared to it's close rivals than the S10 is compared to it's competition. Ergo's, you can get a taller seat for the 650, but it's probably less cramped than the S10 for a tall rider anyway. Not saying the S10 is a bad bike here, I'd pick an S10 over a DL 1000 or 1200GS any day :), but the S10 and DL 650 will do the same job with about the same effective performance and comfort, one just happens to cost half what the other does. I'd say your research has hit it dead centre, but you just don't believe the results ? ![]() Pete |
12-20-2012, 12:24 AM
#4 |
Oddometer: 1,316
2012-> Wee's stock seat doesn't really suck nowhere near as bad as the 2004-2011-models seat did. Even some journos haven't noticed they're very different. But it's still up to the individual, how it'll fit you (as always).
If you don't care about lotsa power, and ride 1-up, I think the Wee gets the job done quite nicely. (Actually for me it even does this 2-up, but not everyone shares my view). And for long distance it's nice, that it gets better mpg than bikes having nearly double displacement. Not saying the S10 isn't a great bike, though. Buying on a budget, the choice still seems quite obvious. Too bad you can't test ride them, cos it's pretty hard for others to tell you, which one's the best for YOU. Pecha72 screwed with this post 12-20-2012 at 12:38 AM |
12-20-2012, 03:37 AM
#5 |
Oddometer: 253
If you look at them as tools for a job they'll both get you through your trips just fine. Main things the S10 adds is more power, traction control and shaft drive and better fit and finish. Haven't sat on a 12 Wee but have had 2 earlier models so can't speak for the seat on the 12 but the earlier Wee seats suck and the S10 seat is to me very comfortable. As stated above, YOU really neeed to find a dealer and ride both to see what you prefer. I prefer the S10 over Wee for power, comfort (for ergos only mod was bar risers), shaft drive etc. At 6'6" I'm not comfortable on a lot of bikes but the S10 works for me. S10 also feels less top heavy to me as they carry their weight lower IMO. Good luck in your search, let us know what you decide.
12-20-2012, 06:27 AM
#6 | |
Oddometer: 147
Appreciate the input everyone!
Frankly your answer surprises me. And you're spot on that my "research results" confirm what you say. I admit I am a bit skeptical still. Chain vs shaft also doesn't particularly worry me much. I guess the things that would make a big difference to me between the bikes are as follows: 1) Vibrations (less is better) 2) Suspension smoothness on the highway and over bad roads (roads where I live are awfull! Including the highways) I'd like the bike to be able to soak up the road as much as possible without transfering the vibes of poor pavement to the rider. (this is really a big deal for me!) 3) Wind protection If the two bikes are nearly identical in these respects then it's the 12 vstrom adventure that will end up in my garage. If the tenere has a meaningful advantage here, then I might have to spend the extra $. I realize a test drive is the best way to find out, just not looking forward to driving several hundred miles to another dealership. I'll do it if I absolutly have to, it's just really helpful to see if you all might have a consensus on how these two would compare when you take off-road abilities and power out of the picture and focus purely on comfort, road absorbtion, and wind protection for long distance trips. MariusD screwed with this post 12-20-2012 at 09:19 AM |
12-20-2012, 07:03 AM
#7 |
Oddometer: 501
To your point 2: It sounds like you are off-roading anyway, only on-road.
I would imagine the more off-road capable ST would be much better at isolating the rider from road imperfections. |
12-20-2012, 07:08 AM
#8 |
Oddometer: 155
With the 2012 dl650 adventure if you add a custom seat and a Madstad windshield bracket and new shield you should be good to go anywhere. Also a skid plate to protect the oil filter. Even if you only stay on road.
Jon Kohler sent from my iPhone
Jon Kohler Colbert, GA 2012 VStrom 650 Adventure IBA# 24562 |
12-20-2012, 07:19 AM
#9 |
Oddometer: 1,175
Keep in mind that some people have wind buffeting issues with the DL650. Not to sure how well the 2012 model addressed that issue. Lots of riders purchased multiple screens in an attempt to resolve buffeting as well as many riders have no issues with wind at all. So, while testing a bike may be a pain it is advisable as a sizable investment is at stake.
12-20-2012, 07:23 AM
#10 | |
Doesn't Care
Oddometer: 1,516
Ergos and fit and finish are nearly identical between a 2012+ dl and an s10. I've had my eyes (and my ass) on several units of each over the last few months, and I've seen scratched tanks in both cases :(
the s10's screen is out just a touch farther in front of a rider. Prices for leftovers are closer to 50% more for an s10, not quite double. s10 has F-you power, the dl doesn't relative to other bikes but will still smoke 95% of cars out there (this is based on an 09, the 2012+ is just a touch better in terms of power). To me, leaning the s10 felt... weird, but no weirder than any "new" bike. If I could have either bike entirely pre-farkled for free right now, I'm still not sure which one I'd pick. In the end neither is enough of an upgrade to my k9 wee to make it worthwhile (right now). I have high hopes for a new DL1000 in the coming months that might split the difference in terms of power and cost (though if suzuki follows the trajectory of the old DL, it might not really be down that much in power from the s10), will make the decision to side-grade easier. Quote:
All reports are that buffeting on the 2012 wee isn't an issue - it seems that most people end up comparing recent bikes to the pre-2012 DL650.
--Semantics are everything. |
12-20-2012, 08:19 AM
#11 |
Unpaved road avoider
Oddometer: 889
I put a Russell seat and a Madstad screen and mounts on my 2012 DL650. With those additions for well under $1000, I believe under $750, there are no comfort issues remaining. Some have reported vibrations with crash guards so I went with sliders.
Pat in order of ownership 1971 Honda CB350, 2 1973 Honda CB500s, one was stolen, 1974 Can-Am 175 TNT, 1978 Yamaha XS11, 1978 Honda CX500, 1975 BMW R90S, 1983 BMW R65LS, 2005 Suzuki DL650 totaled, 2007 Suzuki DL650A, 2012 Suzuki DL650A |
12-20-2012, 08:40 AM
#12 |
Just say NO to socialism!
Oddometer: 2,785
I own a Wee. Several years ago I had the opportunity to spend a day on an S10. before they were imported. I was overseas, and had never seen one before. The S10 had 3km on it when I got on it. Imediatley i loved it. After a while I found the fuel mapping was poor, it stumbled off the line often. Again, it wasn't broken in yet. The next thing I noticed was the gearing. I had to feather the clutch A LOT in traffic, had to slip it A LOT off the line. You said you don't do off road, but when you head out west, there are lots of places where a county/gravel/mild Jeep road will get you in to things you might not want to miss. Both will do that, but the high gearing and unable to change the gearing with shaft drive were an issue to me. When I first started on the S10 I thought, I want one of these. After spending the day on it, i was conviced i didn't want one. The reasons were the price/,gearing. I couldn't justify the price. Not enough EXTRA bang for the buck. And the high gears, for what i do with it would not work. Great bike for sure. I often ride with a guy who has a GS1100 Adventure, it's geared nicely, better than the Wee, the F800 is too.
If I was doing lots of interstate type cruising or higher paced highway, the S10 would be great. |
12-20-2012, 09:26 AM
#13 |
Oddometer: 17
Dont forget that if you do go with the Wee, you will be saving a lot of money that could be used to upgrade whatever you feel is slacking with money left over. I am in the same boat except for some reason i have a f800gs on the list also even though i know maintenance will drain my wallet.
12-20-2012, 09:35 AM
#14 | |
Doesn't Care
Oddometer: 1,516
12-20-2012, 09:54 AM
#15 |
Desert Rat
Oddometer: 994
Can't speak to the s10, as I've never ridden one. The Wee will get you where you need to go with plenty of power and great mpg. I tour 2up on my wee all the time with no issues. That means at 270 and my wife at 130 and all of our camping gear. If I were to chose the s10 it would be for the better suspension, with more travel, and higher ground clearance.
If all you ever do is all you’ve ever done, then all you’ll ever get is all you ever got. http://advrider.com/forums/showthread.php?t=851060 ... A desert rat explores the south. |
