Old 07-18-2012, 11:09 PM   #1
fractalsource OP
fractalsource's Avatar
Oddometer: 90
HIGH SPEED WOBBLES on my F800 GS
At about 70 mph. or 112.65 kilometers per hour my bike began to feel wobbly on asphalt.
I'm running new TKC 80's.
I assumed it was the non-adjustable, upside-down forks and replacing them, - replacing the springs, and using heavier weight oil was an option for a remedy.
- My local BMW dealer told me it was my tires. - I checked my tire pressure and wear.
I adjusted my bike for my ride, using:
http://www.photos4aidan.com/actions/F800GSPreload.html
On the Interstate without wind or trucks to give me turbulence -
Still, a wobble.
So I bought a steering damper.
Installed it.
Adjusted it, as prescribed.
Wobble gone.
- Stabilized in Idaho.
THE CENTER FOR LAND USE INTERPRETATION http://clui.org/ludb
Earthquake, Weather, Radiation LINKS
http://sincedutch.wordpress.com/1ear...diation-links/
fractalsource screwed with this post 07-18-2012 at 11:41 PM Reason: image too large
fractalsource is offline   Reply With Quote
Old 07-18-2012, 11:33 PM   #2
itsatdm
itsatdm's Avatar
Oddometer: 4,819
There have been many complaints about the wobble. Most have been with tkc80 tires. At about 300 miles the wobble goes away. I initially jacked up the rear preload and dropped the forks 1/4" inch and the wobble went away.
Since that time I have changed out the front springs and cartridge tube. I added a Hyperpro spring to rear and added some preload.
It was a very good pavement bike. I have since added a Scotts stabilizer for off road. It made the bike feel like a heavier bike.
All together, the thing is a rock. I do not care what tire is has on it, it goes where where you point it. The most stable bike I have ever owned.
itsatdm screwed with this post 07-19-2012 at 04:58 AM
itsatdm is online now   Reply With Quote
Old 07-19-2012, 04:50 AM   #3
itsatdm
itsatdm's Avatar
Oddometer: 4,819
Easy fix. Go ride in the dirt. Never wash it. It must effect more than others, never bothered me.
Old 07-19-2012, 05:40 AM   #4
amackenzie
Oddometer: 10
I run the TKC80s and I found airing up the tires helps, especially the front. I've never really had much of a problem with it though.
If you're going to do a lot of high speed highway I'd keep them pretty hard.
amackenzie is offline   Reply With Quote
Old 07-31-2012, 07:01 AM   #5
Snowy
Oddometer: 1,662
Yep.
Forks...shit. Options...shit. Solutions...like your link says:
On ADVrider, there is an extensive thread about the mythic Bitubo fork cartridges, imported from Italy. There’s one guy who actually has them, swears by them, but he does most of his riding in Staten Island. Fuck sake, lads. I need a better endorsement than that before I run out and chuck a bunch a dough at new cartridges.
Things like this stopped me in my tracks. Then there were the failures that started to emerge with the kits.
I have 2 motoX front ends awaiting that perfect moment where I have a surplus of time and money.
Then the BMW front end goes the way of the Dodo.
Front wheel clacking is most likely the disc pads floating in the caliper. Mine makes a hell of a noise. If you pull the front brake on and pump the forks see if it makes the noise then. It'll be the pads for sure.
The wobbles - itsatdm has the way of it. It's a geometry thing most likely. Play with rear pre-load and front height. Raise the rear and drop the front each by 20mm and it changes everything about the way it behaves at freeway speeds.
Some blame tyres, some blame pre-load...I just know this works after figuring it out on my own and then seeing that others agree.
Snowy is offline   Reply With Quote
Old 08-02-2012, 08:08 PM   #6
Dream Rider
Servant
Dream Rider's Avatar
Oddometer: 192
front wobble
justbought 2012 f650gs. told dealer front wobbles then settles when i push left/right quick as inavoidance maneuver. usually above 65 mph. However, since the bike settles on its own that is "normal???" bike handles fine other wise. A little more shakey thatn my 1200 GSA behind semi's or in wind,but the bike is about 150 lbs lighter. Is this the same suspension as the 800 GS?
Dream Rider is offline   Reply With Quote
Old 08-03-2012, 12:31 AM   #7
fractalsource OP
Oddometer: 90
F650 and F800 forks/ suspension
I'm pretty sure you have adjustable front forks on the 2012 F650 GS.
The F800 GS has upside down, non adjustable front forks. (What were they thinking?)
I like the diagrams for adjusting a bikes suspension, on pages 12 and 13 of this pdf. from Ohlins.
See: http://www.ohlins.com/Products/Owner...M_07241-02.pdf
Having said all that:
I weigh too much for my suspension. (300+)
So, I am getting an upgrade from:
See: http://sasquatchrider.com/products.html
My Scotts steering damper took out my high speed wobbles.
That damper works really well. I like it very much.
It does raise my bars. I can't use some wind screens, like the Windshield - VStream Touring Windshield - by ZTechnik without hitting my mirrors on the sides. Even with the mirror extenders. (I bought one and returned it.)
See: http://www.ascycles.com/detail.aspx?ID=76186
Now, I just have a bottoming out, issue. And a few noises I need to dampen.
Someday, I will dial in, this bike.
fractalsource screwed with this post 08-03-2012 at 12:38 AM Reason: added sentence
Old 07-28-2013, 01:32 PM   #8
Kevfoley
LocoRojo
Kevfoley's Avatar
Oddometer: 81
Still, a wobble.
Installed it.
Wobble gone.
I have the same problem on my F800 Trophy when running TKC80s, no problem when off road but a total pain when getting between places. Thanks for the solution.. looks like i need a damper..
http://www.celticadventurer.com check out the progess!
Kevfoley is offline   Reply With Quote
Old 07-28-2013, 05:39 PM   #9
Full Power
Oddometer: 1,463
Before you start throwing money at "Solutions", I recommend that you adjust the steering head bearing preload, according to factory specs.
You may actually have a well designed, stable motorcycle, already in possession...... with loose bearings.
Warm enough to RAIN is warm enough to RIDE.
Full Power is online now   Reply With Quote
Old 07-28-2013, 05:50 PM   #10
chris73
Oddometer: 229
Can you post a link for the method of doing this? Mine does this as well
chris73 is offline   Reply With Quote
Old 07-28-2013, 07:28 PM   #11
itsatdm
itsatdm's Avatar
Oddometer: 4,819
Stock suspension and what do you weigh?. My now 5yr F800gs would get the weave on a new TKC80. My bike did not have a loose steering head nut.
The unladen bike has more weight on the rear than the front and my theory is, it does not take much to start the weave on a set of new soft knobbys.
See if this has any impact. Scrunch up as close as you can to the faux tank. If moving your body weight forward improves things, you can either jack up rear preload substantially or raise the forks about 10mm below the line inscribed on the forks.
Even after I re sprung my bike, I still run the forks up a bit. Dirt or pavement it just goes where I point it.
Stabilizers are nice too, I crank mine down on soft terrain or rocks.
itsatdm screwed with this post 07-28-2013 at 08:14 PM
Old 07-29-2013, 01:02 AM   #12
Full Power
Oddometer: 1,463
Head Bearing preload is set thus:
Remove handlebar clamp bolts, lift and secure handlebars, for clearance.
Loosen (4) upper fork pinch bolts.
Remove decorative BMW logo from 10mm hex steering stem bolt
Tighten to 25nm
Turn steering 3 times lock to lock.
Loosen 60 degrees
retorque to 11nm.
Tighten fork pinch bolts to 19nm
replace handlebars, tighten front bolts first, rear bolts last
Old 07-29-2013, 01:22 AM   #13
Kevfoley
LocoRojo
Kevfoley's Avatar
Oddometer: 81
interesting, worth checking the various options, weighing in at 74kg (163 lbs),
It started on Motorways when travelling with loaded bike, increasing the preload on the rear suspension did help, but ultimately it did not fix the issue, same goes for tire pressures, increasing the air in the front tyre would increase stability up to a point but not eliminate the wobble, which when travelling at speed can get a little hairy!
Will check the bearings, and see, but it does not seem loose.
Scrubbed in TKC's or brand new dont seem to make much difference, just a but less bumpy on old ones ;)
Old 07-29-2013, 05:06 AM   #14
Snowy
Oddometer: 1,662
On third set of steering head bearings.
Steering damper.
RMZ front end.
They last longer now with the RMZ front end than before. But I need more kms on it before that is "factual". If I can get double the kms then I'll blame it on the standard front end.
I don't suffer as many rim dings now, I've noticed. I'm much nastier to it than I used to be.
Old 07-29-2013, 05:29 AM   #15
Ceri JC
UK GSer
Ceri JC's Avatar
Oddometer: 2,462
I also have this on TKCs on my F800GS. Fitting a Rallemoto (RM2) steering dampener and setting it accordingly, means that it doesn't become a problem until about 100mph unladen and 90mph fully laden.
I like my bike because I can overtake 4x4s down farm tracks with a week's worth of shopping on the back.
Ceri JC is offline   Reply With Quote
Times are GMT -7.   It's 06:35 PM.
