11-10-2012, 03:33 AM
#721 |
Hooked Up and Hard Over
Oddometer: 7,563
Also if your just changing the tires and not the tubes dont take them out. After you have the top bead off simply stuff the deflated tube under the brake disc and remove the bottom bead of the tire. Take your new tire and place it over the tube where the stem is still in place. Spoon on the the rest of the bottom bead. Add some air now to tube and place it back in and finish tire install. No need to remove tube and deal with the stem. Saves time and fingers. Lol
Sent from my SCH-I800 using Tapatalk 2
Frank Reinbold "Every bike I ever had, was the best bike I ever had, when I had it" *2010 FOREVER WEST* NEW ENGLAND AND CANADA OFFROAD F800GS 14 DAY IDAHO ADVENTURE KTM 950 TRANS AM TRAIL WEST TRANS AM TRAIL VID CLIP THE DEAN OF WESTERN ADVENTURE ROUTES |
11-10-2012, 06:33 AM
#722 | |
Oddometer: 56
11-10-2012, 06:42 AM
#723 | |
Oddometer: 56
Airing up the tube helps it to not pinch and twist on the bead as well. Just like a bicycle.
11-10-2012, 09:21 AM
#724 | |
on the road o'dreams
Oddometer: 5,505
![]() ![]() Thanks for the excellent tutorial on the Zip ties. I'd heard about these but have only used them to hold a flat tire on the wheel when out in the middle of nowhere. Never used them to mount a tire. I'll have to try it. Seems it would make sense to carry the Zippies on the bike with you, as a roadside flat would go easier using them to remount. Are they hard to pull out once tire is mounted? How many Zippies are used in all? Seems like at least 3 ? I'm thinking these Zippies are very heavy duty? Do they have a gauge number or anything? Thanks again!
11-10-2012, 09:48 PM
#725 |
Oddometer: 617
Zip-Ties for tires
Here is a picture
![]() I had already removed a couple zippies when I thought to take a picture, They slip right out, no trouble at all. This is the front tire that i did first, I used even more zippies on the rear since I had them, the are quick and easy to install and remove, and the brand new rear knobbie has a VERY stiff carcass. The beads did not want to pull together. I think i could ride 100 miles with a flat, no problem. ![]() The package of zippies says on it: 18" Heavy-Duty Cable Ties 5" max diameter 175 lbs GB (Gardner Bender) brand that I picked up at Lowes electrical department. There are 15 in this package. I agree that they would be an excellent addition to the on-board tool kit. They don't weigh anything and are very handy. I just put as many on as seemed beneficial. I don't think you could use too many and I don't know what a minimum might be. Enough to keep the two beads together I would say. I placed my tire tool so that it was bearing against the zippie as it is more slippery than the rubber tire. No idea if that made a difference or not. In the picture you can see the zippie I put around the tire and rim to keep it down in the well by the valve, You can just make out the end of the valve stem with the nut on it.
Attitude ~ The difference between Ordeal and Adventure James |
11-11-2012, 09:51 AM
#726 |
Oddometer: 5,505
Perfect, thanks for the pic. Tells the whole story.
I have a tire change coming up ... will report back on this.
11-17-2012, 03:44 AM
#727 |
Oddometer: 13
anyone reading the rubbish from jonkol in the usual dr thread
![]() some people...
11-17-2012, 08:17 AM
#728 |
Oddometer: 617
Flexy Flier Frame
Yep.
I sure am glad I don't have a flexy frame DR. ![]() Too bad his does. ![]() Good thing he is the only one... ![]() I guess the rest of us happy DR riders are ignorant of this serious design flaw that only his bike has.
11-17-2012, 10:04 AM
#729 | ||
Oddometer: 5,505
1. Worn or loose Wheel, Head or Swing arm bearings ? 2. A crack somewhere in the frame, perhaps in the steering head area or where swing arm attaches to main frame around linkage area?? 3. Bent forks ? 4. Out of align frame (from previous accident) ? It could also be clapped out suspension, but probably one of the above issues are having an affect too .... ![]() I don't think he is a Troll ... but somehow has got a weird DR650. He's taken a lot of Flack ... but handles it pretty well, IMO. I have seen (and ridden) bent frames that you can't tell are bent. But the bike handles weird ... has a mind of its own. Can be subtle, impossible to see with naked eye. There is a guy called The Frame Man up near Sacramento, CA who is expert at straightening ... mostly does race bikes. Excellent work ... and night and day difference once frame is perfect. There are others who provide these same services. Frame Man has been around over 20 years. I take bent wheels to him ... and one crashed bike. Perfect results! |
11-17-2012, 10:24 AM
#730 | |
Oddometer: 491
victor441 screwed with this post 11-17-2012 at 11:08 AM |
11-17-2012, 11:10 AM
#731 | |
barko1
Oddometer: 2,513
Perhaps in the region above the neck ![]() Troll?? DR worst bike ever?
DR650, 98 Bimota SB6R, Kawasaki 14, 67 X-6 Scrambler (apart), SL350K1, 77 Goldwing 1000, V11 Rosso Mondello Guzzi |
11-17-2012, 02:32 PM
#732 | |
Oddometer: 1,179
doug s, |
11-19-2012, 07:54 AM
#733 |
Oddometer: 64
"Factory" lowering of DR650?
Hey guys....
I've seen it mentioned a couple places that there is the ability to lower the DR650 in it's stock configuration. Is this correct and if so, how is it done? I understand using lowering links but I think this was something different. Thanks, Nate (the noob) |
11-19-2012, 08:29 AM
#734 |
Oddometer: 617
Lowering the Factory way
Yes, the DR is designed so that it can be lowered by altering the suspension.
The shop manual has the info on how to do it. Don't have a shop manual yet? Buy one. ![]() Basically, the forks are removed, opened up, and the steel tube spacer that sits on top of the main springs is moved to fit on the damper rod with the top out spring. That lowers the forks and limits their travel by the length of the spacer. The rear shock is removed, pretension on the spring is released by turning the two rings on the top of the spring and once the spring is real loose the spring seat at the bottom ( a big chunk of aluminum with a slot in the side) is slipped off the shaft and turned upside down and slipped back in place. Then the spring tension rings get re-tightened and the shock gets reinstalled and bolted back in place but using the upper of the two bottom mount holes on the clevis. The spring seat flip limits the travel in the rear so that the tire doesn't hit the fender. Using the upper of the two lower mount holes in the shock clevis is what lowers the rear end of the bike. I have done it twice and it is not difficult if you are comfortable working with tools and following instructions. Some have the dealer do it but if the dealer mechanic is not familiar with the DR factory lowering I would NOT have them do it. I don't have my shop manual here so others may want to correct anything I have said that is not correct. I am going by memory and that isn't very good any more. Never was actually, but is worse now. ![]() This will lower the bike almost 2 inches. Suzuki sells a shorter kick stand for the lowered bikes. Or you can cut and weld the stock one. The forks can also be slid up in the clamps a bit to lower the front more without the tire hitting the fender, and lowering links can be used in the back too. Keep in mind that this also decreases ground clearance and suspension travel. My Street Tracker Sumo bike is lowered 5" in front and 4" in the rear for a lower CG. (I have a 19" front wheel on it)
11-19-2012, 09:33 PM
#735 |
Oddometer: 272
shhh!!!
