Old 08-03-2012, 12:32 PM   #1
naginalf OP
Handy Schtroumpf
naginalf's Avatar
Oddometer: 250
Quick ? about F series axle nuts
I'm looking at getting one of these wonderful multitasking tools,
And the 3/8" adapter:
And I was just wondering what the most common axle nut size is on the KTM and F series bikes that are popular enduro bikes. I don't think there's much I need a 24, 27, or 32mm spanner for on my own bike and since it doesn't matter which size I get, I figured I might as well get the most common size needed for other bikes that might need a hand with a tool or two. Probably a dumb question tho, since you probably always have the tools on hand, but if it doesn't matter, and I can be a tad more prepared, that would be good.
'91 R100GSPD
Adventures with a Type1 TARDIS.
naginalf is online now   Reply With Quote
Old 08-03-2012, 10:43 PM   #2
squawk77
Dreamer
squawk77's Avatar
Oddometer: 542
I just ordered one of the 24mm ones with the ratchet adapter myself. Since they cost more and look a bit more awkward, I got a few of the normal tire levers as well. Not a bad idea though
ADVriders on Kiva | Balkans | Morocco | Alps | Corsica
squawk77 is offline   Reply With Quote
Old 08-04-2012, 12:38 AM   #3
GoneAgain
Huh?
GoneAgain's Avatar
Oddometer: 1,577
i contemplated getting a 24mm one too... but i wasnt sure that it would fit down in over the 800's axle nut... the ring spanner end seems fairly thick, and a socket 'just' fits down in there on the axle nut.....
anyone confirm you can actually get it on the nut?
GoneAgain is offline   Reply With Quote
Old 08-04-2012, 04:11 AM   #4
1994klr250
1994klr250's Avatar
Oddometer: 652
I have the 24mm and it is to big to fit in the space for the rear axle nut.
2300 miles on a 250 all for a sticker http://www.advrider.com/forums/showthread.php?t=616239
Fall ride on a KLR250 http://www.advrider.com/forums/showthread.php?t=754065
1994 KLR250, 2009 F800GS, 2006 KLX351
1994klr250 is online now   Reply With Quote
Old 08-04-2012, 04:33 AM   #5
casperghst42
casperghst42's Avatar
Oddometer: 212
Remember that the 'Motion-Pro-3-8-Drive-Adapter-for-T6-Tire-Lever' is only good for 40nm, and the rear axel nut needs 100nm.
Casper
casperghst42 is offline   Reply With Quote
Old 08-04-2012, 07:54 AM   #6
GoneAgain
Huh?
GoneAgain's Avatar
Oddometer: 1,577
coool! (well not really ) but as i suspected...
thanks for the confirmaton
Old 08-04-2012, 03:20 PM   #7
sturgeon
sturgeon's Avatar
Oddometer: 931
You guys must have smaller nuts than me
My 24mm MP combo tire iron fits the rear axle nut on my F800GS just fine. It doesn't cover the entire nut, but certainly enough for me.
Dyslexics Untie!
sturgeon is offline   Reply With Quote
Old 08-04-2012, 04:31 PM   #8
naginalf OP
Handy Schtroumpf
naginalf's Avatar
Oddometer: 250
Thanks for the pic and info Sturgeon. 24mm it is! That coincides with hondas as well apparently. Look like ktms are 27 tho. Thanks again!
'91 R100GSPD
Old 08-05-2012, 08:03 AM   #9
sturgeon
sturgeon's Avatar
Oddometer: 931
Cruz Tools makes a couple of nice combo axle wrenches as well, if you want alternatives. I've got a 22/27 mm for another bike.
http://www.cruztools.com/products/axleplug.html
Dyslexics Untie!
Old 08-05-2012, 08:11 PM   #10
trizzo
Oddometer: 207
i picked up a 17mm/24mm combo wrench for $11.99 from rocky mountain atv - http://www.rockymountainatvmc.com/p/...ch/TUSK+WRENCH
should do the job for front/rear on the GS
trizzo is offline   Reply With Quote
Old 08-08-2012, 04:01 PM   #11
sturgeon
sturgeon's Avatar
Oddometer: 931
Casper
Yabbut, the hex end of the tire iron itself is good for 122 Nm, no need for the adapter for that if you have the 24mm version
Dyslexics Untie!
Times are GMT -7.   It's 08:27 AM.
