Go Back   ADVrider > Fluff > Shiny Things
Thread Tools Rating: Thread Rating: 181 votes, 4.94 average. Display Modes
Old 01-22-2009, 11:50 PM   #601
Iron socks
Son of a BSA
Iron socks's Avatar
Oddometer: 285
Originally Posted by 100mpg
mmmm...ok. that would be good too, but the 10,000 RPM sound is what I want to hear!
you can't make lightning strike twice, but you sure can stand in a field with a 4 foot length of rebar.
Iron socks is offline   Reply With Quote
Old 01-22-2009, 11:57 PM   #602
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 103,027
Old 01-23-2009, 12:06 AM   #603
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,686
Originally Posted by Gimpinator
Here's what I'm currently up to with mine. Any guesses?
Here's a hint: It involves making very accurate plots of valve motion with a laser. I'll be done building this beast in about two weeks. It can go beyond 10K rpm if I am ATGATT.
You're channeling Mr. Yunick.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 01-23-2009, 08:10 AM   #604
Gimpinator
This is my Mom's cat
Gimpinator's Avatar
Oddometer: 1,173
That would be true! The difference is that I'm doing it with a portable package. It's also a dyno so I'll be able to measure parasitic valvetrain torque. It will be a nice instrument for studying any OHC heads, including motorcycles.
There's a Ducati 749 head on the bench, just waiting for a shot. The fixture is also currently set up to run Ford Modular heads. I'll be building adapters to run pushrod heads in the near future as well.
Gimpinator screwed with this post 01-23-2009 at 09:38 AM
Gimpinator is offline   Reply With Quote
Old 02-12-2009, 07:27 PM   #605
FloridaSteve
FloridaSteve's Avatar
Oddometer: 2,082
Originally Posted by muddywater
4 cylinder triple????
Yes. Built By a fellow named Jim Knight in Tennessee. It's a 750 triple with an extra cylinder. It's flawless. I crawled under it and you can just make out the welded seam down the middle.
FloridaSteve is offline   Reply With Quote
Old 03-03-2009, 02:57 PM   #606
ilmostro
Under Da Sea
ilmostro's Avatar
Oddometer: 29,256
bump
I've got stay the fuck out of it written on a stone tablet in my bedroom. - Con Stapleton
ilmostro is offline   Reply With Quote
Old 03-03-2009, 03:00 PM   #607
Motociclista
Custom User Title
Motociclista's Avatar
Oddometer: 14,462
That thing must move like a hurricane ...
Fred
Motociclista is offline   Reply With Quote
Old 03-03-2009, 03:09 PM   #608
earwig
Crowbar of Embrayage
earwig's Avatar
Oddometer: 4,726
earwig is offline   Reply With Quote
Old 03-03-2009, 03:20 PM   #609
DirtDOG
Same Dog, New Tricks
Oddometer: 17,755
DirtDOG is offline   Reply With Quote
Old 03-03-2009, 03:40 PM   #610
EvoLife
Evolving.....Slowly
EvoLife's Avatar
Oddometer: 982
Real Rotary engine
Not that Wankel thingy. A Gnome.
The cylinders rotate around the crank. The fuel/ air mixture travels through a pressurized crankcase, through the copper tubes to the intake valve.
"If what you are doing isn't working, don't try harder, try different."
"Today I'm younger than I'm ever going to be, and I intend to act like it"
EvoLife screwed with this post 03-03-2009 at 04:01 PM
EvoLife is online now   Reply With Quote
Old 03-03-2009, 03:45 PM   #611
EvoLife
Evolving.....Slowly
EvoLife's Avatar
Oddometer: 982
Wow! Got that wrong! The intake valve is in the piston and opens by the vacuum generated on the intake stroke. The low pressure in the cylinder pulls the fuel/air mixture through the piston from the crankcase. The copper tubes must be exhaust.
More Here
That top photo's a different design. It's got intake and exhaust valves in the "head" with a rocker and pushrod.
EvoLife screwed with this post 03-03-2009 at 04:00 PM
Old 03-03-2009, 04:03 PM   #612
EvoLife
Evolving.....Slowly
EvoLife's Avatar
Oddometer: 982
For most of the World War One, rotary engines like the Le Rhone were the lightest available for a given horsepower. An improved version of the Gnome rotary, the Le Rhone featured nine cylinders rotating around a fixed two-piece crankshaft. Its costly design used nickel and special alloy steel cylinders around pressed-in cast iron liners, with copper inlet manifolds and intake/exhaust valves driven by a single pivoted rocker arm. With no carburetor or throttle, it was normally run wide open. To vary the speed, the ignition was intermittently cut via a "blip switch" on the control column.
EvoLife screwed with this post 03-03-2009 at 04:11 PM
Old 03-08-2009, 08:48 AM   #613
FloridaSteve
Oddometer: 2,082
Old 03-08-2009, 10:06 AM   #614
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,728
Wondering if this should have been posted in old timey things instead.
Yes, it still runs on the crap gas in the tank.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 03-13-2009, 10:41 PM   #615
roadholder
roadholder's Avatar
Oddometer: 2,538
Triple expansion steam engine from RMS Titanic.
Can still be viewed today...with a little effort!
roadholder is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 04:38 PM.
