Old 01-04-2013, 04:44 AM   #16
Bar None
IBM Retired
Bar None's Avatar
Oddometer: 4,800
Originally Posted by kb5zcr View Post
You need this. The one four from the left is the correct tip.
$24 at Harbor Freight.
http://www.harborfreight.com/automot...kit-95904.html
I bought that kit at HF and had to use the one four from the left plus the flexible extension to get the grease into that fitting.
I saw the "hand mini grease gun (3 ounce cartridge of grease) that fits my 2011 GearUp zerks very nicely" there also but I think it required manual loading.
Seemed to me that all three u-joints on my Yamal took a lot of grease.
Vince @ SWFL or WNC
2015 Ural cT 2001 Kawasaki W650
Bar None is online now   Reply With Quote
Old 03-02-2013, 02:47 PM   #17
smelick
Once you hack...
Oddometer: 76
found it!
Ok, after trying the needle tip fitting and then grinding the needle tip down without any success, I figured I'd try the mini grease gun from Harbor Freight. The fitting on that was too big as well, as I tried to grind it down I took off the fitting it came with and BINGO it works perfectly!! It turns the tip into the Lincoln Lubrication 5855 Extension Adapter - but at less than 1/2 the cost!!
This is the gun (It was on sale for $9)
http://www.harborfreight.com/grease-...ase-95575.html
You can see the gun here without the fitting.
I am lubed up!!
-Scott
'10 Ural Patrol T
'64 Vespa GS 160
'57 Cushman Road King with 'side kar'
http://www.scooter-sidecars.com/
smelick is offline   Reply With Quote
Times are GMT -7.   It's 09:27 AM.
