Old 07-27-2012, 12:57 PM   #91
kubiak OP
Oddometer: 4,829
changed the rear rack and exhaust. took off the big rack and put back on a ktm 950 rack.
Old 07-27-2012, 12:58 PM   #92
kubiak OP
Oddometer: 4,829
top pic of the rack
Old 07-27-2012, 02:37 PM   #93
DingDangKid
El Lechero
DingDangKid's Avatar
Oddometer: 2,415
Originally Posted by kubiak View Post
wait im getting mixed up here, i got the body panels from you. i put those to good use too lol!
Haha yeah.. I just read that lol. I still got that light in the box in the garage. I'm going to throw it on the tw one of these days. I just haven't had the coin to buy the conversion kit to make it street legal
2006 TW200 85mpg
1981 Honda CM400T
2005 Wee
DingDangKid is offline   Reply With Quote
Old 07-27-2012, 05:29 PM   #94
kirkster70
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Kubiak,
you are a VERY talented individual!!!!
More great work, as usual. Thanks for posting your pics!
kirkster70 is offline   Reply With Quote
Old 07-27-2012, 08:06 PM   #95
kubiak OP
Oddometer: 4,829
do they check for stuff like that in your state? in california you need high and low beam but i just aimed the light more towards the road so it wouldnt blind anyone and it was fine. make sure you post pics when you get the headlight on!
Old 07-27-2012, 08:07 PM   #96
kubiak OP
Oddometer: 4,829
Originally Posted by kirkster70 View Post
Kubiak,
thanks kirkster!
Old 07-27-2012, 08:11 PM   #97
DingDangKid
El Lechero
Oddometer: 2,415
The garage I go to for inspection is pretty lick'em stick'em on bikes so I'm not worried about passing inspection. Long story short, the company I work for is very strict on vehicle appearance/noise. Blinding the locals on my way into work at night would not help my company's reputation with the locals.
2006 TW200 85mpg
1981 Honda CM400T
2005 Wee
Old 07-28-2012, 09:39 AM   #98
kubiak OP
Oddometer: 4,829
yea you would be better off seting it up right, dont want to set a bad example. did you check out that electric box i sent with the light? i didnt know if that was some sort of resistor for high low beam or for something else.
Old 07-28-2012, 12:23 PM   #99
DingDangKid
El Lechero
Oddometer: 2,415
It is a regulator/rectifier for bikes that run direct from the stator. I'd be running off a fuse block so I would be able to skip that.
2006 TW200 85mpg
1981 Honda CM400T
2005 Wee
Old 07-28-2012, 12:43 PM   #100
ergomoto
FOCUS ON THE THROUGH.
ergomoto's Avatar
Oddometer: 83
Talking Simply FABuLUST
Kicks following your wanderlust build Kubiak. Thanks for keeping the forum posted
I have been trying to read back through these many threads where your bike's progress was featured, in this case when the paint came of the lower frame rails. Wasn't it when you moved your side stand? Is that why you still us the lower rails, at least on the left side? Pardon again my asking, if this an old topic more than covered elsewhere, but I couldn't find my way back to the rail work and why. I've seen some 650's go without these lower rails, after relocating the only items they seem to serve: side stand, regulator, and stock bash plate. Now the new Husqvarna looks to be doing away with them as well. What's your take on removing these and any plans to follow suit, finding much needed ground clearance.
Cheers,
Mark S
2004 R1100S[BCR]
2005 F650GS
2004 DRZ400S/E =SOLD=
2004DR200SE
=SOLD=
"Is that what you wanted that to look like?
ergomoto is offline   Reply With Quote
Old 07-28-2012, 03:46 PM   #101
kubiak OP
Oddometer: 4,829
shoots i was thinking it might be the part you needed. hope you get the light on there soon!
Old 07-28-2012, 04:03 PM   #102
kubiak OP
Oddometer: 4,829
Cheers,
Mark S
yea i started by removing the stock skidplate since i do mostly easy trails, no rock crawling anymore. then noticed all the electrical stuff on the lower frame rails exposed so i cut the skidplate tabs off, kickstand safety switch plug gone since i disconnected it and tucked away the oxygen sensor wires behind the front frame rail. then i cut the kickstand mount off and rewelded it a few inches back and angled it down more so i could shorten the kickstand. i was wondering about removing the bottom rails alltogether but dont know how much stress they take. it would be nice if they were not needed but we need someone to try it first lol! i was also thinking on making the bottom rails straight across for more ground clearance too since the stock ones hang down so far. let me know if you find out more info on removing them all the way like the husqvarnas. thanks!
Old 08-04-2012, 07:24 PM   #103
kubiak OP
Oddometer: 4,829
just bought new rear brake shoes for the tw wheel, 12.00 for factory oem ones!
Old 08-04-2012, 09:15 PM   #104
AtlasExp
beer me
AtlasExp's Avatar
Oddometer: 435
You over paid by 1.37$
AtlasExp is offline   Reply With Quote
Old 08-05-2012, 09:58 AM   #105
kubiak OP
Oddometer: 4,829
dang!
Times are GMT -7.   It's 12:20 PM.
