Old 07-22-2012, 05:43 AM   #1
mikesova OP
mikesova's Avatar
Oddometer: 1,940
EMGO Travel Trunk, Any Good?
I just installed a set of Givi E21's on my FZ6 and I wanted to add an inexpensive topbox to the set. The EMGO looks pretty reasonably priced and decent looking box that will fit a helmet. Is the box decent? How is the mounting system? Any pics/info would be appreciated.
http://www.amazon.com/Emgo-72-32440-.../dp/B000GVD0VE
2009 Kawasaki KLX250S
2005 Yamaha TW200 (Wife's bike)
2005 Yamaha FZ6
2009 Honda Ruckus
mikesova is offline   Reply With Quote
Old 07-22-2012, 05:53 AM   #2
Unstable Rider
10,000 Lakes
Unstable Rider's Avatar
Oddometer: 2,577
Hey Mike,
Great post. A friend of mine got the Emgo trunk for the back of his Super Tenre. Thought if it looked and worked smart enough to hang on that bike, (and it looks right on it..) that it would be good enough for my stinking second gen. KLR 650.
Had mine about a year, think I paid like 69 bucks for it from Dennis Kirks... I live close enough to Kirk's to just drive over and get one, and skip the shipping charge.
I really like mine... no issues, really. It will fit a 3 XXXL full face helmet if nothing else is in there...
(yes, I got the huge melon).
Ps: one tip for you-- both of us that have these opted to put the quick docking plate onto the trunk's base, but then drilled clean through it and used longer stainless bolts, washers and nylon filled lock nuts.. end result, they are perm- mounted now, I have some LEDS to back up my brake light wired into mine, as well as a cig. lighter socket to charge my iphone while I am riding. Works great.
The quick release system a little stiff and gritty, and we did not want them inadvertently popping off if not latched onto the base all the way, so we went with the perm-mount method, never looked back, 4 bolts, your done, no worries. Weather and dust proof, looks great too.
I have big ass Pelican Hardigg Storm cases as panniers, and the Emgo as the tailbox. Great setup.
-“Ah, you're wasting you're time. They can't track us over rocks.
Tell them that.......... --Who are those guys?”
~Butch Cassidy
Unstable Rider is offline   Reply With Quote
Old 08-27-2012, 08:26 AM   #3
steveb126
Adventurer Anonymous
steveb126's Avatar
Oddometer: 1,038
Does anyone know if the EMGO mount will accept my monokey E36 GIVI cases ?
Found an EMGO mount on ebay, its half the cost of the GIVI universal mount.
I may not be much, but I'm all I think about.
Wee & Wingabago Wanderings
steveb126 is offline   Reply With Quote
Old 08-29-2012, 11:43 AM   #4
kitesurfer
kitesurfer's Avatar
Oddometer: 1,666
I have a givi plate and it's much larger than the EMGO. but as to which givi i have, i do not know.
2012 VSTROM ADV 650
US NAVY RETIRED
kitesurfer is offline   Reply With Quote
Old 08-29-2012, 11:50 AM   #5
2fastlx
2fastlx's Avatar
Oddometer: 83
I just got one. Seems pretty solid so far.
2fastlx is offline   Reply With Quote
Old 08-29-2012, 12:01 PM   #6
duck
duck's Avatar
Oddometer: 10,403
Word of advice #1: Do not cram pack it and use the latch to force it closed. The latch will break. And then you'll spend the rest if your trip with a string tied around it to keep it closed.
Word of advice #2: When the latch breaks, don't run out and buy a whole 'nother travel trunk. The lock and latch are available as a separate part. Emgo part number is 72-32442.
Now I've got two of them!
duck is offline   Reply With Quote
Old 08-29-2012, 12:08 PM   #7
duck
duck's Avatar
Oddometer: 10,403
A similarly priced and sized top case is the Givi E26. (Note that it uses the Givi MonoLOCK base, not the Givi MonoKEY base. They are different.)
http://www.motorcycle-superstore.com...-Top-Case.aspx
Old 08-29-2012, 04:14 PM   #8
Bluesmudge
Bluesmudge's Avatar
Oddometer: 117
I have been using (abusing) mine for years. The price has gone up at least $10 since I bought it, but the case is still a good deal. EMGO is not known for quality, but I have to say this thing is well made.
Bluesmudge is offline   Reply With Quote
Old 08-29-2012, 07:11 PM   #9
ausguy
Oddometer: 58
Love Mine
Ausguy
ausguy is offline   Reply With Quote
Old 09-06-2012, 08:47 AM   #10
jsb223
ADV Rookie
jsb223's Avatar
Oddometer: 1,218
If it has the plastic base, make sure it's completely flat when mounted to your rack
or it will crack.
R1150GSA
DRZ400S
DRZ400E
jsb223 is offline   Reply With Quote
Old 09-06-2012, 11:30 AM   #11
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,667
or it will crack.
That's good info.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 11-21-2012, 02:08 PM   #12
TheLandYacht
Oddometer: 25
Do you mind if I ask where you got those side-box things? Manufacturer, model, etc would be appreciated. Thanks for your time.
TheLandYacht is offline   Reply With Quote
Old 05-12-2013, 01:08 AM   #13
HaChayalBoded
Brooklyn Bored
HaChayalBoded's Avatar
Oddometer: 7,927
anyone pick up a replacement latch kit for their emgo but only need the flip down section and not the lower piece? Seems thats the part that breaks but they give you the whole thing as a replacement.
I'd be curious if that lower piece with the red button and the 4 scew holes would fit my GIVI, rather not order a $30 emgo kit replacement in order to find out. Thought maybe one of you guys had a spare.
HaChayalBoded is offline   Reply With Quote
Old 05-12-2013, 08:32 AM   #14
Mobiker
Oddometer: 1,754
No it won't fit. I have the Emgo and E36's.
I only used the Emgo for a couple of years. Its a fine box for the price. The plastic for the mounting plate does not look to be as good as the plastic Givi uses. I think Givis are better made all around which is probably why they cost so much more. That said I wouldn't hesitate to use the emgo.
'88 R100GS
'76 xl350
"Don't Panic"
"If I was in a hurry, I'd left earlier."
Mobiker is offline   Reply With Quote
Old 05-12-2013, 10:54 AM   #15
HaChayalBoded
Brooklyn Bored
Oddometer: 7,927
Although the GIVI boxes will not fit the emgo and other off brand plates (it gets very floppy). An emgo or JC Whitney box WILL fit a GIVI plate. Certain ones may require an ever so slight filing on the INSIDE edges of the openings that slide over the mushroom bolts.
I had a pair of GIVI cases that I used as panniers on my concours before finally getting myself a set of GIVI cases.
Times are GMT -7.   It's 06:04 AM.
