Old 08-04-2012, 11:12 AM   #1
Bobmiller90 OP
Oddometer: 113
Dorsoduro - transformation into ADV bike
This is my 2012 Aprilia dorsoduro SMV750
The idea is to build it into a ADV bike as good as any other multi-cylinder.
This includes the following big things:
- Wheels
- Gas Tank
- Skid plate.
And there'll be a load more Other things.
So - Wheels:
Bobmiller90 is offline   Reply With Quote
Old 08-04-2012, 01:03 PM   #2
WARRIORPRINCEJJ
Not in the clique...
WARRIORPRINCEJJ's Avatar
Oddometer: 9,747
Originally Posted by Bobmiller90 View Post
This is my 2012 Aprilia dorsoduro SMV750...
...- Wheels...
...So - Wheels:
I hadn't seen anything like this, before. So, just curious...
17/17 or 19/17?
I spent all my money on motorcycles, 4X4's, whiskey, and women...The rest I just wasted. (edited to fit/original phrase by "WIBO")
"There's a WEALTH of cool people and knowledge on ADV, there's also a decent sized pocket of douche bag assholes that think their ADV forum Post Count (Oddometer) is their badge at being experienced riders." goodcat8
WARRIORPRINCEJJ is offline   Reply With Quote
Old 08-04-2012, 04:16 PM   #3
Milosh
Milosh's Avatar
Oddometer: 112
Subscribed.
Milosh is offline   Reply With Quote
Old 08-04-2012, 04:47 PM   #4
Bobmiller90 OP
Oddometer: 113
Wheels
19/17
This is the rear which is from a 2004 Aprilia (keep it in the family!) Caponord. It is 17X4.00 - 36 spoke tubeless.
I bought the whole rear wheel sans disk (pics to follow) but was in pretty dire condition.
I aim to run GS size tyres and TKC rubber.
Old 08-05-2012, 06:24 AM   #5
Bobmiller90 OP
Oddometer: 113
So here's the original Caponord wheel, pretty tatty:
Here it gets a bath in WD40 in anticipation of deconstruction. Left overnight too.
Here's another few pics of it before:
Old 08-05-2012, 06:41 AM   #6
Bobmiller90 OP
Oddometer: 113
After
Here are some pics after a bit of a clean-up:
Sprocket is good, bearings appear to be ok. Hub was painted silver by Aprilia and thats a bit tired, but not too bad. I need to do some more work on it.
Looking at the pics you can see I have removed the rim from the hub.
Wow, that was fun. They were ALL seized - the problem is the spokes are straight, like nails, so as soon as you put the allen key on them, they just turn in the socket. Great!
I had to clamp the spoke in a vice and then try. I managed to get all but one out, that one I had to cut the spoke.
3 hours of my life I'll never get back...
Anyway. The spokes are stainless, and are in pretty good shape, so I think I will reuse. The tensioners weren't:
So In ADVrider spirit I made myself a tumbler:
(old paint tin on the end of a cordless drill)
Then added some crushed glass form the blaster (i would have blasted them, but they are too small):
And let it run on slow until the battery runs out. I'll post the results later,
Cleaned out all the holes in the rim with the cloth burr on the dremel:
Now I just need to get the rim checked and I will start reassembly for alignment.
Some concerns:
Axles size - the 'HardBack' runs big axles, not sure what they are but I reckon either 25 or 30mm. The Capo is a 20mm.
I can either replace the bearing (might be difficult, not much in the way of OD size) or have a new axle and spacer-inserts made up. I need to measure it properly and get onto SKF.
The rear disk on the Capo is 280mm, the HardBack is 240. I think if I trim down a Capo disk it may work, but likely it'll need a spacer anyway. The spokes go left to right and vice versa, so there should be sufficient space for the caliper.
I want to have a true bolt on bolt off with the standard wheels, no changing bracket or crap like that.
Time will tell.
Old 08-05-2012, 07:20 AM   #7
Leviathan
Tenerider
Leviathan's Avatar
Oddometer: 142
Subscribed.
Leviathan is offline   Reply With Quote
Old 08-05-2012, 09:05 AM   #8
Kawidad
Kawidad's Avatar
Oddometer: 4,759
Nice. I thought about what you're doing when I saw pictures of this bike.
In.
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 08-05-2012, 10:22 AM   #9
stevh0
Super Retard.
stevh0's Avatar
Oddometer: 1,419
im in too :)
06 950S
Yamaha YZ250WR
Ex 1150GS, 650R, Ex 950SE, Ex 950ADV
Ex SM610, FS570, WR450, Africa Twin(s)
stevh0 is offline   Reply With Quote
Old 08-05-2012, 10:43 AM   #10
ram1000
ram1000's Avatar
Oddometer: 1,833
What will you do about the extra space between the swing arm where the axle goes through and the new wheel assembly. It is going to look a bit awkward. I looked into a smaller wheel (150/80-17 adventure bike size) in the rear but decided I would have to cut and weld the swing arm assembly to get it much more narrow. Also the alignment for the sprocket to the output shaft will be off even if the swing arm were made narrower. Same problem up front but the triple clamp can be changed to a narrower assembly and front wheel. Do you intend to extend the suspension travel?
A good adventure bike will get you to where you wish you had a good dirt bike! (and back)
:2014 XC800 :2012 WR450
ram1000 is offline   Reply With Quote
Old 08-05-2012, 02:38 PM   #11
Bobmiller90 OP
Oddometer: 113
I'm not overly fussed about looks, its more about how it rides. I will use longer spacers in the space, but the Capo hub is not as narrow as you may think. I will update with dimensions and specs later. If I were to try to address it, i would most likely build a tube steel custom swingarm - the design of the Hardback swingarm is really simple - it has no linkages. My biggest concern is how much offset I will need to use to ensure the centre line is maintained; I expect I will need to pull the rim over to the disk side a fair amount. The standard rim width is 6", the Capo is 4". This means that I might have to pull it over a bit.
I think the front would be similar; it is not as wide. I guess we will see!
I will take and post detailed pics for all.
I plan to change the suspension as far as springs go up front (and oil). The rear will be a height adjustable Nitron shock.
Old 08-05-2012, 03:49 PM   #12
jaumev
jaumev's Avatar
Oddometer: 1,487
Nice project but it is such a beatiful bike... I would be really afraid to spoilt it...
I'm going to follow the thread with interest
jaumev is offline   Reply With Quote
Old 08-06-2012, 01:19 AM   #13
JohnG.
JohnG.'s Avatar
Oddometer: 1,946
JohnG.
JohnG. is offline   Reply With Quote
Old 08-06-2012, 02:21 AM   #14
Cortez
BAZINGA!
Cortez's Avatar
Oddometer: 6,979
'08 Yamaha FZ6n S2 ABS
SOLD: '03 Peugeot Speedfight2, '07 Kawasaki ER6F ABS, '06 Kymco Agility 125, '12 Kymco Downtown 300i ABS
My Flickr gallery --- My 500px gallery
Cortez is offline   Reply With Quote
Old 08-06-2012, 03:23 AM   #15
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,702
Have you considered getting Talon to make up some hubs to your spec?
Interesting project. I've thought for quite a while (after riding one of those bikes a couple of years ago) that if Aprilia marketed an ADV version, I'd have bought it. I had to wait for the Tiger800XC to come out to find my ideal bike.
2002 black Tiger955i, 72000 miles and counting.
2012 black Tiger800XC, The other British Land Rover. 40000 miles and counting.
2013 black Tiger800XC, The other British Land Rover. 500 miles and counting.
blacktiger is offline   Reply With Quote
Times are GMT -7.   It's 05:18 AM.
