Old 01-20-2013, 09:06 PM   #31
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,490
http://jupiterhack.blogspot.com/
Living proof you shouldn't play with matches
ABC# 1992
Old 01-22-2013, 02:12 AM   #32
toastmuncher OP
I be new round here! Ello
toastmuncher's Avatar
Oddometer: 677
A little progress yesterday, dropped the gear oil while the exhaust was off, refilled transmission and re-fitted the exhaust system, for those unfamiliar with guzzis, the oil filter is INSIDE the sump pan, so I removed the sump to fit a new filter, a pain but it DOES make you clean the pan out periodically, the bikes been idle for 7-8 months and the oil had settled and the inside of the sump was in need of a good clean out. Put the sump back on with new gaskets.
Had a good nose about while the sump was off, no evidence of prior blowups or bad repairs.
Now, the front upper mount for the chair brackets is a bit tricky, the reg/rec is mounted just under the headstock, by drilling the mounting bracket I was able to relocate in 2'' over to the right.
The ignition coils are another issue though.
While it would have been far better to use a 'block' clamp, I just could not seem to get it installed without fouling the coil assembly, so, searching through my bracket archive I found a cast type clamp, I know this is less strong, but the other three are very tough and I am confident this wont cause me an issue, I have installed this as close to the headstock as I can and still clear the coils. You can see the issue in this pic. There is not enough clearance to relocate the coils over to the right, and no alternative site for the coils without major headaches, Ill have to run with this.
Just heading back up to the workshop for a few hours, about three today hopefully, and am pleased that the bike is beginning to look like a bike again, just hope Im not waiting too long for the body after I run out of prep work with the bike. I am in a spot where, because I wanted the hack wheel painted up to match the body, I cannot do anything to mount the frame as the height of the chassis cannot be set.
Although I am using the little GN 'Mighty Bullet' as my son calls it, to run about in this snow, alopng with my AJS 250 unit, I need this done..........I have a camper van 'Small RV' to build before the spring too. Some pics.
the Camper, its gonna be a pain, but will open the door to more regular getaways, the Outfit will be dragged on its trailer along with us and used for running around once the van and its awning etc are set up. At the mo, its a blank canvass. 2.4 5 cyl diesel, non turbo, S L O W !
Guzzi 1100 callifornia stone 2003
Guzzi 1100 california hedingham hack 1994
Guzzi 1000 lemans 5
Guzzi 700 V7 details-mystery
Matchless g3ls 350 54, Ariel 650 huntmaster 56. IBA 40526
toastmuncher is offline   Reply With Quote
Old 01-22-2013, 02:16 AM   #33
toastmuncher OP
Oddometer: 677
Methinks I may need a new camera too.
Guzzi 1000 lemans 5
Old 01-22-2013, 04:55 AM   #34
Guzzista_Joe
Guzzista_Joe's Avatar
Oddometer: 34
Love the rig as it's coming on, the bug looks the nuts too. If you're still looking for paint codes we have a load on our site in the "Resources" section, look for the "useful websites" page http://guzzista.wetpaint.com/page/GUZZI+RESOURCES
Joe
Guzzista_Joe is offline   Reply With Quote
Old 01-22-2013, 05:59 AM   #35
toastmuncher OP
Oddometer: 677
Joe
Thanks Joe, bug has gone now unfortunately, it wasnt getting used enough so has gone to fund the camper which will benefit us as a family rather than be another toy for 'Daddy', wish I had that paint code info a while back, just came back from the painters and....................................... ITS DONE. Pics to follow.
Guzzi 1000 lemans 5
Old 01-22-2013, 07:17 AM   #36
toastmuncher OP
Oddometer: 677
Right, just uploaded, off shortly to collect my lad from school so Ill get these up quick.
Minor screwup, once the grey was on, they discovered they did not have enough gold pinstripe to go between the pearl and dark grey, so they have laquered it and are going to apply the stripe over the top. Again, not ideal but just glad to have it done. I had the jerry can done as I plan to carry fuel on a holder on the back corner of the hack, the guzzi sticker on this AND the eagles on the hack ARE laquered over. PICS................................... All of them.
Hes put the grey on the wheel center too, I dont want to hear 'fault finding' Im just so happy its done and I can now get on and get this done. Clive who did the work is a mate Ive known for 20 years, hes done this pretty cheap and I gave him free reign to decide where the white went on the body, and how much to put on, I guess I may have had a LITTLE less white, but we'll see when its all together how she looks.
One happy Ginger Bugger.
Guzzi 1000 lemans 5
Old 01-22-2013, 07:53 AM   #37
Sidecarjohn
Sidecarjohn's Avatar
Oddometer: 754
Blimey, know it's been a while, but some paint job. The project is going well.
SidecarJohn
http://www.sidecarjohn.co.uk/
Sidecarjohn is offline   Reply With Quote
Old 01-22-2013, 08:33 AM   #38
toastmuncher OP
Oddometer: 677
Thank you John. Im hoping itll be a great outfit once finished. Hopefully It will match up and look the part too.
Guzzi 1000 lemans 5
Old 01-22-2013, 01:38 PM   #39
Bobmws
Curmudgeon At Large
Bobmws's Avatar
Oddometer: 1,398
Can't wait to see that all together, the paint looks great!
Bob Weis 04 K12RS - Hannigan Hack
Everything happens for a reason, but sometimes the reason is you're stupid and make bad decisions.
Photo's: http://s1077.photobucket.com/albums/w464/Bobmws/
www.earplugco.com
Bobmws is offline   Reply With Quote
Old 01-22-2013, 02:04 PM   #40
TouringDave
Tri Moto Veritas
TouringDave's Avatar
Oddometer: 7,101
Wow! very nice paintjob, colour scheme is brilliant!
05 R1150R....now 2 wheels...soon 3 wheels.
84 Kwaka GT750 Cafe Project & 84 Kawaka GT750 Outfit
TouringDave is offline   Reply With Quote
Old 01-22-2013, 02:45 PM   #41
Jnich77
Jnich77's Avatar
Oddometer: 817
Love the attention to detail in regards to the paint
Jnich77 is offline   Reply With Quote
Old 01-23-2013, 01:26 AM   #42
brstar
brstar's Avatar
Oddometer: 476
Thumb Classy
It is going to look very classy.
brstar is offline   Reply With Quote
Old 01-23-2013, 03:04 AM   #43
Agent Wayward
Oddometer: 375
It's going to look superb! Great job so far.
SV650 Rat
R80 custom
Multistrada 1100
www.motopodd.com
Agent Wayward is offline   Reply With Quote
Old 01-24-2013, 12:40 AM   #44
toastmuncher OP
Oddometer: 677
Wink
Painter man dropped the wee bits and bobs off last night, I have to go collect the sidecar body tomorrow, the grey on the parts is a LITTLE darker than the grey on the bike. I re-assembled the bike last night, removed a very complicated alarm system and the heated grips that didnt fit right and moved around on the bars. Here the last solo pic of this bike ever. You can see the auxillary tank on the tail, its not plumbed in yet, will plumb it before our france holiday in the summer.
Guzzi 1000 lemans 5
Old 01-25-2013, 03:14 AM   #45
toastmuncher OP
Oddometer: 677
I am having a dry mock-up, the brackets dictate a lead of 14 inches, FOURTEEN INCHES!!!!
Input?
Guzzi 1000 lemans 5
Times are GMT -7.   It's 06:17 PM.
