Old 07-20-2012, 09:15 AM   #1
thomas.tc.young OP
Oddometer: 862
another versys powered klr
well here it goes guys another versys powered klr project. mostly because i saw a complete versys partout and couldn't pass up the deal and the proximity.
Here's the frame.
and the engine.
everyone knows it doesn't fit in. i plan on copying some of klrsys project because its the most well documented and makes sense to me as well.
first thing's first, flip those carb boots
their directional which is why you have to flip the carbs as well
that's it for now. time to get out the sawzall
1969 CL350 permanent project
2013 Ninja 650
1987 XR600R
2001 TTR-125L
the klr/versys project: http://advrider.com/forums/showthread.php?t=810279
thomas.tc.young is offline   Reply With Quote
Old 07-20-2012, 09:55 AM   #2
kajj
kajj's Avatar
Oddometer: 192
subscribed
kajj is offline   Reply With Quote
Old 07-20-2012, 02:29 PM   #3
2fast4u
Oddometer: 747
Cool project!! I know this has been done before but never looked at a build. What fuel tank are you going to run? Just wondering about the fuel pump.
2fast4u is offline   Reply With Quote
Old 07-20-2012, 03:07 PM   #4
thomas.tc.young OP
Oddometer: 862
Im basing most of my project on klrsys's build thread. He ran the stock tank and rigged it so the hose ran into an external fuel pump mounted under the seat. I'm looking at the fuel pump and figuring out my options but that looks like the simplest way currently.
2013 Ninja 650
1987 XR600R
2001 TTR-125L
Old 07-20-2012, 04:05 PM   #5
2fast4u
Oddometer: 747
I was goiing to put a ninja motor in crf 450 frame but the fuel pump worried me. Will the fuel pump be submerged in fuel because thats what keeps the pump cool and with a external fuel pump you have to think safety. I was thinking about a fuel tank off a 610 husky but don't know that would work. Would have to compare fuel pumps. Will be watching.
Old 07-21-2012, 07:21 AM   #6
KLRsys
KLRsys's Avatar
Oddometer: 131
The stock Versys fuel pump has to be put in a can for cooling. If anyone knows of a suitable small external pump and regulator I would like to hear about it and I'm sure Tom would also. The specs for the stock pump:
With engine idleing: 294 kPa (3.0 kgf/cm2, 43psi) with fuel pump running
Discharge: 60ml or more for 3 seconds (72 liters/hr)
KLRsys screwed with this post 07-21-2012 at 08:02 AM
KLRsys is offline   Reply With Quote
Old 07-21-2012, 08:46 AM   #7
LukasM
Oddometer: 5,425
The Suzuki LT-R 450 quad pump is perfect. It's about 4-5" long and should put out enough juice for 65 RWHP.
Old 07-21-2012, 01:12 PM   #8
2fast4u
Oddometer: 747
The problem with an external pump is the fuel lines. If you was to wreck and break or crack a fuel line with that much fuel pressure it could be bad real bad.
Old 07-21-2012, 02:53 PM   #9
LukasM
Oddometer: 5,425
I don't really get the concern?
The pump and lines would be tucked in under the tank, so they won't be damaged if you crash. If you use fuel injection rated hose it will not split either.
And most importantly, the only difference between internal and external pump is the line going from the tank to the pump, and that is not even under pressure?
Old 07-21-2012, 03:43 PM   #10
2fast4u
Oddometer: 747
The stock line thats under pressure on the ninja is very short when you move it under the seat you will have two long fuel lines. This bike should be able to run over 120 mph. It just scares me not saying it wouldn't work. The tank off of a KTM or Husky that has the fuel pump in it would work and be safer and easier. Just my opinion.
Old 07-21-2012, 07:30 PM   #11
DRjoe
DRjoe's Avatar
Oddometer: 5,136
You sleep with the lights on don't you.
Old 07-21-2012, 08:40 PM   #12
wibby
BrotherFromAnotherMother
wibby's Avatar
Oddometer: 10,580
'05 DL650
'92 KDX200
wibby is offline   Reply With Quote
Old 07-21-2012, 10:00 PM   #13
RedRaptor22
Oddometer: 155
I've worked on a few bikes that had external pumps, never heard of them turning into fire balls.
Like that other guy said, the only difference would be a couple of inches of plain rubber fuel line from the tank to the pump, even mounted under the seat the bike would have to turn itself inside out for damage to occur.
RedRaptor22 is offline   Reply With Quote
Old 07-22-2012, 07:17 AM   #14
Kawidad
Kawidad's Avatar
Oddometer: 4,901
Facet makes some really nice, small external fuel pumps. They are a common upgrade on KTM Adventures. DAMHIK.
As an example:
http://www.aircraftspruce.com/menus/...telectric.html
FAA rated, so....................
BTW, since you have a bare KLR frame, I would suggest welding a small plate over the spine above the shock mount/down tube area. There is a lot of stress on that point is it is known to fail and be a weak point.
I'm in.
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 07-22-2012, 08:47 AM   #15
thomas.tc.young OP
Oddometer: 862
service manual reveals fuel pressure is 294kPa, 41.81psi and discharge is 83mL (2.8US oz) and more/10 sec. i dont think it will work with that lower flow rate, anyone else know if it would or wouldn't?
2013 Ninja 650
1987 XR600R
2001 TTR-125L
Times are GMT -7.   It's 07:15 AM.
