Thread Tools Rating: Thread Rating: 156 votes, 4.94 average. Display Modes
Old 07-03-2009, 06:34 AM   #721
100mpg
Self Imposed Exile
100mpg's Avatar
Oddometer: 17,567
Originally Posted by Wheedle
WTF IZZAT!!!!
edit
holy crap, is that a 4 cyl 2 stroke? from what planet?
100mpg is offline   Reply With Quote
Old 07-03-2009, 08:23 AM   #722
Gimpinator
This is my Mom's cat
Gimpinator's Avatar
Oddometer: 1,121
WTF IZZAT!!!!
It looks like a large outboard motor powerhead (v-4) mounted into a motorcycle frame. Pretty cool!
Gimpinator is offline   Reply With Quote
Old 07-03-2009, 09:17 AM   #723
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,430
Not as exotic, but still pleasing to the eye.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is online now   Reply With Quote
Old 07-03-2009, 09:25 AM   #724
cagiva549
whats a cagiva
Oddometer: 2,454
Nice 409 , only took 49 pages for one to show up . the 348 truck engine was top shelf fifty years ago , SEYA
David H
00 Cagiva GC
04 9 fiddy
05 ST3 duck
07 KTM 450 EXC
86 Goldwing my geezer ride
cagiva549 is offline   Reply With Quote
Old 07-03-2009, 10:45 AM   #725
mud
I just wander.....
mud's Avatar
Oddometer: 1,772
Originally Posted by FloridaSteve
2 stroke porn..
Is that a six cylinder?????? There is a funny carb hiding in the frame member......
2007 Factory Husaberg 380FE
2007 Montesa 4rt
1984 Husqvarna 500AE
mud is offline   Reply With Quote
Old 07-04-2009, 08:28 AM   #726
vtwin
vtwin's Avatar
Oddometer: 7,430
2 stroke porn..
What's with that little belt hanging off the side?
Monroe.
unknown
Old 07-04-2009, 08:42 AM   #727
xlcr
Stop being a dick, dick.
xlcr's Avatar
Oddometer: 4,895
Water pump drive. Appears to be driven off the alternator rotor.
xlcr is offline   Reply With Quote
Old 07-04-2009, 08:48 AM   #728
xlcr
xlcr's Avatar
Oddometer: 4,895
Looks like 3 disc-valve singles sandwiched between two alloy plates and all driving an intermediate shaft.
Old 07-04-2009, 08:57 AM   #729
vtwin
vtwin's Avatar
Oddometer: 7,430
I'm learning how to make a 427 SOHC live at insane rpm.
Here's what 9,000 rpm sounds like. Sweet! I could listen to that all day. 10,000 rpm still, um, needs a bit of work!
The spring gets super hot at that rev level. When the bolt pulled out oil started gushing onto the hot spring. When I saw the smoke I shut her down immediately... No damage except for a few stripped threads. We will fight another day.
Was it a matter of the bolt not being torqued down? It seemed to unspin before it stripped the rest of the threads out. Nice videos.
Monroe.
unknown
Old 07-04-2009, 09:43 AM   #730
Andrew
Optimus Primer
Andrew's Avatar
Oddometer: 15,650
Tell us about your image capture setup.
Splitting lanes, and splitting hairs.
Andrew is offline   Reply With Quote
Old 07-04-2009, 09:51 AM   #731
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 33,981
[IMG]http://i103.photobucket.com/albums/m135/rdkingryder/036-2.jpg[IMG]
I met Jay up at Alices five or six years ago. He was on his Sportster engined cafe racer. He told me about his Jag engined Corvair and the 2/3 scale Ford he was building. I saw it up there a few years later. He also has a V-16 Marmon.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 07-04-2009, 11:16 AM   #732
Gimpinator
Gimpinator's Avatar
Oddometer: 1,121
I'm just using a digital stroboscope and a Canon Powershot at 30 frames/second. The stroboscope is the key. It can handle up to 10 kHz, which is 20,000 crank rpm. Interestingly, 30 frames/sec looks cleaner than 60 frames/sec. Must have something to do with the camera's native (optimal) setup.
I typically process the raw video through a custom video editor that I hired a guy to write. If the program sees a completely black frame (from the strobe being off at that moment) it replaces the black with the average of the frame before and the frame after. At higher speeds it's rare to get a totally black frame though, since the strobe is pulsing so fast.
Now for the bolt failure. The root cause is not enough thread engagement plus soft aluminum in the head casting. It did turn, but also stripped out a few threads. A Helicoil and longer bolts are the fix.
Old 07-04-2009, 11:22 AM   #733
DELTATANGO
Motorcyclist and Dog Walk
DELTATANGO's Avatar
Oddometer: 13,872
That is really interesting. Look at how the valve bounces.
Is it bouncing/floating enough to open it?
DELTATANGO is offline   Reply With Quote
Old 07-04-2009, 12:33 PM   #734
Gimpinator
Gimpinator's Avatar
Oddometer: 1,121
Yup! Here's a plot I made using a precision laser to measure the valve event at high speed
The orange part of the curve at 7200 rpm shows the valve bouncing off the seat several times. This lets intake charge back out into the manifold during the compression stroke, killing power.
I'll be buying one of these lasers as soon as I can rub a few more shekels together. It's expensive but the results are worth it!
Old 07-04-2009, 12:52 PM   #735
DELTATANGO
DELTATANGO's Avatar
Oddometer: 13,872
Wow. So that is a perfect illustration of valve float.
Neat. Thanks.
Thread Tools
Times are GMT -7.   It's 08:56 PM.
