Old 10-05-2012, 02:59 AM   #61
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,196
Originally Posted by TVtommy View Post
I think I'm going to order a solo from S.Meyer in Germany. Should bolt directly on yes?
I was told yes for my R80gspd but it does not. Going to require welding for proper fit. Other may have had better luck.
I ordered R80 solo seat
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Old 10-05-2012, 05:32 AM   #62
motog
Oddometer: 85
Originally Posted by Uncle Pollo View Post
Both! Por favor ...
Send me a PM and I'll dig out and send you the emailed descriptions of the work that I shared with a few mates who are doing similar things. I probably shouldn't put it on this site because the level of profanity (faux-swearing rather than actual) is a bit high for such a family oriented place. If some pseudo-swearing is not to your liking, let me know and I'll edit it out before sending
motog is offline   Reply With Quote
Old 10-05-2012, 07:55 AM   #63
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,409
Has anyone tried to buy an oem 3/4 seat lately?
boxerboy81 is offline   Reply With Quote
Old 10-05-2012, 08:47 AM   #64
R100LT
Chasing 11
R100LT's Avatar
Oddometer: 628
One went for just under Aus$500 on Ebay UK about 4 weeks ago . Almost went for it .. but I had just bought a 22 litre top box for my RS ... Plus I like the option of being able to put someone on the back ... But YES the 3/4 do look dead sexy
BMW R100LT 93 BMW R100RS 91 BMW K1100LT SE 94 76 R90S
R100LT is offline   Reply With Quote
Old 10-05-2012, 01:00 PM   #65
GapRunr
GapRunr's Avatar
Oddometer: 493
Does it require welding for the seat to fit the rack or for the rack to fit the bike? I just bought a new OEM luggage rack and am looking for a seat to fit it.
GapRunr
07 R1200GSA - 81 R80g/s - 88 Hawk GT - 06 TW200 SuperDuper Tenere
GapRunr is offline   Reply With Quote
Old 10-07-2012, 09:31 AM   #66
Sutherngintelmen
around the bend
Oddometer: 1,196
The welding will be to reposition the lock in tab - needs to move forward 10mm. I'm thinking I'll use some flat bar, machine slots for adjustment. Aggravating to need to do this.
Other disappointment is quality of vinyl. I haven't had the privilege of sitting on it so can't say if quality of materials caries through to foam.
Doesn't seem to interfere with factory racks.
Old 10-07-2012, 05:02 PM   #67
Wdwrkr
Wdwrkr's Avatar
Oddometer: 1,853
Originally Posted by testa d'aria View Post
Obviously I don't know how to download more than 1 picture per post ...........
[IMG][/IMG]
Pretty a /6 as I've seen. Loven the rear fender is that from a /2? Also no mirrors?
Wdwrkr is offline   Reply With Quote
Old 10-14-2012, 05:09 PM   #68
Sutherngintelmen
around the bend
Oddometer: 1,196
I got motivated.
This is my very first weld project, wish I'd shaken the photo a bit.
Overalll I'd describe the build quality of the S Meyer solo seat as China. I've hopes of some long distance on this bike so seat is going off to Renazco for foam and cover. I'm going to have too big a chunk of change in it, maybe I'll learn not to drink and ebay.
First, detach misplaced prong.
Then learn to weld.
Next, handy chop saw.
Factory Fit
And you will need to custom fit to eliminate massive slop up front. I used closed cell foam and shoe goo.
Sutherngintelmen screwed with this post 11-04-2012 at 04:39 PM
Old 12-11-2012, 02:03 PM   #69
Sutherngintelmen
around the bend
Oddometer: 1,196
I knew this would happen.
Busted the lock after 4th or 5th ride with solo seat.
The seat has mounting brackets but the bike (84 R80gspd) is missing counterparts.
Ideas on retrofit? Anyone else run across this?
Old 12-11-2012, 02:14 PM   #70
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,294
Yep, the lock doesn't eliminate the pivoting of the seat. You'll have to run some angle irons off of the bracket that houses the seat lock. I welded the nut on the bottom of the bracket for ease of assembly. I'll take a pic when I get home. I brake the angle brackets about once a year.
Old 12-11-2012, 03:42 PM   #71
tofgasp
tofgasp's Avatar
Oddometer: 58
for the Giulliari Replica. Looks good as a solo, but still able to take a passenger for short rides.
tofgasp is offline   Reply With Quote
Old 12-11-2012, 04:16 PM   #72
Beater
Dirty
Beater's Avatar
Oddometer: 3,198
'New Solo Seat' (Made from an Old one )
Fred
'85 R80RT G/Sified <|> '91 R100GS Bumblebee (103K miles and climbing) <|> '73 R75/5 LWB
Airhead Zen: Ride - Repair - Ride - Maintain - Ride - Repeat
Beater is online now   Reply With Quote
Old 12-11-2012, 04:21 PM   #73
SOLO LOBO
airhead or nothing
SOLO LOBO's Avatar
Oddometer: 8,715
Here's my hack-job solution...
"punkrocks what it's all about" - J. Strummer
SOLO LOBO is offline   Reply With Quote
Old 12-11-2012, 04:33 PM   #74
Sutherngintelmen
around the bend
Oddometer: 1,196
Excellent.
This will give me a reason to do some more "welding" .
Old 12-11-2012, 05:26 PM   #75
Sutherngintelmen
around the bend
Oddometer: 1,196
Nice example. Looks like I could do that without melting metal.
Are you guys using fasteners to secure seat supports to your customer brackets or is 'gravity' the retainer. Wondering for seat pop off ease ?
Times are GMT -7.   It's 08:04 AM.
