Old 08-02-2012, 01:57 PM   #1
Meritlane OP
Meritlane's Avatar
Oddometer: 65
simple accessory adapter
I came up with this simple solution to mount a cigarette lighter accessory plug.
I purchased a battery Tender female cig. adapter and terminal harness. Both available from Amazon for $10.50. Then a got a grey plastic fitting from the electrical dept at home depot for .30. I painted the piece black with Krylon Fusion. This stuff is the bomb for plastic. Using the existing windshield screw I was able to firmly mount the adapter in a convenient place. It's also easy to remount when I change to the tall windscreen. In addition I can quick release the lighter plug and hook in the trickle charger using the same harness.
[[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Meritlane screwed with this post 08-02-2012 at 02:13 PM
Meritlane is offline   Reply With Quote
Old 08-03-2012, 03:11 PM   #2
sarathmenon
Oddometer: 893
I went though pretty much the same mod, except that I picked up one of these for mounting. I am not that cheap after all
sarathmenon screwed with this post 08-03-2012 at 03:11 PM Reason: Fixing link
sarathmenon is offline   Reply With Quote
Old 08-05-2012, 11:34 AM   #3
MikeMike
MikeMike's Avatar
Oddometer: 4,150
Meritlane, excellent idea!
I owe you one or two!
What I like about that is how the wire won't be constantly moving back as it would on the steering head.
Very cool, thanks.
Times are GMT -7.   It's 07:13 AM.
