07-02-2012, 12:01 PM
#16 |
Oddometer: 920
I’ve measured the bike lowest point in the centre stand without a skid plate and is a bit less than 25cm (9,84”), so the best ground clearance with a skid plate must be about 24cm (9,45”) minimum or the plate is going to touch the sump.
So, I assume both the Rumbux (24,76 cm) and the Force (24,13cm) are not measured in the lowest place. Can you check it? Thanks!
jaumev screwed with this post 07-02-2012 at 10:36 PM |
07-07-2012, 08:07 AM
#17 |
Oddometer: 1,524
Jaumev - thanks for starting this...
H&B is 9.5" at the front, 9.25" at the rear. I think the front clearance is the more important number - and anyway the rear tang has a bit of flex in it so the missing 1/4" isn't going to afftect anything. thickness is 4mm Trevor |
07-07-2012, 12:40 PM
#18 | |
Oddometer: 920
Let's see if someone tell us the RideoNav and OEM specs. |
07-07-2012, 12:49 PM
#19 |
Oddometer: 1,668
Is there a 'rideonADV' plate? I mean, he's custom made some for customers, but every one is different isn't it?
07-12-2012, 02:23 PM
#20 | |
Oddometer: 920
07-14-2012, 09:44 AM
#21 |
Oddometer: 865
Rem has one (RideOnAdv) in WhiteHorse, Yukon. I saw it, thought I took some pictures. Anyway it is built with a jig, so you can order and install yourself. Very strong looking and 1/4" thick. Solid solid. It will fit over the crashbar mounts or OEM mount like I have. If I did not have the H&B I might get one, but I am very happy with the ease of removal and protection I have.
2013 HyperStrada 2012 Super Tenere 09 Monster 696 (wife's bike) |
08-23-2012, 06:21 AM
#22 |
Studious
Oddometer: 4,272
Got my RideonADV plate yesterday. I won't install it until the crash bars come in, so I'll post up some more later...
Initial impressions: Damn, this thing is built like a tank! ![]() Excellent beer for scale: ![]() Now for the big question, weight. From my not legal for trade, non scientific, uncalibrated scale: ![]() ![]() It's thick, about 1/4 inch: ![]() Jaxon, ~TABASCO~ on ADV and the Tenere forum, was great to work with. His enthusiasm for motorcycles in general and the Tenere in particular shows in every phone call and email. Just don't expect to order it on a Monday morning and get it for your weekend trip as it is made to order . I'll add some pictures with the ground clearance once I get it mounted.
Later, Michael "If I can't pass at a reasonable speed I do it unreasonably." - jdmetzger DRZ400 for sale |
08-23-2012, 03:45 PM
#23 |
Oddometer: 920
Thanks! I think this is more or less the same we've got in the list, please check it.
Is the weight with the hardware? ![]() Your bike is going to look like a panzer, it looks really strong!!!
08-23-2012, 04:04 PM
#24 |
Studious
Oddometer: 4,272
The specs are what is on the list. The weight is with the rear mounting bracket (also 1/4" aluminum) but without any bolts. The bolts Jaxon provides replace stock bolts, so I left them out.
08-23-2012, 06:23 PM
#25 |
Lone Trail Of Dust
Oddometer: 288
Keep those calipers they are classic old school!
Nice skid plate setup...
2012 Yamaha Super Ténéré |
08-24-2012, 08:42 AM
#26 | |
www.rideonadv.com
Oddometer: 351
Keep in mind that depending on how the suspension is set up on a particular bike these "clearance" measurements wont be the same or accurate.. Depending on sag, fuel capacity, extra accessories added to the bike, Etc... Someone could be off 1/2" or more with soft suspension and a full tank when measuring... |
08-24-2012, 08:52 AM
#27 | |
www.rideonadv.com
Oddometer: 351
They are hand made for sure. We do offer many options that the customers can choose. Our "standard" plate starts off the same each time for the ST. We do have two jigs we use for these plates. Here are a few other features... - Change the oil and the filter with the plate left on the bike - The entire construction is 1/4" (6mm) billet aluminum - Frame mount (frame to frame) does not touch the motor - Protects the fallowing: bottom of engine / headers / rubber water hose / metal water hose / water pump / generator cover / oil filter / 02 sensors / exhaust cat / right and left side (front of) engine cases - Powder coat color of your choice - We can add high way pegs to the unit - LIFE TIME WARRANTY |
08-24-2012, 10:20 AM
#28 |
Oddometer: 697
Jaumev - you might want to correct the spelling of RideonADV in each category in post #1 of this thread, now that we are getting details on this plate. It has confused at least one inmate.
1990 Honda NT-650 Hawk-GT Never doubt that a small group of thoughtful, committed citizens can change the world; indeed, it's the only thing that ever has. - Margaret Mead
08-24-2012, 10:29 AM
#29 | |||
Oddometer: 920
GROUND CLEARANCE: Every bike is set up differently with different gear and pre-load settings, etc. So lets have the measurement on the center stand, from a level concrete floor to the skid plate lowest point. Tabasco, can you gives us the RideonADV skid plate ground clearance in this conditions?. Many thanks! Quote:
jaumev screwed with this post 08-24-2012 at 10:48 AM |
08-25-2012, 06:09 AM
#30 |
Oddometer: 726
Price?
Nothing is worse than active ignorance. Johann Wolfgang von Goethe |
