07-09-2012, 10:49 AM
#31 |
Back Home
Oddometer: 1,546
200 miles in the dirt
Just can back for riding 200 miles in the dirt. The bike performed flawlessly - power was smooth and very controllable with no low end snatchyness. I think I may drop a tooth (46 -> 45) on the rear when its time to change the sprocket a result of this modification.
07-09-2012, 11:59 AM
#32 |
Rough Rider
Oddometer: 825
Copy $ Copy $
Well you spent the time and $$$ to get this tuning together.
I'd be happy to pay for a copy to help you off set your costs. Max
Da oggi la strada é senza limiti |
07-10-2012, 07:21 AM
#33 |
Back Home
Oddometer: 1,546
Now that I'm home I just need to get some time to hookup TuneECU - I'll interested to see what was changed from the standard Akrapovic map.
07-10-2012, 07:35 AM
#34 |
Positating the negative
Oddometer: 73,600
Do these things work on the 950s?
"So what you gonna do when the novelty is gone.."-- Joy Division Same as it ever was 2010 Latin America Route |
07-10-2012, 07:45 AM
#35 |
Back Home
Oddometer: 1,546
They do http://advrider.com/forums/showpost....9&postcount=76
Someplace on ADVrider I've even seen info on re-jetting too - bet CJ know where |
07-10-2012, 07:51 AM
#36 |
Oddometer: 73,600
Thanks! I was considering going the pre-filter route but this seems like a better option to me.
07-10-2012, 08:10 AM
#37 |
newoldguy
Oddometer: 17
I did basically the same mods to my Superduke, installed the CPR Rottweiler intake, removed SAS, removed secondary butterflies and shafts, added RC8 velocity stacks, O2 eliminators, and FMF Apex exhaust. I plugged the breather hole in the CPR base plate and routed my breather hose to a small filter instead of dumping oily fumes back into the intake. Tuned with TuneECU and pulled 121hp and 75.5 torque on the dyno. Smoothed out low end jerkiness (combined with a G2 throttle tamer), improved rideability greatly, revs quicker, and absolutely screams to redline. Like the original post said, saved a bunch of weight too, all the smog crap weighed 10lbs.
R1200GSSuperdukeXR650L |
07-10-2012, 04:19 PM
#38 | |
Lost again
Oddometer: 3,514
Very easy to install, jetting is pretty straightforward and easy to clean. Power increase is very noticeable and for some reason, my fuel economy has gotten better ![]() ...now if it only cooked and did the dishes....
DRCOOL rides with me |
07-10-2012, 06:07 PM
#39 |
Oddometer: 989
The CPR set up is so much better I don't they are even comparable. The pre filter clogs up in one day in dusty conditions and is a restriction that takes away power. The CPR is one of the best aftermarket pieces I have added. It is really a nice upgrade.
'06 950 Adventure S '10 Husaberg FX 450 '01 KTM 520exc |
08-05-2012, 01:50 PM
#40 |
Oddometer: 29
How did you install the PVC ball valve on the CPR plate, cannot find any instructions for disassembly or mounting.
Thanks, Jim |
08-05-2012, 08:26 PM
#41 |
Oddometer: 29
Figured it out
Jim |
08-05-2012, 09:07 PM
#42 |
Back Home
Oddometer: 1,546
The PVC is made of two parts screwed together with a ball in between. All you have to do is put a wrench on each end and unscrew it. Once its unscrewed you will have two halves so just mount the baseplate in between when you screw the halves back togeather. Make sure you keep the end that was connected to the engine on the outside of the base plate when you install it.
08-05-2012, 09:24 PM
#43 |
Oddometer: 421
Will the filter compromise water crossing depth?
This one was over my knees standing (when I walked back across to help some of the MX bikes across) and over the header on the SE, ![]() Is that a fair assumption?
'10 Multistrada 1200 Std ('11 - current) '07 Super Enduro 950 ('12- current) '02 Superhawk (37k miles, '02-'11) '96 KLX250R - kind of street legal - ('97 - current) '90 KLR 650 Tengei ('95-'97) |
08-06-2012, 04:58 AM
#44 |
Oddometer: 362
08-06-2012, 12:10 PM
#45 |
AWD please!!
Oddometer: 3,864
If you have a Uni Pre-filter (removed Snorkel), this setup is no lower than that. Of course if you fall over it won't matter anyways.
![]() The gage that I use is the bottom corner of my Seat "V". Or, if the front fender is under water you are getting very close. Depending on how tall your bike is, that's pretty deep. Slow and steady as to not to cause too large of a bow wake. On my 950 ADV S, the base plate is about 35" high. So, if I walk a water crossing and my nuts get wet..... I might want to try and find a way around or inflate some pontoons.
My 2006 950S thread. 2006 950s updateNew product updates here! Wordpress BLOG click www.cjdesignsllc.com for the full line of products. www.outriderjournal.com FREE STUFF!! |
