Old 11-19-2012, 10:05 PM   #736
Tech23
Tech23's Avatar
Oddometer: 471
Dunlops tire changing video.
How many of you guys remove both beads from the same side of the rim when dismounting a tire?
Dunlop dismounting video....
http://www.youtube.com/watch?v=TVKzoaL8qaI
Dunlop mounting video...
http://www.youtube.com/watch?v=IMYQ6L2jKKQ
Having all the tools used in these videos can make life easier including the Motion Pro tool that holds the bead into the drop center of the rim. There are two version of that tool so if you plan to order one make sure you order the correct one.
Tech23
2004 Suzuki DR 650SM
2000 Harley Davidson FXDWG
2011 Victory Cross Country
Tech23 is offline   Reply With Quote
Old 11-19-2012, 10:11 PM   #737
Tech23
Tech23's Avatar
Oddometer: 471
Originally Posted by rogor View Post
anyone reading the rubbish from jonkol in the usual dr thread
some people...
Some call it buyers remorse, this often leads to neglect of the machine and complaining about it whether its a car, motorcycle, or whatever it may be. The good news is there are many other motorcycles to choose from.
Tech23
Old 11-19-2012, 10:47 PM   #738
BergDonk
BergDonk's Avatar
Oddometer: 3,719
Tech23
Yep, been doing it this way for a long, long time.
The stand makes it easier on the body, but not essential. I use more talcum than they do, and no assembly lube, its not needed. Nor do I use a bead buddy for assembly. This is where you use the rim lock, and by starting and finishing at the rim lock you have an easier time getting the bead into the well of the rim. So in addition to what they do, start and finish at the rim lock, and/or valve stem if you have no lock. Easy 5 min job. Also get the tyres hot. If I'm not riding to warm them up, I leave them in the sun for a bit, and do it when the day is warmer if I have a choice. A HD tube will normally hold its shape without adding air, so no need for that either unless you have std tubes. I also prefer pointier tyre irons/levers. I have a Motion Pro T6 axle spanner spoon on each bike that I reshaped a bit to get a pointier tip. Only put the lever down between where the bead is outside the rim and in the well, so small chunks at a time and it'll go on easy, and you can easily get the lever under the bead because its not in contact with anything at the spot, say 2-3" at a time.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 11-20-2012, 02:19 PM   #739
godaddygo
drdude
godaddygo's Avatar
Oddometer: 344
New instrument panel...need to move the key gizmo
I may not be searching correctly so let me ask and thanks for the help...looking to get the instruments including the key ignition out of the "hole" and build a more Dakar panel on my DR650... All is easy except movng the key tumbler? I have read where you can rewire and use a different lock/key? ...but would be nice if there was a relacement plug and play key tumbler?...Not sure i am making sence...want to move the key out from stock location up and out...
Chris
Northern Idaho
godaddygo is offline   Reply With Quote
Old 11-20-2012, 06:30 PM   #740
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Chris
Northern Idaho
You can move the ignition switch ... or put in a different one. But be aware of the wiring that comes into the underside of the switch and the little secret Resistor in there that is an Anti-Theft device. You need that Resistor as it feeds back into the main wiring harness and goes to the CDI box. Figuring out how to eliminate it ... is something I've not heard about.
When you pull apart the stock ignition this may make more sense to you ... or not.
Old 11-20-2012, 06:46 PM   #741
JagLite
JagLite's Avatar
Oddometer: 1,330
Thumb Remote key
Chris
Northern Idaho
Sure you can move the key ignition.
You will have to do some work to remove the safety screws that hold it on that are to keep people from removing the key lock since it is the fork lock too.
Once you cut/drill/hack away the screws holding it to the upper fork clamp you can mount it anywhere the wires will reach.
Or, by extending the wires you can relocate it anywhere you want.
Of course you will NOT have a fork lock so plan an alternative parking lock.
You can use a different key ignition but you will need to wire in a correct resistor.
There is a nice write-up on here by someone who did that.
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 11-20-2012, 07:45 PM   #742
ER70S-2
ER70S-2's Avatar
Oddometer: 6,740
Here you go, post #25.
http://www.advrider.com/forums/showthread.php?t=635694
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 11-22-2012, 09:26 PM   #743
TrophyHunter
Oddometer: 2,250
My DR was originally blue but I like the clean look of all white so I've been collecting, uh ordering off the 'net, parts for the change over. I also finally bent the stock bars so and had the ProCycle bar kit waiting, so....
New front fender, Tusk handguards, bars w/1 inch risers, pillowtop grips (managed to save my grip warmers during the transfer) and a fork service since it was all apart anyway.
I like the profile on the aftermarket fender....which was $22 shipped and bolted right up. Just had to drill for the speedo cable guide. I have a new white rear fender waiting for a few hour gap in my day.
'07 WR450 2013 HD Road King '73 Hodaka Wombat
TrophyHunter is offline   Reply With Quote
Old 11-23-2012, 04:29 AM   #744
Bultaco206
Back-to-back motos suck
Bultaco206's Avatar
Oddometer: 2,397
Originally Posted by Bultaco206 View Post
Well, I've got a lot of stuff (a lot) ordered but I've done nothing to the bike yet since I bought it last Saturday. But I did do about 40 miles of gravel on it today...what they're calling the last 80-degree day until next summer.
Had a DR guru friend (he lurks on here...thanks for your help, Paul) who's up on all the necessary DR mods help me for a day a few weeks ago. The bike really woke up motor-wise. Drilled out the fuel screw, re-jetted for the Q4, installed Ricor emulators, added external fuel filter, re-worked the neutral sending unit mount, installed new rubber (Shinko 244 test) new Renthal Jimmy Buttons, did the DR200 taillight swap, kickstand safety switch removal, upper chain roller removal, Acerbis handguards, and the rear end conversion to a simple license plate mount. This thing pulls like a tractor now right off the bottom. My Wolfman racks and Expedition bags have been shipped. And I'm playing around with a new Cee Bailey sport windscreen mounted on a spare headlight shell for quick conversions. The jury is still out on the performance of that, and now that winter has set in here in NE Iowa it will be next spring before I can figure that out.
'07 DL650, '06 KLX351, '97 DR350, '83 XR350R (vintage GP racer), '74 Bultaco Alpina (trials)
Bultaco206 screwed with this post 11-23-2012 at 04:38 AM Reason: Kant spel
Bultaco206 is offline   Reply With Quote
Old 11-23-2012, 04:35 AM   #745
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,764
Originally Posted by ER70S-2 View Post
Did you know you can link to the actual post by clicking on the number on the top right of the post itself?
Old 11-23-2012, 11:40 AM   #746
ER70S-2
ER70S-2's Avatar
Oddometer: 6,740
Yes, I did thanks and now others do too. I wanted the OP to scroll thru the thread to see what's available in Krusty's Index.
Also thanks for your tips in the GPS and Spot threads.
2013 WR250R
Old 11-23-2012, 01:23 PM   #747
killme_quik
the street n00b
killme_quik's Avatar
Oddometer: 40
Question Engine rebuild...?
Thank christ there's a newer, less monsterous DR thread... After many attempted searches through that monster, I've decided to post my question here.
Has anyone done the full top end rebuild on a DR650? I'm looking at getting the high performance top end rebuild kit from procycle as my big pig has about 25-26,000 miles on it. Is it too soon to do a rebuild?
2005 Suzuki DR650
++TARDED
killme_quik is offline   Reply With Quote
Old 11-23-2012, 03:08 PM   #748
dflow
dflow's Avatar
Oddometer: 358
It depends on a lot of factors but I have 29k on my second DR now, the 1st one is over 32k, and neither has had any work or need for it. With basic upkeep they run without issues.
'06 DR650SE, '99 R11S, '84 R100 project (eventually)
Get your facts first, then you can distort them as you please. -Mark Twain
dflow is offline   Reply With Quote
Old 11-23-2012, 03:29 PM   #749
M1Jeep
M1Jeep's Avatar
Oddometer: 1,954
+1, 34k miles and going strong. It's all about PMCS (preventative maintenance checks and service). "If it ain't broke, don't fix it!"
Rich
My YouTube
M1Jeep is online now   Reply With Quote
Old 11-23-2012, 03:57 PM   #750
ER70S-2
ER70S-2's Avatar
Oddometer: 6,740
+ another: 42,400
2013 WR250R
Times are GMT -7.   It's 05:46 AM.
