Thread Tools Rating: Thread Rating: 166 votes, 4.94 average. Display Modes
Old 02-15-2012, 09:39 PM   #1186
diethornig
diethornig's Avatar
Oddometer: 10
Nice tank... Can you make mine?
diethornig is offline   Reply With Quote
Old 04-15-2012, 10:19 AM   #1187
andruboz
Serial overfiller
andruboz's Avatar
Oddometer: 5,412
this might get my colorado down the 1/4 faster than 17 sec.
2.7l 350-400hp.-probably less on pump gas. redlines around 9000.
might have a problem bolting up a bellhousing since midgets don't run much in the way of transmissions..
A good folly is worth whatever you pay for it.
andruboz is offline   Reply With Quote
Old 04-15-2012, 04:21 PM   #1188
Motornoggin
Two-Bit Throttle Bum
Motornoggin's Avatar
Oddometer: 21,197
Small block Chevy I'm building for a future project.
Started out as a garden variety 2bbl grandma car engine, 71' vintage.
Now:
Ported and decked heads with new valves and HP springs.
Nasty hydraulic cam.
.040 overbore with flat top pistons.
Decked block.
Dual quad intake with a pair of 500cfm carbs.
Shoud make 350+ hp.
O.K. Joke's over. You can bring back the constitution now. Please.
My Wyoming has an East infection.
http://motornoggin.smugmug.com
Motornoggin is offline   Reply With Quote
Old 04-16-2012, 04:09 AM   #1189
12ARX
12ARX's Avatar
Oddometer: 1,435
In 1986, Lancia Triflux motor developed for the ECV2. This incorporated a new type of engine, a twin turbocharged 600HP 4 cyl using only 1.8L displacement.
Technical specification
Engine - Centrally mounted, longitudinal with 4 cyl inline. 1795CC. Bore x stroke, 88.5mm x 71.5mm Triflux' double reverse flow cylinder head with 4 valves/cylinder and twin overhead camshafts. Compression ratio, 7.5:1. 600bhp @ 8000rpm.. 55mKg@5000rpm. Twin KKK (K26 type) turbochargers with individual intercoolers. Weber/Magnetti Marelli injection/ignition with electronically controlled turbocharging level. Dry sump lubrication with pressure and extraction pumps and air/oil radiators.
Transmission - Four-wheel drive. Epicyclic train torque converter with viscous coupling and ZF differentials rear. Carbon fibre/Kevlar drive shafts. Provision for locking the central torque distribution (30/70, front/ rear). Twin-plate clutch with metal-ceramic friction gaskets. Five speed gearbox longitudinally mounted at rear.
Current Ride:
09 DR650SE
12ARX screwed with this post 04-16-2012 at 04:17 AM
12ARX is offline   Reply With Quote
Old 04-16-2012, 04:11 AM   #1190
12ARX
12ARX's Avatar
Oddometer: 1,435
Current Ride:
09 DR650SE
Old 04-18-2012, 02:38 PM   #1191
12ARX
12ARX's Avatar
Oddometer: 1,435
Current Ride:
09 DR650SE
Old 04-22-2012, 07:00 AM   #1192
dagwood
dagwood's Avatar
Oddometer: 35,427
Originally Posted by 12ARX View Post
still trying to figure this out.
dagwood is offline   Reply With Quote
Old 04-22-2012, 07:37 AM   #1193
EvoLife
Evolving.....Slowly
EvoLife's Avatar
Oddometer: 945
Looks like a fuel injected W16 to me.
"If what you are doing isn't working, don't try harder, try different."
"Today I'm younger than I'm ever going to be, and I intend to act like it"
EvoLife is offline   Reply With Quote
Old 04-22-2012, 07:50 AM   #1194
AWM
Beard Bros Racing
AWM's Avatar
Oddometer: 11,383
"Hes not called the Angry White Man for nothing,much more fitting then the,Unicorn Clouds and Happy Trees Man".... UpST8
Theres a name for people without beards,"Women".
AWM is offline   Reply With Quote
Old 04-22-2012, 12:18 PM   #1195
Wadester
Rides a dirty bike
Wadester's Avatar
Oddometer: 2,068
They're both of the same type - exhaust exits to either side of the head, valves are cattycorner from each other, giving a swirl effect. Problem is getting the intake down the middle along with the spark plugs.
Too much trouble for general production, high end racing only.
Two roads diverged in a wood, and / I took the one less traveled by, and / now where the hell am I?
This isn't a "you're doing it wrong" topic. (Originally Posted by Human Ills, 7/1/14)
Wadester is offline   Reply With Quote
Old 04-22-2012, 04:48 PM   #1196
Ridemuch
SUP
Ridemuch's Avatar
Oddometer: 2,266
Not sure if it's been on here before but I found a great web site about all types of engines.
http://www.animatedengines.com/
"Ya Rob, well she either gets used to the fact that I ride pretty much every weekend or she needs to find herself another boyfriend" KTMike
"There is no bad weather, only bad gear." Dahveed
Ridemuch is offline   Reply With Quote
Old 04-22-2012, 05:00 PM   #1197
dorkpunch
Oops...
dorkpunch's Avatar
Oddometer: 5,346
I use that in the engines class I teach- LOTS of cool info. Students also seem to like this one too: http://www.animatedpiston.com/Home.htm Not as many engines, but pretty good animations!
http://www.mobilemrt.com http://www.dorkpunch.com
"I've been going to this high school for SEVEN YEARS. I'm no dummy!"
-Charles De Mar.
dorkpunch is offline   Reply With Quote
Old 04-22-2012, 05:54 PM   #1198
12ARX
12ARX's Avatar
Oddometer: 1,435
Repco V8 with double reverse flow heads -
Current Ride:
09 DR650SE
Old 04-23-2012, 12:48 PM   #1199
crampfan
not really a nOOb
Oddometer: 2,580
http://www.youtube.com/watch?v=coXB3...eature=related
crampfan is offline   Reply With Quote
Old 04-24-2012, 06:13 PM   #1200
ttpete
Rectum Non Bustibus
Oddometer: 5,989
It appears to be a stagger-valve just like the Lancia Triflux except that it's a V8. The idea behind the valve arrangement is that there are never two exhaust valves side by side, which means that there's less of a problem with heat distortion or cracking between the valve seats.
The interesting thing about the Repco is that it's based on the block of the 215 cid Buick aluminum V8 of the 1960s. It was designed by Phil Irving, who also designed the post war Vincent motorcycle engine. It was good enough to win an F1 world championship.
15 BMW RnineT
09 Kaw Versys
Thread Tools
Times are GMT -7.   It's 10:51 PM.
