Old 07-11-2012, 03:04 PM   #1
DRTBYK OP
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,776
BaseCamp v4 Beta's are available
The v4 Beta's of BaseCamp are available and it appears that the BaseCamp teams are listening:
Mac-BaseCamp 4.0 is here.
The Win-BaseCamp 4.0 is here.
Garmin believes these beta to be reasonably stable, but it is a Beta, so there are definitely some quirks to be expected.
A few words about your data
When you install 4.0.0.4, all your data from 3.3 (or earlier) will be copied. You can keep using 3.3 afterwards, 4.0 will not alter your 3.3 data (but 3.3 also cannot see any changes you make with 4.0).
Change list
This is the list of changes. There is a separate thread What’s new in BaseCamp 4.0 that gives some more explanations (please excuse the Windows screenshots until I get a chance to create a Mac version. The features are basically identical between the two platforms), and a Garmin Adventures thread that introduces that new feature (again please excuse the Windows screenshots).
Added support for Garmin Adventures.
Added support to search for adventures.
Added support for transferring adventures to devices.
Added support for authoring and publishing adventures.
Added chase camera adventure playback.
Other New Features
Added intersection search. If you add an '&' between two roads, it will find the intersection, e.g. 'Main & Elm'
Added support for BaseStation mode for Rinos and Astros. Firmware support coming soon.
Added better trip planning capabilities to a route (you can set arrival/departure/layover times for via-points ).
Added a context menu for the hand and selection tools.
Added a read-only 'Unlisted Data' list that contains all items that are in no other lists.
Added support for waypoint creation date, which will not be changed when updating the waypoint.
Added information in waypoint properties which routes that waypoint is a part of.
Added ability to create a route from a named trail.
Added support for temperature and pressure in track statistics and graphs.
Added support to delete waypoints that are included in a route.
Added ability to perform undos and redos on supported devices.
Added ability to create waypoint from find result on the map.
Added a photo viewer for Geotagged Photos.
Improvements
Improved display when many photos are at the same spot on the map.
Improved XML processing (so it should now be possible to import and export larger gpx files than previously).
Fixes
Fixed numerous issues with finding addresses.
Fixed area calculation for tracks.
Fixed issue where the Geocache symbol was not consistent with found status when importing or adding a geocache.
Cheers,
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 07-11-2012, 06:49 PM   #2
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,690
Let the 'Adventures' begin!
Will these be 'packaged' in such a way that you can share them, between compatible units, like at offroad events, etc?
Old 07-12-2012, 11:37 AM   #3
DRTBYK OP
DRTBYK's Avatar
Oddometer: 5,776
Yes, that's the idea. There will be a Garmin Adventures Website where you can "share" your Adventures. In addition, each Adventure can be Exported as a GPX file. Keep in mind that any Garmin "Adventure-specific" data will not be usable by other GPS devices that are not Adventure-aware.
Adventures are a GDB database and therefore BaseCamp will, at v4, support multiple databases - as long as they are Adventures.
Looking forward to playing around with this but will have to use the Windows version until they release a new beta of the Mac version (currently, the beta will not run on my Mac).
UPDATE: Mac version is now running on my MBAir. Seems there is an issue with the "Unlisted Data" feature so I had to use another one if my databases.
Cheers,
Cheers,
Dan
All Things GPS
DRTBYK screwed with this post 07-16-2012 at 08:55 AM
Old 09-28-2012, 10:21 AM   #4
christian
Exchange your GPS Track!
christian's Avatar
Oddometer: 2,609
So what's the verdict on BC 4.x? stable? worth it ?
I am embarquing in a project to transfer all my tracks from mapsource to Basecamp, if V4 is worth it and the "adventure" feature works , then I may just do 4 instead of 3.3.x
thank you
christian
Cheers,
KTM 950 ADV '05.5
KTM 690 '10
christian is offline   Reply With Quote
Old 09-29-2012, 05:38 PM   #5
OceanMtnSea
Pretty Dogged
OceanMtnSea's Avatar
Location: left middle Saskatchewan & entering middle BC
Oddometer: 591
thank you
christian
It is BC V4.01 now and I have been using it for awhile and have not had any issues.
J
2007 BMW Dakar & 2009 Ducati Multistrada leaving the middle of the in-land sea called Saskatchewan for the Mountain Valleys of BC, Canada
http://s737.photobucket.com/user/Oce...?sort=3&page=0
OceanMtnSea is offline   Reply With Quote
Old 09-30-2012, 10:56 AM   #6
DRTBYK OP
DRTBYK's Avatar
Oddometer: 5,776
v4.0.1 is stable and only has a few annoying issues that will most likely get addressed in the next maintenance release.
DO NOT INSTALL v4.0.2 for Windows AT THIS TIME. It has an install issue.
Cheers,
Cheers,
Dan
All Things GPS
Old 10-02-2012, 05:39 PM   #7
DRTBYK OP
DRTBYK's Avatar
Oddometer: 5,776
Both the Mac and Windows v4.0.2 are safe to install now.
Cheers,
Cheers,
Dan
All Things GPS
Old 10-03-2012, 10:06 AM   #8
Lobby
Viel Spass, Vato!
Lobby's Avatar
Oddometer: 28,450
Hmmm. Are any of the Garmin units capturing this info currently? Perhaps I'm out of date....
Gracie's Gold
Lobby is offline   Reply With Quote
Old 10-03-2012, 10:08 AM   #9
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,690
Yes, with the Garmin Tempe.
Old 10-03-2012, 10:57 AM   #10
Lobby
Viel Spass, Vato!
Lobby's Avatar
Oddometer: 28,450
Well isn't that cool?
(Might have to ditch my 478 for this...)
Gracie's Gold
Old 10-03-2012, 07:13 PM   #11
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,690
Cheers,
Got one of each tonight...
Old 10-04-2012, 06:38 PM   #12
TowPro
Lets ride
Oddometer: 3,203
Why is Garmin always picking on me
Loaded win from your list, when it starts it says lost data file, fix? yes
then it installs a newer version then your link. 4.0.2.0
worked nice, made a route (in direct route) and saved it.
Restrated program, same Lost data file, fix? yes
then it installs a newer version again 4.0.2.0
my new route is gone.
and every time I restart the program, same thing all over again.
2015 KTM 690 Enduro R
2014 R1200GS - My Naked Street Touring Bike
2000 KTM LC4 640 E - currently up for adoption with 3200 miles
TowPro is offline   Reply With Quote
Old 10-04-2012, 07:58 PM   #13
LakeAbilene
Oddometer: 6
Never in the history of mankind has any leading company fought so hard against intuitive programming. I feel your pain.
LakeAbilene is offline   Reply With Quote
Old 10-04-2012, 08:22 PM   #14
EmmEff
Oddometer: 1,729
Quite simply, the people (person?) who writes the software doesn't actually use it... As a software developer myself, this isn't something new to me. I've come across many developers in my career that simply don't understand what "user experience" means.
2001 F650GS Dakar
2008 DR-Z 400S
EmmEff is offline   Reply With Quote
Old 10-05-2012, 05:46 AM   #15
OceanMtnSea
Pretty Dogged
Oddometer: 591
Yes I had this unpleasant experience too in Win7-64b the first time. I backed up all my tracks, routes and waypoints using the BC backup, then uninstalled everything, rebooted, cleared all the temp files, then reinstalled and opened the backup file I stored and all was good. No issues since then - even going from V4.01 to V4.02.
If that does not work you may have to save your waypoint, track and route files as *.gdb or *.gpx and export - then import back to your fresh install of BC.
Hope you get it up and running smoothly.
OceanMtnSea screwed with this post 10-05-2012 at 06:19 AM
Times are GMT -7.   It's 03:09 AM.
