Old 03-23-2013, 01:36 PM   #1666
AntiHero OP
Oddometer: 1,354
More Official Press Pics:
Social Media, Ride Report and other Links: www.antihero-x.com
Behind the Scenes Info: The AntiHero Newsletter
AntiHero is offline   Reply With Quote
Old 03-23-2013, 01:37 PM   #1667
AntiHero OP
Oddometer: 1,354
This is Claudio Domenicali, one of the top ten most powerful guys in motorcycledom--and the head of Ducati Corse. He's extremely intense. He's also the guy who was forwarded an email to my thread on either Ducati.ms or ADV, which led to my invitation to the R launch. Did I mention he was intense? 99% of the time the only expression I witnessed was ferocity. This is a rare moment where the man, just for a moment, allowed himself a moment of satisfaction at what he's accomplished:
This expression (that's Claudio on the outside of Hayden), demonstrates that intensity I spoke of:
Just a wee bit of a slide:
Exiting the pits:
Old 03-23-2013, 01:37 PM   #1668
AntiHero OP
Oddometer: 1,354
Hey, I know these guys now!
You actually don't notice it much in person:
Old 03-23-2013, 03:37 PM   #1669
CharlestonADV
I do my own stunts!
Oddometer: 578
Amazing photos and rare opportunity to see inside the workings of Corse. Last year, I went on a Ducati factory tour (purchase by Audi had just been announced) and cameras were forbidden. Needless to say...the Corse area was completely off limits.
CharlestonADV is offline   Reply With Quote
Old 03-23-2013, 03:54 PM   #1670
AntiHero OP
Oddometer: 1,354
I'm working on the full "behind-the-scenes" write up, but here's my review of the 1199 R:
When I first saw the specs of the R motor during the press launch PowerPoint (the only PowerPoint I've probably ever paid attention to in my life), the differences in weight between the S and the R flywheel and connecting rods were listed in grams. Being a retarded American who has to google “gram to ounce conversion” every time a metric unit of weight is encountered, I dismissed the figures as being measurable by sensitive scales only. One bit of data that I did understand very well was this:
Pole position for the 1199R at Phillip Island: 1:30.795.
Phillip Island Lap Record (set by Hayden on a MotoGP bike): 1:30.059.
Granted, MotoGP hasn't been to the track since the repave, so the record will fall, but the fact a largely undeveloped (for WSB) 1199R, based on a production bike with a base price of $30k, came so close to a MotoGP bike record makes you realize how glorious the Panigale is.
The first hardware details you notice about the R that sets it apart from its more plebeian siblings: aluminum blanks instead of mirrors, a larger, crystal clear, lightly smoked windscreen hiding a tiny GPS sensor under its nose, a full sewer-pipe-diameter Termi System and all sorts of carbon bits. Graphic/design highlights include the “Ducati Corse” graphic on the fairings, which tastefully breaks up the rather expansive demonic red surfaces on either side, the exposed aluminum tank and the perfectly textured new seat cover that grips on the track as well as it looks in the paddock. I’ll admit that the heat shield looks rather obtuse in pictures, but it’s fairly innocuous in person. The lack of rim stripes also gives the bike a more dedicated, singularly purposed appearance, but unfortunately the stark white ‘spider leg’ decals on the nose and fairing detracted from the elegance and simplicity of the rest of the bike. Why sexy and purposeful solid white number plate-graphics were reduced to peripheral traces deducts points from the allure and impact the R versions in the past have had. (The brushed aluminum tank is a nice consolation, though.)
Blindfolded, you’d never know the difference between the R and any other Panigale variant. That is, until you gave the throttle a blip. Those grams that threw me off as being academic during the presentation actually equate to almost 3 lbs less rotating mass, which remarkably changes the responsiveness of the engine. Whereas the base engine builds revs with brutal, explosive, mechanical fervor, the R motor responds with an synaptic, hyper, explosive fluidity.
While sitting on pit row waiting for green-flag-permission to enter the track, I got to enjoy the unapologetic, snarling sounds the engine makes exhaling through the revised Termi exhausts as the journalists launched onto CotA (with no speed limit in the pits). As I hurtled off the line the exhaust note thundered off the pit wall like a THX-optimized version of a solid-fuel space-shuttle launch from afar. The alacrity of the engine, combined with the new gearing made the R feel significantly lighter than the S or Base versions even under partial throttle.
That Ducati doesn't claim any additional HP over the base is the first indication that they might just be sandbagging and have made more changes than they're admitting. Two weeks prior I’d been on the track with my 41T S, so the violent forces associated with full throttle acceleration out of corners and onto the straits were fresh in my mind. The R, despite the standard HP claims, is noticeably more powerful. Granted, my S did dyno lower than the average Panigale, and some of the increased forward momentum could have been a result of the increased rate at which the R’s Superquadro motor revs, but seat-of-the pants is what thrills, and there was no mistaking that the R motor is all R. So much so that the front tire just skims the pavement under full throttle at 150+, causing a ‘weave’ in your line.
The timing required to keep a standard Panigale surging forward through the gears uninterrupted, save for quick stab on the quickshifter, was hopelessly inadequate for the R. Despite an additional 500rpm redline, I hit the limiter before even thinking “shift” several times during the first session. Normally towards the end of the tach stratosphere you can feel a motor begin to struggle. It’s that moment when the engine nears its operating limits and the mechanical precision distorts into aural and tactile mechanical disorganization, causing a simultaneous dip in power. You can feel the change on the Panigale around 10,250 rpm, which cues a snikt on the shift lever. On the R, this second law of mechano-thermo-dynamics-type dissolution near redline simply never happens. In a hypothetical study that I made up just now to prove my point, 10/10 motorcyclists, when asked to estimate at what RPM the R motor was at, underestimated the RPM by 3000-4000 revolutions. And when told that the engine was actually spinning at 12,000, 9/10 people estimated that the redline surely would have to be 15-16,000 rpm, based on how smooth it was. (The other 1 person dropped out due to ‘health’ reasons. We referred to him after that point as “orgasm man.”) Ever hit a false neutral while giving your bike full throttle? That's about how fast the R motor revs when driven in anger.
Similar to my thinking the engine was spinning at far less RPMs than it was, my sensitivity to lean-angle demanded some serious adjustment, too. Flicking the bike (and I do mean flicking, it felt so light) into a corner I found my knee would slap the pavement far before I expected. The engineers had indicated the adj swingarm pivot was set at 0 deg., confounding me to wonder why the bike transitioned from side to side so fluidly. (Wasn't until later that day listening to a conversation between Kevin Duke and the Pirelli rep, that the Supercorsa SPs were a brand new compound, explaining at least part of the mystery.) The rest of the changes I’ll chalk up to the track surface and the overall bad-ass-ness of the 1199.
During the past several months living with the Superquadro, I found it impossible to imagine how Ducati could improve on the Panigale. That they did so soon after launch shows you just how fanatical the engineering team is. The end-result of all the subtle changes made the R feel like it was two versions beyond the standard models. The change in engine characteristics that would definitely be noticeable on the street become more profound on the track--and the extra range of adjustment to the swingarm will make exponential differences on the WSB circuit. The R clearly pushes Ducati forward in the moto-arms-race and provides mere mortals the opportunity to experience World Superbike levels of performance without requiring WSB-like abilities (or budgets).
The Good:
Motor, motor, motor.
Seat material is so good I will be swapping out for one soon
On/off throttle less abrupt
Slipper clutch works more effectively than mine
Gear selection not as critical as on the base models
The Bad:
Having to recalibrate up-shift points
Shorter throttle pull with a rising rate would help when trying to unleash the wrath of Satan while trying to hold on (that last 10% of the throttle required an awkward wrist extension)
Full-throttle front end wander at 150+ speeds (how much steering can you do when the front wheel is barely skimming the pavement?)
Stock pegs still don’t inspire confidence, but Sidi boots make up for a lot of the deficiency.
Graphics don’t leave you in awe
AntiHero screwed with this post 03-23-2013 at 05:14 PM
Old 03-23-2013, 04:17 PM   #1671
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,848
After watching (on motogp.com) the Honda and Yamaha guys during their session a couple of weeks ago my first thoughts were, "damn the first right hand corner looks like serious fun." What were your thoughts on the track?
I noticed there is a track day there in June with prices about 2-3X the norm. Sold out of course.
swimmer is offline   Reply With Quote
Old 03-24-2013, 10:44 AM   #1672
gueroaero
Oddometer: 11
Beautiful write up. How was the new track ? :)
gueroaero is offline   Reply With Quote
Old 03-24-2013, 11:18 AM   #1673
rico2072
rico2072's Avatar
Oddometer: 320
Awesome write up once again!
The Panigale is just an amazing dream that I won't be able to afford, for the forceable future.....
As for the graphics, I love my R1 raven because of the simplicity. These on the Panigale are great!
Nice and simple, but still eye catching.
The track looks awesome, but to much red, white and blue. I'm old style and still like to see nice manicured grass with tan gravel pit where it needs to be. White and blue or red rumble strips.
Did they do it that way just for this event or will it be like that all the time?
"Beware of the lollipop of mediocrity. One lick and you'll suck forever!"Brian Wilson
rico2072 is offline   Reply With Quote
Old 03-24-2013, 01:22 PM   #1674
fifthcircle
Beer Knurd
fifthcircle's Avatar
Oddometer: 5,716
It is named Circuit of the AMERICAS. ;)
Sent from my fat thumbs on a small touch screen.
GRAVEL WORLDS
'14 KTM ADV R - '06 DRZ 400 - lot's of bicycles
fifthcircle is offline   Reply With Quote
Old 03-24-2013, 03:28 PM   #1675
DCrider
Live from THE Hill
DCrider's Avatar
Oddometer: 4,333
Awesome sea of RED
ADV'ing from America's fine Crapital...
DCrider is offline   Reply With Quote
Old 03-25-2013, 08:27 AM   #1676
musicman
musicman's Avatar
Oddometer: 101
Claudio most likely heard of you through Vickie Smith.. a person you should get to know. I do not know her exact title now but she works for Ducati in rider/club relations for the US. I sent her a link to your report early on as I'm sure others likely did.
Valve springs?! We don't need no stinkin' valve springs!
musicman is offline   Reply With Quote
Old 03-25-2013, 09:53 AM   #1677
AntiHero OP
Oddometer: 1,354
The track was brilliant. I'll have a detailed report soon. :)
As for Claudio--hmmm, I suppose Vicki might have been the mystery friend who forwarded a link to my R/R over to him. Not sure. One of the Ducati dudes just said 'a friend of Cladio's'. I've exchanged a couple emails with Vicki in the past, but we haven't ever met.
Old 03-25-2013, 11:55 AM   #1678
wantingaduc
Oddometer: 12
That sounds like something Vicki might have had a hand in. She knows more people inside Ducati than anyone, short of Cladio...
If you've never met her, make of point of doing so.
I met her and Rich 2 years ago at Ducstock and I've never met 2 more passionate, personable and genuinely nice Ducatisti in my life.
In my opinion they are royality in the Ducati world.
Looks like were going to have to add your name to that list soon enough Antihero.
jimi
wantingaduc is offline   Reply With Quote
Old 03-25-2013, 06:44 PM   #1679
jpod999
Oddometer: 5
I don't know why, but seeing you refer to your Panigale as the base model seems very comical to me.
jpod999 is offline   Reply With Quote
Old 03-25-2013, 08:07 PM   #1680
fifthcircle
Beer Knurd
Oddometer: 5,716
I love the way people within the Ducati circles talk about one another. It reminds me of the aviation community (the good parts). There are names that you can say to almost anyone in the aviation industry, and they will know who you are talking about. The Ducati people are that way, and I like that a lot. Shows passion, loyalty and community. This is just one of the things that will draw people in, and keep them in.
GRAVEL WORLDS
Times are GMT -7.   It's 03:59 AM.
