Old 07-01-2012, 03:30 AM   #1
jaumev OP
jaumev's Avatar
Oddometer: 1,505
Yamaha Super Ténéré 1200 Skid plates list and specs
So after a million posts in the Super Ténéré thread here is the skid plates list.
After all the discussions I think we can list them for its principal characteristics: ground clearance, mounting type, weigh and aluminium thickness. Feel free to ad any more specs you think or if I forgot any other skid plates.
Please help to correct and fill all the specs so we can have a full list.
GROUND CLEARANCE: Every bike is set up differently with different gear and pre-load settings, etc. So lets have the measurement on the center stand, from a level concrete floor to the skid plate lowest point.
FORCE: 9,5" / 24,13 cm
TOURATECH: 9,17" / 23,3 cm
HEPCO&BECKER: 9,25" / 23,5 cm
ACD: 9,45" / 24 cm
ALT RIDER: 9 3/8" / 23,8 cm
RIDEONADV: 9,5" / 24 cm
SW MOTECH: 9,25" / 23,5 cm
RUMBUX: 9 ¾” / 24,76cm (skid plate lowest point??)
OEM:
MOUNTING TYPE: FRONT / BACK
FORCE: sump / frame
TOURATECH: front engine mount with silent blocks / frame
HEPCO&BECKER: front engine mount / frame
ACD: frame / frame
ALT RIDER: front engine mount / frame
RIDEONADV: frame / frame
SW MOTECH: sump / frame
RUMBUX: frame / frame (complete steel frame under the engine 25mm steel tubing)
OEM:
WEIGHT (measured with bolts and all hardware): lbs / kg
FORCE: 6 / 2,7
TOURATECH: 7,8 / 3,57
HEPCO&BECKER: 14 / 6,3
ACD: 11 / 5
ALT RIDER: 9,2 / 4,17
RIDEONADV: 13 / 5,9
SW MOTECH:
RUMBUX: 12,6 / 5,7
As to the weight of the Rumbux, the weight of the unit, complete upper and lower with all hardware, (most of the big bolts replace shorter OEM ones), is 23 lbs. The lower bash frame w/skid plate and all hardware is 13 lbs and the upper bash frame is 10 lbs.
OEM:
ALUMINIUM THICKNESS (millimetres):
FORCE: 4
TOURATECH: 3
HEPCO&BECKER: 4
ACD: 4
ALT RIDER: 3
RIDEONADV: 6
SW MOTECH: 3
RUMBUX: 4,5
OEM:
jaumev screwed with this post 02-14-2014 at 11:47 PM
jaumev is offline   Reply With Quote
Old 07-01-2012, 07:54 AM   #2
Anticyclone
Ride more worry less
Anticyclone's Avatar
Oddometer: 5,760
I recently talked to Jaxon at RideonADV, and according to him the plate weighs roughly 13lbs depending on how many and what kind of holes you have machined in it.
I'll be ordering one in the next few weeks and will be sure to weigh it before I install it .
Anticyclone is offline   Reply With Quote
Old 07-01-2012, 08:32 AM   #3
stevepsd
Oddometer: 226
My Altrider gives me 9 1/2" clearance where you measured yours.
Also it does not attach to the sump at the front as you have listed, but to the front engine casings. The sump is the bottom of the motor...aka the oil pan.
My skid measures 3.2mm or 1/8" thick.
'12 XT1200Z SuperTénéré, '09 KTM 530 EXC, '08 Triumph Tiger 1050, '87 XR600R Street Legal
Gone but not forgotten: '92 Yamaha TDM850, '82 XJ550 Seca, '80 XS1100,'85 GL1200A, '84 V65 Sabre, '80 CB750F SuperSport, '77 RD400, '72 TS250, '69 CB450K, '68 CL70
stevepsd is offline   Reply With Quote
Old 07-01-2012, 10:29 AM   #4
jaumev OP
jaumev's Avatar
Oddometer: 1,505
Ok, added to the list. Thanks!
OK, added. Do you measured in the lowest point? Its strange, the Touratech is nearly touching the engine and is lowest than yours. With the central stand, in the Touratech the lowest point is the front to the skid plate.
You're right I modified the Altrider attach, Thanks!
jaumev screwed with this post 07-01-2012 at 10:34 AM
Old 07-01-2012, 01:45 PM   #5
stevepsd
Oddometer: 226
Rechecked, and at your reference point (in front of the brake pedal, in line with the exhaust heat shield screw) it measures 9.5". This is on the centerstand, on level concrete.
I moved the tape all around, and did find towards the front where the clearance went down to 9 3/8" in one spot.
Now my skid did have the snot beat out of it, enough to crack the welds, bend the mounts, so I did have to straighten the skid and the mounts - with the help of a 12 ton press and I did reweld the cracked so this could change things some.
I also checked and I have no less than a minimum of 3/4" of clearance from the skid to the bottom of the motor (I put a 3/4" spacer down there at it clears everywhere). There is more clearance between the skid and the motor at the back than the front, and I have right at 3/4" between the oil filter and the skid.
Old 07-01-2012, 02:36 PM   #6
jaumev OP
jaumev's Avatar
Oddometer: 1,505
I think the best is to measure them all at their lowest point, so I put 9 3/8 to your plate, ok??
jaumev screwed with this post 07-01-2012 at 11:54 PM
Old 07-01-2012, 02:42 PM   #7
AlsoRan
Lone Trail Of Dust
AlsoRan's Avatar
Oddometer: 408
Ground Clearance
SW Motech ground clearance from same point of reference and on center stand: 9.250 in or 23.495 cm
2012 Yamaha Super Ténéré
AlsoRan is offline   Reply With Quote
Old 07-01-2012, 03:44 PM   #8
Ze_zaskar
Ze_zaskar's Avatar
Oddometer: 309
This should go sticky
Ze_zaskar is offline   Reply With Quote
Old 07-01-2012, 03:46 PM   #9
GrahamD
GrahamD's Avatar
Oddometer: 5,366
It's in the link thread, so it's sticky-ish.
"It's better to ride a boring bike than push an interesting one" ... Canuman
"I just may as well admit that my other bikes are toast. I don't ride them. Plain and simple. I didn't want this. It wasn't the plan." - snakebitten
GrahamD is offline   Reply With Quote
Old 07-01-2012, 03:51 PM   #10
CafeRacer99
Oddometer: 443
The clearance on the Force Accessories plate is about 9.5 inches at the front edge. That's on concrete on the center stand.
Ride to Coffee
Coffee to Ride
CafeRacer99 is offline   Reply With Quote
Old 07-01-2012, 03:55 PM   #11
wfopete
Suffer Fools; Gladly!
wfopete's Avatar
Oddometer: 486
How about throwing in the MSRP for each?
Suffer Fools; Gladly!....
RIDING the TAT? CHECK IT OUT: TAT SHAK
ARA - Adventure Riders of Arkansas
wfopete is offline   Reply With Quote
Old 07-01-2012, 04:11 PM   #12
Ze_zaskar
Ze_zaskar's Avatar
Oddometer: 309
Yep, that's perfectly acceptable
Old 07-01-2012, 07:18 PM   #13
olie
olie's Avatar
Oddometer: 1,164
how about the OEM accessory? that should be the baseline of comparison of price and design features or lack of them if you wish...
red 09 ZG /C14 ABS (gone with 59k miles); blue 13 ZG /C14 (7/13 new)
Remus HexaCone Ti, CF hugger,CB Ultra W'shield, GSG Sliders, Sargent seat
12 XT12, black
Akrapovic, Givi W'shield, Kappa saddlebags...
11 Vette, unmolested...
olie is offline   Reply With Quote
Old 07-01-2012, 08:12 PM   #14
CafeRacer99
Oddometer: 443
I'm considering replacing the bolt in this picture with a nylon or similar material bolt.
This is the bottom of the front bracket that holds the Force Accessories plate on. It's the only mounting point that I really would worry about. I'm thinking a plastic bolt would break away under a hard hit before the engine mount would break.
I was considering just taking this bolt out and not putting anything in there. The plate would still be prretty solidly mounted with two bolts in the rear attached to the frame and the two at the upper engine mounting points.
I know I said in the other thread that I was done worrying about this, but it's one of those things your mind works at until you find an answer. I can't help myself, lol.
The specs for the plastic bolts are here: http://www.non-ferrousfastener.com/p...489be9c3#NYLON
I'm thinking polypropylene.
Is this just crazy talk?
Ride to Coffee
Coffee to Ride
Old 07-01-2012, 11:52 PM   #15
jaumev OP
jaumev's Avatar
Oddometer: 1,505
Added: SW Motech and Force. But no idea of OEM specs.
Don’t know how to do it
Good idea but difficult to apply, it could be different prices in different countries. If you want to do the exercise…
Times are GMT -7.   It's 01:34 AM.
