Old 01-02-2013, 12:08 PM   #1081
amazing ricardo
Piste Off
amazing ricardo's Avatar
Oddometer: 3,543
Originally Posted by bajaboundmoto View Post
and even the little tool boxes in the bash plates are new and weren't installed until bikes were at lima. They were made by jc's brother and in his shop a couple weeks ago.
Yes factory hrc but...
raceco
amazing ricardo is offline   Reply With Quote
Old 01-02-2013, 12:08 PM   #1082
Brodovitch
Team ⌘R
Brodovitch's Avatar
Oddometer: 3,171
That "Noguchi: King of Seat" makes me laugh every time
TALES FROM THE BIVOUAC
TWOONEZERO
Brodovitch is offline   Reply With Quote
Old 01-02-2013, 12:17 PM   #1083
Gian
dreamer
Gian's Avatar
Oddometer: 1,301
Originally Posted by amazing ricardo View Post
rear tanks HRC
it looks so... wide
Gian is offline   Reply With Quote
Old 01-02-2013, 12:23 PM   #1084
amazing ricardo
Piste Off
Oddometer: 3,543
Originally Posted by Gian View Post
it looks so... wide
..it's 'girth'....chix dig 'girth'...
Old 01-02-2013, 12:23 PM   #1085
troy safari carpente
Team f5ool
troy safari carpente's Avatar
Location: "Pearl of the sound" - f5ederation of scandwegia
Oddometer: 20,854
Originally Posted by rmhrc628 View Post
Can someone with more info please advise on the reason for alloy tanks over plastic on the Crf rallye ?
Haven't we used non plastic tanks 30 years ago and learnt they were no good? (steel)
I can't figure out why Honda persist with alloy tanks. Is the reason they are still r and deeing?
Originally Posted by doyle View Post
I've asked and received zero answers. With the might of HRC, I would suspect plastic tanks or a full plastic subframe could be developed pretty readily. It's not like it's new technology and they even exist for the CRF already. I was also thinking heat dissipation. Perhaps the aluminum is acting as a bit of a heat sink to help combat the extreme temperatures expected in Dakar? Either way, they've changed quite a bit even from Morocco to Peru, but they remain alloy no one seems to want to answer why that is.
Only a guess but I'd say it's because everything is still being figured out. Why spend the mega $$ to make plastic until it's a set shape.
In some FBook pics you see the rear view of the X and both side tanks look to have a little box at the top tip. That was because not too long back they cut off the top few inces of tank and relocated those ounces down lower. So the side plate was left with a sharp point and they basically just filled it in. I only know because I asked "WTF?" when a couple weeks ago I saw the sharp point of the side tank. They said it was going to get filled in, but not with gas.
If that was plastic it would be huge $ to make that change.
Guestimate only.
And yes it might be HRC but there's always a budget. If there was no budget wouldn't they have supplied all their own support?
And even the little tool boxes in the bash plates are new and weren't installed until bikes were at Lima. They were made by JC's brother and in his shop a couple weeks ago.
Yes Factory HRC but...
I think it is a combination of two things (possibly) the R & D (ongoing development) vs expense - knocking out new dyes, and moulds to make repeated modifications; (Vers.1, Vers 1.2... Vers 2.0, Ver 3.2... etc. as per Bajabounds obsrevations/insider info. ) does not come cheap... because as tim pointed out also... even if it is "HRC" money is obviously not "no object".
The second theory (along doyles train of thought) comes to me after playting with some plastic multi tanked Husabergs in hot climates, with all the associated plumbing, breathers, fuel lines, different tank volumes AND FUEL INJECTION Not so much for heat dissapation... but the structural integrity of aluminium (and the fact that it does not breathe or expand as the plastic tanks tend to) may well be the HRC engineers idea towards solving the problem of fuel starvation/vapour lock/boiling fuel etc. when at high altitude/high temperatures that we have seen on some of the El dakar stages these last years?
As it has always been a cornerstone of HRC's plan for this new CRF Rally project to run EFI, and we know that the bubbling/fuel expansion/airlock/boiling fuel issues of the last couple editions that commonly plague the multi tanked/different volumetric capacity tanks, plastic kit bikes (the FI husa's spring to mind again) then maybe the Aruminirum tank is the Japanese engineers ace in the hole* as far as getting the FI to work up at 20,000 ft cruising altitude...?
Willing to forgo some of the advantages that plastic/nylon has over aluminium, for the sake of reliable engine management perhaps?
*Then again... wasn't the "official" explanation of helders DNF in Marocco a "vapour rock" though...? ummm... you get those in the tank... not the engine... don't you?
CONTENTS MAY SETTLE DURING TRANSPORT...
troy safari carpente is offline   Reply With Quote
Old 01-02-2013, 12:27 PM   #1086
Team f5ool
Oddometer: 20,854
HRC rear tanks...
This is the "Mariah Cary" edition of the CRF Rally kit;
Sexy, high maintenance, superbly capable in the right hand and oh so expensive...
... but still extremely wide across the ass!
Old 01-02-2013, 12:34 PM   #1087
doyle
RallyRaidReview-ing
doyle's Avatar
Oddometer: 23,852
Oh, that's bad.
RallyRaidReview - @RallyRaidReview
doyle is offline   Reply With Quote
Old 01-02-2013, 12:39 PM   #1088
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 10,147
Holy that bike is freaking fugly...hope it performs up to it's hype
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is offline   Reply With Quote
Old 01-02-2013, 12:42 PM   #1089
doyle
RallyRaidReview-ing
doyle's Avatar
Oddometer: 23,852
You guys are right. HRC just confirmed for me that the rear tanks are aluminum because they are easy to fabricate in a short time frame.
Also we had some discussion about the blocks on the ends of the swingarms when the bikes were first photographed in Peru. IIRC, HogWild had some awesome explanation about passive traction control devices. Well, I asked and they confirmed that they were nothing more than blocks to allow the use of road race style bike stands. Unobtanium.
Old 01-02-2013, 12:54 PM   #1090
Balkan Boy
Oddometer: 1,105
They could've fitted an inline-four motor inside that fairing.
That CRF kit loos like it has much more 'girth' then the HRC ones.
Balkan Boy is offline   Reply With Quote
Old 01-02-2013, 12:56 PM   #1091
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,950
I would rather have aluminum over plastic any day..My 450x puts off much more heat than the lc4, much more!! I'm supprised they dont have any type rubber dampening on the muffler straps as that would seem to conduct heat up toward the tank..
wrk2surf is offline   Reply With Quote
Old 01-02-2013, 12:57 PM   #1092
Iron Horse
I Make Shit Up
Iron Horse's Avatar
Oddometer: 9,353
I like big butts...
Wandering Wapiti
Iron Horse is offline   Reply With Quote
Old 01-02-2013, 01:02 PM   #1093
amazing ricardo
Piste Off
Oddometer: 3,543
Laugh
i'm surprised that the muffler and tank assy has so much room between each other.. yes.. i understand heat transfer, but the COG of the bike could have been much lower if the rear tanks were made thinner and 'lower'... again.. bench racing... but it is obvious that HRC has something behind the curtain... evidence the quick release mechanism at the top of the tanks...
but.. i ain't saying nuttin about nuttin... 'cept honda kick ass in the dakar!!!!
and.. check out the 'raceco' tool box!!!
Old 01-02-2013, 01:39 PM   #1094
rmhrc628
rmhrc628's Avatar
Oddometer: 2,670
Has that exhaust system got 'crack and break' written all over it?
Or will those brackets take a 'lie down'
I can't reconcile 'HRC' with hastily made and old technology.
I understand the tanks are under development but shouldn't that all have been done a year back ?
Don't you do your major learning before the race ?
rmhrc628 is offline   Reply With Quote
Old 01-02-2013, 01:56 PM   #1095
Team f5ool
Oddometer: 20,854
it looks so... wide
Originally Posted by Iron Horse View Post
I like big butts...
Three prospective customers for the soon to be released HRC customer spec' CRF 450 BAMF.
troy safari carpente screwed with this post 01-02-2013 at 01:56 PM Reason: BAMF = BARGE ARSED MO FO...
Times are GMT -7.   It's 09:10 PM.
