Old 07-02-2012, 12:42 AM   #1
Phil43 OP
Oddometer: 6
Dominator Street Tracker
Hi, I'm currently building a Honda NX650 Dominator based street tracker. The project is underway , but still with a long way to go and so I'm hoping that by keeping a build diary here I will be encouraged to keep it from stalling ! Will post pictures of the progress so far, over the next few days. Here's the first, showing the bike in the process of being stripped down.
Cheers, Phil
Hmmm.... can't see anywhere to attach pics ? Where should I look ?
Phil43 is offline   Reply With Quote
Old 07-02-2012, 08:25 AM   #2
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 2,897
Send a message via AIM to Bronco638 Send a message via Yahoo to Bronco638
Welcome Phil.
You need to host the images elsewhere (picaso, photobucket, smugmug, etc.) and link to them.
I had an NX125 and am curious as to what a "NX650 street tracker" will look like.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 07-02-2012, 12:43 PM   #3
andy352299
Oddometer: 8
http://www.xrv.org.uk/forums/dominat...-all-done.html
this guy has now built 4 of them all top quality work
andy352299 is offline   Reply With Quote
Old 07-07-2012, 05:37 AM   #4
Phil43 OP
Oddometer: 6
test
Testing
Old 07-07-2012, 05:46 AM   #5
Phil43 OP
Oddometer: 6
test2
Old 07-07-2012, 05:49 AM   #6
Phil43 OP
Oddometer: 6
Done it, posted a picture on my thread !!!!
More will be posted soon.
Old 07-09-2012, 12:12 PM   #7
Phil43 OP
Oddometer: 6
Lower Front Suspension
The first job that I tackled was lowering the front suspension. I lowered the forks 100mm (4") by removing a 50mm spacer
from above the springs and then chopped off a further 50mm from the end of the springs that have the more loosely wound coils. This should stiffen up the front end as well as lowering it. Next I machined up some 100mm spacers to fit below the springs,which compensate for the removed material up top. This ensures there's no slack in the forks when the front wheel lifts off the ground ! There's a large hole in the spacer to line up with the oil way and a grub screw to line the two up.
Here's the bike sitting pretty, 100mm lower at the front
Old 07-09-2012, 06:47 PM   #8
RedRaptor22
Oddometer: 133
Hmmm, be carefull with those spacers in the bottom end, a friend of mine built a full size nsr once and put the spacers below the springs which ended up in a locked up solid fork when the spacers jammed beneath the upper tubes.
Definately make sure you have a way to hold them absolutely center in that lower leg.
RedRaptor22 is offline   Reply With Quote
Old 07-11-2012, 07:09 AM   #9
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 2,897
I cannot believe how similar that frame is to the frame on my DR650.
Old 07-11-2012, 12:24 PM   #10
Phil43 OP
Oddometer: 6
New rims and tyres
The front wheel has now had the 21" rim swapped for a wider 18" rim and both rims have been powder coated satin black, with Made-In-England Avon road rider tyres fitted. Finding a 32 hole rim to suit the hub was not an easy task, as nearly every ally rim on e-bay is either 36 or 40 hole.
The fork spacers should be fine. I made them with an interference fit on the inner piston strut and about 3mm clearance round the outside for good oil flow.
Just waiting for my genuine Chinese Yamasaki tank to arrive in the post now !
Old 08-07-2012, 07:00 AM   #11
JagLite
JagLite's Avatar
Oddometer: 598
Thumb Nice!
Excellent start!
I am looking forward to following your progress.
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 09-18-2012, 02:14 PM   #12
Pake
Oddometer: 1
Looking forward to progress pictures, just wondering what size tyres you have used, they really look right on the bike.
Pake is offline   Reply With Quote
Old 09-19-2012, 02:35 AM   #13
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,030
Off to a good start. Running a similar wheelset on one of the 650L's I'm building right now.
GatosBros · Crux Studio · Trails Less Traveled
jesusgatos is offline   Reply With Quote
Old 09-21-2012, 07:41 AM   #14
jpbaztan
Oddometer: 1
Hello,
I can't stand waiting for your chinese tank.
I've got an XL600lm and got a similar project on her. Mostly easthetic at this time due to my lack of knoweledge.
As far as your frame is the same as mine, do you know if an old CB350 or 360 from first seventees would fit on it?.
Thank you for sharing.
Pd. Anyone can tell me how to upload pictures from an iPad? Thanks again.
jpbaztan is offline   Reply With Quote
Old 09-22-2012, 09:45 PM   #15
bdjuju
Should be wrenching
bdjuju's Avatar
Oddometer: 47
Send a message via AIM to bdjuju Send a message via Yahoo to bdjuju Send a message via Skype™ to bdjuju
This is what I'd have in mind..
http://deustemple.com/motorcycle/the-dominari/
bdjuju is offline   Reply With Quote
Times are GMT -7.   It's 12:55 AM.
