Old 07-16-2012, 09:58 AM   #1
LasseNC OP
XSessive!
LasseNC's Avatar
Oddometer: 1,071
RD350 returning to the road!
Hello guys!
This friday I bought myself an RD350 and now I'm working on getting it back and ready for the road. I've been putting some serious hours to it these last few days too.
Engine is running and sounds healthy. Compression is VERY good and it starts piss easy. Smokes too much, might have to adjust oilpump.
Wiringharness was/is a mess, but I'm doing my best to fix it. Took off the winkers, less wires is my mantra!
The petrolcarrier has a tiger painted on it, quite ugly, but very well made. This bike has been loved by someone!
All the wires you see here were not connected at one or both ends.
Here I have removed the non used wires.
Caliper was binding, so I took it apart, wiped stuff clean, blew it out and yada yada. Works fine now and is oil tight.
Wiring improvement!
Birds nest reduced by 100%!
Old 07-16-2012, 03:44 PM   #2
Shocktower
Shocktower's Avatar
Oddometer: 9,479
You might just have some residual oil in the bottom end , get a proper Manual, enjoy the ride
Alexa Drew Nov 9 1995- Oct 28th 2004 Miss you baby
'08 KTM 530 EXC
79 RD 400 Daytona
Shocktower is offline   Reply With Quote
Old 07-16-2012, 05:31 PM   #3
spo123
Man About Town
spo123's Avatar
Oddometer: 800
Thumb Beware Brother, Beware...
TIMING and CRANK SEALS!
Have Fun!
spo
1973 /5 LWB Toaster
spo123 is online now   Reply With Quote
Old 07-16-2012, 05:53 PM   #4
Shocktower
Shocktower's Avatar
Oddometer: 9,479
Have Fun!
Yes, for about 14 USD you can get new crank seals VS the 300+ for the roasting pistons , I have heard they make great ashtrays
'08 KTM 530 EXC
79 RD 400 Daytona
Old 07-18-2012, 12:21 PM   #5
LasseNC OP
XSessive!
LasseNC's Avatar
Oddometer: 1,071
Ordered an MZb ignition, which should come in tomorrow or friday :)
Old 07-18-2012, 12:44 PM   #6
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,345
Tank looks like it was Napolian Dynamite who owned it before!
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Old 07-23-2012, 04:24 AM   #7
LasseNC OP
XSessive!
LasseNC's Avatar
Oddometer: 1,071
A dead thread! YUK!
After this photo was taken I had filed it down square and level. I am going to make the inside thread M10x1.5 10mm. deep and put in a bolt, fully threaded, so I can refit a washer and nut!
It also saw daylight for the first time since I dragged it down in the bunker (Literally is a bunker!)
Old 07-29-2012, 10:00 PM   #8
tripodtiger
I used to be SCRay
tripodtiger's Avatar
Oddometer: 4,718
Good find, fingers crossed.
Too much smoke? Is it HVCycle that has the tag line 'If it ain't smokin, it's broken"
Modern two stroke oils are much better than my memory tells me period oils were - for smoke if nothing else.
Let it run and get the exhaust hot, that should burn out the oil in the exhaust / mufflers, at least until the next time you turn the engine off.
Have fun with it.
rayb Crash Dummy (no testing involved)
Old 07-30-2012, 06:16 AM   #9
LasseNC OP
XSessive!
LasseNC's Avatar
Oddometer: 1,071
I'm sorry, I couldn't help myself!
Painting it red again!
Old 07-30-2012, 09:51 AM   #10
JonnyCash
turd polisher
Oddometer: 1,606
Oh, you've done it now! Good man!
I wouldn't bring her home to Mama, but Mama ain't home tonight.
JonnyCash is online now   Reply With Quote
Old 07-30-2012, 10:05 AM   #11
LasseNC OP
XSessive!
LasseNC's Avatar
Oddometer: 1,071
Tomorrow I should get it sandblasted! I need to get the frame up in a hydraulic press to get the swingarm off. Will also happen tomorrow :)
Old 07-30-2012, 11:14 AM   #12
LasseNC OP
XSessive!
LasseNC's Avatar
Oddometer: 1,071
Inspiration!
Old 07-30-2012, 12:19 PM   #13
baloneyskin daddy
bikaholic
Oddometer: 2,158
You didn't say what you paid for it but I can almost guarantee that a real nice one could be purchased for less then you'll have in it when its done, if done correctly. Its a slippery slope you approach anytime you start a project with an old bike like this. Get online and look at the finished bikes available before you start throwing money at it. If you're doing it for the joy of the project and satisfaction and gratification youget from it then money is no object and have at it.
baloneyskin daddy is offline   Reply With Quote
Old 07-30-2012, 05:00 PM   #14
LasseNC OP
XSessive!
LasseNC's Avatar
Oddometer: 1,071
It's really not that bad :)
Old 07-30-2012, 07:24 PM   #15
JonnyCash
turd polisher
Oddometer: 1,606
Why do you need a hydraulic press to get the swing arm off?
Times are GMT -7.   It's 07:09 PM.
