04-24-2009, 04:56 PM
#691 | |
1.5 Finger Discount
Oddometer: 20,081
"Try turning that burn into torque. Then we're getting somewhere. Riding the potato to work seems quite impractical." - anotherguy "Never bring a Nerf gun to a shovel fight." - My Brother |
04-25-2009, 01:26 PM
#692 | |
zipper suited sun god
Oddometer: 1,348
Please enlighten us on why the Corvair is a poor candidate for a flight engine. Ready to fly, it is substantially lighter than a Continental O-200 and it makes more thrust as proven with dynomometer testing. It has a forged crank and rods, and forged pistons are installed in flight engines. It is heat tolerant and durable, with a factory CHT redline of 575 F. With the addition of a 5th bearing on the front of the case (not pictured on my engine, but one resides there now), propeller loads are supported for even greater crankshaft reliability. The dual coil/dual point distributor ignition has been failure free since it's development by William Wynne. Dual plugs are not needed in a small bore, high compression, six cylinder engine. Modern Viton o-rings and better quality gaskets make for leak free engines. It's a real airplane engine. Period. The Corvair engine has been flying since the Corvair was introduced in 1960. |
04-25-2009, 01:58 PM
#693 | |
Two-Bit Throttle Bum
O.K. Joke's over. You can bring back the constitution now. Please. My Wyoming has an East infection. http://motornoggin.smugmug.com |
04-26-2009, 08:36 PM
#694 |
Oddometer: 4,157
Honda 350
04-26-2009, 08:38 PM
#695 |
Oddometer: 4,157
500 Triumph
06-23-2009, 01:09 PM
#696 |
Oddometer: 2,070
A few from a recent motorcycle show I attended.
Ariel Square Four ![]() Vincent ![]() Twin Engine KZ1000
My Blogs: Higher Resolution Photo Album Motorcycle Photo of the Day 2-Stroke-Biker-Blog FloridaSteve screwed with this post 06-23-2009 at 01:20 PM |
06-23-2009, 01:15 PM
#697 |
40-128
Oddometer: 12,300
The road to Hell is paved... Save $5 on a Smugmug subscription when you use my coupon: yBr7OofIPuOP6 KLR takes a circular route to Big Bend '13 http://advrider.com/forums/showthread.php?t=887449 |
06-23-2009, 01:16 PM
#698 |
40-128
Oddometer: 12,300
06-23-2009, 01:24 PM
#699 |
Oddometer: 2,070
Millard V12
My Blogs: Higher Resolution Photo Album Motorcycle Photo of the Day 2-Stroke-Biker-Blog |
06-23-2009, 06:31 PM
#700 |
commutingmysentence
Oddometer: 15,901
06-23-2009, 06:43 PM
#701 |
Oddometer: 276
Those wacky Hansen Honda guys
Feed Your Head |
06-23-2009, 07:01 PM
#702 |
Air cooled runnin' mon
Oddometer: 6,112
Twin plug Hemi..
I used to be indecisive. Now I'm not so sure. "You only have too much fuel if you're on fire" unknown |
06-23-2009, 07:10 PM
#703 |
Oddometer: 1,078
1500cc, 4-cams, 48mm diameter intake valves, twin plugged, hemi,
125 hp at 7500 RPM circa 1956
06-24-2009, 06:45 PM
#704 | |
Red Clay Halo
Oddometer: 11,204
You forgot to add "levitating" to the list.
Maybe Old's Cool is a bunch of dirty old men who swear because , let's face it, old bikes run on blasphemy as much as they do gasoline and oil. --Jinx You can be Han Solo, and I can be another Han Solo... |
06-24-2009, 06:54 PM
#705 |
befuddled
Oddometer: 8,148
Stuart triple expansion steam engine.
STURGIS ride report. 2009 R1200 Gelände/Straße Abenteuer A GS is like chlamydia, it grows on you whether you want it to or not. WhiteManFlail Save $5 on Smugmug "1alkVgTNLEuyQ"
| Thread Tools | |
