09-29-2012, 01:15 PM
#616 | |
Procrastinators
Oddometer: 5,789
So I attach the Battery Tender/SAE cable right to the battery, and use a three way lighter outlet splitter with the SAE connector on a two foot long cable, and when I plug my iPhone or Scala charger into the splitter, I put the whole kit into my tank bag to stay safe and dry. I do have a separate cable for my gps up near the handlebars as well. Both my own and my wife's bikes are set up this way. It gives us a lot of flexibility in what we can plug in...
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
09-29-2012, 01:40 PM
#617 | |
barko1
Oddometer: 2,512
works with stock switch but I mounted another switch on the inside of the heaflight shroud
DR650, 98 Bimota SB6R, Kawasaki 14, 67 X-6 Scrambler (apart), SL350K1, 77 Goldwing 1000, V11 Rosso Mondello Guzzi |
10-02-2012, 07:07 AM
#618 |
Oddometer: 61
Do you have a picture you can post showing the wires you tied the switch into, and how you mounted it on your shroud?
Thanks! |
10-02-2012, 09:16 AM
#619 |
fNg
Oddometer: 779
i initially installed the big groovy HDB top clamp & power & switches & doodads, but really all that just became a hassle to use.
my current setup on both bikes is simply a battery tender dongle hanging on the side of each and an assortment of adapters to plug in stuff, like GPS power, cig lighter, jumper cable setup, etc. i came to realize that less is more in this case.
2006 DR650SE, daily commuter + a StripleR and a bunch of 2 strokes that you dont want to read about. :) http://www.advrider.com/forums/showthread.php?t=829203 |
10-02-2012, 10:07 AM
#620 | |
Tainted Slunt
Oddometer: 655
I don't know about turning off my headlight - I think law says I have to run one even during the day. (I wish the DR had the alternator of the KLR!) |
10-02-2012, 12:14 PM
#621 | |
Oddometer: 458
A couple of photos of my DR setup... ![]()
10-02-2012, 03:04 PM
#622 | |
barko1
Oddometer: 2,512
Here is a picture, on the left side where I can switch it if need be when riding. When the switch is off there is no light at all, when the switch is on the high beam is on if switched to high. I guess if I ever got pulled over for not having a light on I could say my low beam burned out. I like being about to switch it off like when in the garage, starting, or on dirt but staying warm. The switch is a flat rocker with three prongs on the back but I used only 2, can't see what I connected to )-: Just drilled a hole for the switch in the support part of the shroud above and forward of the screw on that side.
10-05-2012, 06:47 AM
#623 |
Nobody Home
BergDonk (Steve) is making counter-shaft seal retainers. His first production run is complete and spoken for. I would like one and if 5 others are interested, I'll be point man for another 6 units.
I am not going to require any up-front money as long as your word is good. The price will be $40 for the retainer plus a portion of what it costs to get them from Oz to the US and then from me to you. I would imagine ~$50?
There are some simple thruths......and dogs know what they are - Joseph Duemer Andy holds the lead. And he will, all the way to the Highway. Today is his day. Bronco638 screwed with this post 10-05-2012 at 12:34 PM |
10-05-2012, 07:18 AM
#624 |
Oddometer: 227
Cool, how much are these?
05 DL650 |
10-05-2012, 12:35 PM
#625 | |
Nobody Home
There are some simple thruths......and dogs know what they are - Joseph Duemer Andy holds the lead. And he will, all the way to the Highway. Today is his day. |
10-05-2012, 01:51 PM
#626 |
fNg
Oddometer: 779
look into the stator mod, basically you change the wire arrangement of the stator and increase the output by alot. and you'll get more available power output at lower RPMs.
10-05-2012, 03:38 PM
#627 | |
Oddometer: 2,551
Procycle: Peak voltage is down about 1 volt. The stock stator makes peak voltage right around idle. The modified stator makes its peak voltage at around 2000 rpm. If you're stuck in traffic or idling along on a slow trail shut off the extra lights, heated vest, etc. or you may drain the battery. From here, post #7: http://www.thumpertalk.com/topic/755...7#entry7722957 |
10-05-2012, 05:16 PM
#628 |
Procrastinators
Oddometer: 5,789
I'd put my name in for 2, to Canada. Sent a PM.
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. Emmbeedee screwed with this post 10-06-2012 at 05:23 PM |
10-06-2012, 05:18 PM
#629 |
Oddometer: 920
Ditto on 2 - PM sent. I usually bulletproof my son's DR as I do mine. Around 50 each is good for me.
www.dualsportmoto.com 2005 DR650 2013 HD Road King "It's a small amount of gas, but it represents a long walk" My Dad... |
10-06-2012, 05:59 PM
#630 |
Oddometer: 27
Retainer
PM sent. I'm good for one.
