12-03-2012, 04:34 AM
#1396 |
Oddometer: 4,357
The article I read referenced a piston wear rate of .03MM per 1000 hours. Don't know what is considered worn out on something like that.
When injustice becomes law,resistance becomes duty. Thomas Jefferson |
12-03-2012, 01:59 PM
#1397 | |
Adventure Connoiseur
Oddometer: 2,929
How about this V-16? 640 bhp @ 11,500 rpm. Crafted from 4 Yamaha 1000's.
12-03-2012, 02:25 PM
#1398 |
Rectum Non Bustibus
Oddometer: 3,641
One of the Navy ships I served on was diesel engined. Two 3000 hp 9 cylinder Nordbergs. We never changed oil, but we ran continuous purification on it through DeLaval centrifugal oil purifiers.
10 Ducati 1098 Streetfighter S - "Sleipnir" 09 Kaw Versys "The problem with Socialism is that you eventually run out of other people's money" _____ Margaret Thatcher |
12-03-2012, 03:31 PM
#1399 | |
Oddometer: 4,600
Rod |
12-03-2012, 03:43 PM
#1400 |
Oddometer: 895
ship will probably be scrapped before the engine needs an overhual
1998 Honda Helix 1989 Honda Pacific Coast 2000 westward Go-4 1982 Bluebird wanderlodge |
12-03-2012, 04:06 PM
#1401 |
Rectum Non Bustibus
Oddometer: 3,641
We had a spare cylinder sleeve and piston hanging on the after engine room bulkhead. There were chain fall tracks over each engine.
12-04-2012, 09:02 PM
#1402 |
Careening forward
Oddometer: 5,734
My red brick after a complete rebuild and getting ready to plug it back into my 1800S. Before and after.
![]() ![]() GT 40 engine at the Cobra Museum in Boulder. ![]() In Situ ![]() 429 ![]() ![]() SAAB Rally car
2003 KLX 400R dual sport |
12-05-2012, 03:52 PM
#1403 |
the slow one
Oddometer: 68
Let's ride bikes!
12-05-2012, 05:11 PM
#1404 |
Minister Funny Walks
Oddometer: 1,024
Actually that's an FE Series engine - most likely a 428 between the fenders of what looks to be a Shelby GT 500 Mustang.
The GT-40 engine up top has a reproduction Shelby block. You can tell because the Shelby blocks have two side bolts per cap, where original Ford 427 blocks only have one. Yeah I know... Call me the Klay of Ford engines. I'm a detail Nazi - Eeet must be correckt!
"Son, I thought by now you would have run out of stupid." |
12-05-2012, 05:41 PM
#1405 | |
Oddometer: 471
12-05-2012, 08:00 PM
#1406 | |
Careening forward
Oddometer: 5,734
http://102449.smugmug.com/Other/Shel...6640211_wPj3xT
12-06-2012, 08:17 AM
#1407 | |
Rectum Non Bustibus
Oddometer: 3,641
At the time that Ford was competing with these engines, I was working for the company in a research area. I saw the 3 valve heads that would have gone to LeMans if the French hadn't changed the rules to prohibit the big engines. The flow lab boss said they were flowing 550 CFM per cylinder.
12-06-2012, 08:32 AM
#1408 |
Oddometer: 245
12-06-2012, 10:43 AM
#1409 |
Oddometer: 1,024
^^^^ Kaase!! ^^^^
http://www.jonkaaseracingengines.com/ Plenty of engine porn on there. That's an easy 750 HP on pump gas, with plenty of vacuum to run power brakes, etc. Those things are da bomb!
12-06-2012, 02:16 PM
#1410 |
Oddometer: 5,671
Yep, it's a piston out of a Ingersol Rand KVS 26CT Engine. This one was over limits on out of round and was pulled. The bare piston weighs 400lbs so it makes a nice solid vice stand.
Here's a few pics. The piston has two threaded holes in the dome of the piston that are used for attaching a pulling tool to remove the piston from the engine. I just cut a piece of plate and drilled two holes so I could attach the plate to the piston with bolts....worked great. ![]() This is the KVS 26 engine, it's rated at 1000 HP at 330 RPM and drives two integral double acting compressors. This engine is used to compress natural gas on a pipeline and is the smallest engine/compressor on the pipeline. ![]() Inside the KVS crank case taking crank thrust readings. The power rods are removed in this pic so the power pin is wrapped in cardboard to keep it from getting scratched. ![]() Here's a few pics of one of the larger units, It's a Clark 12 Cyl two cycle engine driving three double acting compressors, it's rated at 4500 HP at 300 RPM. ![]() ![]() ![]() ![]() I have more pictures of the Clark here: http://www.advrider.com/forums/showt...ight=hodakaguy Hodakaguy
Be yourself, everyone else is already taken. |
| Thread Tools | |
