Old 01-22-2013, 01:24 AM   #76
mikecbrxx OP
mikecbrxx's Avatar
Oddometer: 193
Originally Posted by beat View Post
I picked up a car that runs 50mpg, I'll head west next month if you pm me a date.
How about coming on 21st Feb (Thursday) in the evening. Its MOTORBeurs Utrecht that weekend and I am taking 22nd off to go to the show. You can stay at my place for a couple nights if you want to....plenty of room.
mikecbrxx is offline   Reply With Quote
Old 01-22-2013, 01:17 PM   #77
beat
Double Dutchie
beat's Avatar
Oddometer: 88
Sounds like a plan. I'll put it in my agenda.
I wanted to go too Utrecht anyway
2012 summer holiday
beat is offline   Reply With Quote
Old 01-23-2013, 01:53 AM   #78
mikecbrxx OP
mikecbrxx's Avatar
Oddometer: 193
Originally Posted by ciedema View Post
Such a small world - stayed at the Sarayshik hotel also get place in Almaty's summer heat and we Aleksey also, I just can remember where, Bikefest on Lake Baikal I think, but it may have been Barnaul. Looks you came through not long after we did (before Vikkor broke his arm).
Great RR - I wish I had of done some of the side trips you did.
Are you still on the road? Do you have your own report running ?
Old 01-23-2013, 07:01 AM   #79
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,942
Yep in Mexico at the moment. I am a bit lazy with the RR, I need to go back to Aus for a couple and plan update it then.
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema is offline   Reply With Quote
Old 02-07-2013, 06:19 PM   #80
Bli55
Oddometer: 362
mikecbrxx, trip!
Also, sorry to hear about the mishap of the sprocket-tank meeting...
Was it 47 teeth? What caused such severe bottoming (i see hyperpro at the back)? Is your X-tank of the newer design with the recessed base above the sprocket?
I could go on forever, please - more details, and pics!
Bli55 is offline   Reply With Quote
Old 02-07-2013, 08:39 PM   #81
Bob
Formerly H20Pumper
Bob's Avatar
Oddometer: 2,571
Thanks for posting the trip and pictures.
Bob is offline   Reply With Quote
Old 02-09-2013, 02:06 PM   #82
Phreaky Phil
Oddometer: 1,758
Thanks for posting, I have really enjoyed your report. I have a question regarding your Britania Comp headlight. I have read a few reports over turbulence/ buffeting/ wind noise creared by it and I thought your opinion would be valuable as you have done some miles with it.
Cheers Phil
Phreaky Phil is offline   Reply With Quote
Old 02-13-2013, 08:36 AM   #83
mikecbrxx OP
mikecbrxx's Avatar
Oddometer: 193
Cheers Phil
Hi Phil
When I first fitted the unit I did get some buffeting at speeds 120+kph. However, that was in fairly strong winds anyway. We have changed the geometry on my bike so it suits me and now, unless the weather is bad or there are other contributing factors, I haven't noticed any buffering at all. However, I don't usually travel over 140kph....and then only to get to the good riding places
As for noise....get better earplugs or turn the music up
Old 02-13-2013, 08:51 AM   #84
mikecbrxx OP
mikecbrxx's Avatar
Oddometer: 193
Originally Posted by Bli55 View Post
mikecbrxx, trip!
I'll try and post some more pics when I have time.....real busy at work atm. You can see loads more pics here in my Picassa album.
But to answer your questions, yes it was a 47 tooth sprocket and I did have a recess above the sprocket. (chain guard removed). Having said that, I had an early recess model. Several people had a problem and it has been re-designed to give more room. Erik repaired my X-Tank to the new spec.
As for what caused it.....go ride the 'main' road between Aktobe and Atyrau in Kazakhstan....try and stay on the road rather than take the side track, and ride fast enough to do the 650kms in a day. It would be easier to ride across a bombing range.
Old 02-13-2013, 01:51 PM   #85
Twinmike
Grandpa
Twinmike's Avatar
Oddometer: 138
gpx track
Hi mikecbrxx
very helpful RR for me,
thank you for the gpx file and the pois, im also planning a trip to mongolia and sibiria 2014 or 2015
Twinmike is offline   Reply With Quote
Old 02-13-2013, 09:01 PM   #86
Phreaky Phil
Oddometer: 1,758
Hi Phil
Thanks for your reply. After playing around with various screens on different bikes over the years I have gotten a bit anal over windscreen created noise and buffeting. Even with earplugs in you can still hear a lot of the noise created by them (ever ridden a 990KTM, they are bad ) and currently have the stock headlight on my DR650, figured a screen vwasnt necessary on the TAT as it was mainly off road. But on the highway you get a lot of wind in the chest, which is tiring. The Brittania Composites unit looks cool and gives options for instuments to be mounted where they are easier to be seen and probably better headlights.
Cheers Phil
Old 02-14-2013, 01:59 AM   #87
mikecbrxx OP
mikecbrxx's Avatar
Oddometer: 193
Thanks for your reply. After playing around with various screens on different bikes over the years I have gotten a bit anal over windscreen created noise and buffeting. Even with earplugs in you can still hear a lot of the noise created by them (ever ridden a 990KTM, they are bad ) and currently have the stock headlight on my DR650, figured a screen wasn't necessary on the TAT as it was mainly off road. But on the highway you get a lot of wind in the chest, which is tiring. The Britannia Composites unit looks cool and gives options for instruments to be mounted where they are easier to be seen and probably better headlights.
Cheers Phil
The headlights are certainly better. However, take the HID option. I didn't.... but have since changed. I say that more due to the reduced power consumption rather than significantly better lighting. The 35w HID (6000k) is about the same as the 65w halogens IMHO and a better color.
As you will be aware, the units in the Lynx are 90mm standard fitting so.... can be changed easily. I am now looking closely at LED's, though am disappointed at what is available right now. The Duo-Lux appears to be the best of what is available....and its expensive.
To compensate, I am considering fitting either a pair of the new, larger, VisionX LED Aux lights or a pair of the triple LED's also from VisionX.
As for noise off the fairing, I rarely ride with earplugs at all....so the noise off the fairing can't be that bad.
Old 02-14-2013, 02:02 AM   #88
mikecbrxx OP
mikecbrxx's Avatar
Oddometer: 193
Originally Posted by Twinmike View Post
Hi mikecbrxx
I'm going back in 2014. Preparing an XC for my wife now. Don't think I will go through Mongolia due to time but I want to visit Tuva, the western BAM and old summer road. Unfortunately I am not retired yet (and am self employed) so have to watch the amount of time I take Taking 3 months is just a dream.
Old 02-14-2013, 04:20 AM   #89
Mara Loochezarny
Mara Loochezarny's Avatar
Oddometer: 135
Good trip! Nice photos! and familiar places))
Always have a good trip!
http://silkoffroad.kz - Motorcycle tours and rent in Central Asia (Kazakhstan,Uzbekistan,Tajikistan,Kyrgyzstan,Turkmenistan,
Mara Loochezarny is offline   Reply With Quote
Old 02-14-2013, 04:32 AM   #90
mikecbrxx OP
mikecbrxx's Avatar
Oddometer: 193
Welcome. Your company hired a bike to one of the original group in Almaty.....a girl. I forget her name. She was going down into the Stan's with her boyfriend.
Times are GMT -7.   It's 10:23 PM.
