Go Back   ADVrider > Fluff > Shiny Things
Thread Tools Rating: Thread Rating: 180 votes, 4.94 average. Display Modes
Old 11-25-2012, 10:57 AM   #1366
ragtoplvr
Oddometer: 6,634
I think this is a polyurethane or polypropylene with aramid. these are impervious to oil. Ford has specified a special oil, there might be some bad additives that kill the belt you I would use the right stuff.
Rod
ragtoplvr is online now   Reply With Quote
Old 11-25-2012, 12:09 PM   #1367
broncobowsher
broncobowsher's Avatar
Oddometer: 1,885
Rod
You might, the other 99% of the public will just put in whatever oil they want. Wouldn't be the first time a Ford had issues with oil requirements. I can think of some powerstroke diesels that wouold not run right unless they were fed the special antifoaming oil.
This is one of those times I might just take that extended powertrain warranty...
broncobowsher is online now   Reply With Quote
Old 11-25-2012, 12:40 PM   #1368
ttpete
Rectum Non Bustibus
Oddometer: 6,159
"Wet" belts have been around for years. Nothing new, it's just a new application. Ford's been specifying oils for their engines for over a decade, and it's because the engines have been designed to use a specific viscosity rating and additive package. This particular engine has 12K mile change intervals. The problem is that everyone seems to think that they know more about lubrication than the people who designed the engine, and they use their own version of snake oil, then blame the company when it takes a dump.
2015 BMW R9T, 2010 Ducati 1098 Streetfighter S
2009 Kaw 650 Versys, 1967 Triumph 650 TT Special
Old 11-25-2012, 01:09 PM   #1369
ragtoplvr
Oddometer: 6,634
There may be some quicky lube lawsuits. I know of one sucessful VW diesel. lawsuit against a quicky lube place for the special VW oil not being used, and another where a oil filter came apart, plugged the piston jets and blew a dodge cummins diesel.
You use the right stuff, and have no problems good for you. Don't change it at all, like a coworkers kid did, or use the wrong stuff, too bad so sad.
I am fond of saying, you can not idiot proof anything, they keep making better idiots.
Rod
Old 11-25-2012, 01:35 PM   #1370
ttpete
Rectum Non Bustibus
Oddometer: 6,159
Rod
I just got a bulletin from Ford saying that some aftermarket filters had come apart and clogged the oil feed to the camshafts. They weren't specific as to which brand, but I suspect it's one of the cheaper ones, maybe made in China.
My dealer is a half mile away and has a quick oil change facility, so I get it done there using OEM oil and filters.
Old 11-25-2012, 04:50 PM   #1371
Nailhead
Free at last!
Nailhead's Avatar
Oddometer: 6,328
What if the right stuff isn't available? What do you do then? Such specialized requirements can be a real pain-in-the-ass out here where things are so few & far between.
-Chris
'7? Benelli 650S, '80 BMW R100 RS, '93 Ducati 900 SS, '07 KTM 990 Adventure
Nailhead is offline   Reply With Quote
Old 11-26-2012, 09:26 AM   #1372
Hughlysses
Hughlysses's Avatar
Oddometer: 3,434
As long you're aware of the requirement and you're concientious it's not a big deal. Case in point- 2006 VW TDI with "pump deuse" engine. You HAVE to use VW spec oil and the only place I've ever found the oil that meets this spec is the local VW dealer. The owner's manual actually cautions you that this oil is hard to find and recommends that you always keep an extra quart in the car, so that's what I've done since I bought the car. I haven't needed that extra quart in 100k+ miles, but I make sure I have it.
That said, I'm sure there are plenty of TDI owners that never opened the owner's manual and dumped whatever was available in the crankcase if they needed a quart.
2007 Buell XB12X Ulysses
1983 Honda VT500FT Ascot
Hughlysses is offline   Reply With Quote
Old 11-27-2012, 07:57 AM   #1373
Andrew
Optimus Primer
Andrew's Avatar
Oddometer: 15,957
Splitting lanes, and splitting hairs.
Andrew is offline   Reply With Quote
Old 11-27-2012, 11:18 AM   #1374
Hughlysses
Hughlysses's Avatar
Oddometer: 3,434
I give up, what is it?
Old 11-27-2012, 11:59 AM   #1375
Jeffy
Hmm...
Jeffy's Avatar
Oddometer: 5,419
Looks like a close up of a valve being ground.
"I'm going to shift gears now.... This will involve man touching." - Jeremy Clarkson
Jeffy is online now   Reply With Quote
Old 11-27-2012, 12:29 PM   #1376
Andrew
Optimus Primer
Andrew's Avatar
Oddometer: 15,957
just trying to steer the thread back on course...
Old 11-27-2012, 01:13 PM   #1377
Motocicletta
ridetowork
Motocicletta's Avatar
Oddometer: 581
Please tell More...
Originally Posted by anotherguy View Post
What is it? It is from the Arpilia forum, upside down, air cooled?
motocicletta
Santa Monica, CA
'88 R100GS
Motocicletta is online now   Reply With Quote
Old 11-27-2012, 01:27 PM   #1378
Hughlysses
Hughlysses's Avatar
Oddometer: 3,434
Ahhh, now I see it, and I recognize the gizmos above.
Old 11-27-2012, 02:25 PM   #1379
Jeffy
Hmm...
Jeffy's Avatar
Oddometer: 5,419
Old 11-27-2012, 06:02 PM   #1380
Trixie
No, not that Trixie
Trixie's Avatar
Oddometer: 3,691
Hmmm...my buddy has on old V-12 flattie from his '41 Lincoln project that I might try to grab....that or the glass-top rifle case for man-town downstairs.
Buy my 1150 GS: http://www.advrider.com/forums/showthread.php?t=1049311
Trixie is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 06:55 PM.
